4wd popping under load
Discussion in 'Suspension' started by 17inferno, Feb 24, 2020.
  1. Feb 24, 2020 at 3:12 PM
    17inferno
    17inferno [OP] New Member
    Hey guys, living in Wisconsin I use 4wd often, year round as needed and a few weeks ago I've noticed a popping noise under load in 4wd, as in pop pop pop, etc, but not under light load (front left is best guess). I swap my coilovers often so winter isnt so harsh on them (king 2.5) and currently have 5100's middle setting so I can keep my bigger tires on. Also I've popped the axle out a few times during this process but never had to force it back in, just turn untill it easily goes back in. Mentioning this so it's complete info as best I can.
    Truck is a 2017 limited crewmax 4x4 with 31k miles. Is this most likely the axle itself? No tears in the rubber boot or leaking...and it doesnt appear strained on the joint at all...
    It is under warranty but I hate to put it stock to run it in, but I may have too
    Thanks for any insight
  2. Feb 24, 2020 at 4:21 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    CV joint? what else 'pop, pop, pops'?
  3. Feb 24, 2020 at 9:52 PM
    Mdjamesd
    Mdjamesd New Member
    2015 Silver Sky Crewmax
    Does it pop when driving on slick or dry pavement?
    If slick/icy, then sounds like an issue.
    If dry pavement, it's from the driveline binding.
  4. Feb 24, 2020 at 9:54 PM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Yeah u-joint or drive axle !
  5. Feb 25, 2020 at 7:03 AM
    17inferno
    I don’t run it on dry, just slick. Thanks for the feedback! Just nice to hear second opinions
