4wd not engaging
Discussion in '1st Gen Tundras (2000-2006)' started by Truckhappy, Aug 14, 2015.
  1. Aug 14, 2015 at 8:18 PM
    Truckhappy
    Truckhappy [OP] New Member
    Mycousin is a Firestone mechanic and replaced the bad differential actuator on my 02 SR5 that I recently bought from my brother-in-law but he said it still isn't engaging the 4wd? Thoughts?
  2. Aug 14, 2015 at 8:36 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    How did he know it was bad?
  3. Aug 15, 2015 at 4:21 AM
    Truckhappy
    My brother in law had gotten it looked at prior to me purchasing it so when I bought it it was disconnected and he had said that there was a fuse that was pulled as well. My cousin doesn't think the fuse that was pulled was the right one. He also said that when he replaced it he could see it was broken.
  4. Aug 15, 2015 at 7:48 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Huh... so does the tcase shift at all or do u just have a flashing light?
  5. Aug 15, 2015 at 8:57 AM
    Truckhappy
    Just a flashing light
  6. Aug 15, 2015 at 2:00 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    U should crawl under it and see if the front driveshaft is locked to the front diff or tcase at all.
  7. Aug 18, 2015 at 5:09 AM
    Truckhappy
    He checked and the driveshaft isn't locked
  8. Aug 18, 2015 at 11:00 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Ok so it spins freely. That means the add actuator isn't locked nor is the tcase. If the add is new and installed correctly... I'd head towards the tcase actuator and diagnose there
