4WD Maintenance Question
Discussion in 'General Tundra Discussion' started by badavis837, Sep 12, 2017.
  1. Sep 12, 2017 at 11:56 AM
    badavis837
    badavis837 [OP] New Member
    2007 Tundra Crewmax TRD 4WD
    Flowmaster duel exhaust
    Hi guys,
    I'm new here. I have a 2007 Crewmax TRD 4wd. This is actually my 3rd Toyota 4wd, my second Tundra and I love them.
    I recently heard a recommendation that you should drive in 4WD periodically to keep everything lubricated and working properly. Is this true? If so what kind of interval/distance is best?
    Thanks,
  2. Sep 12, 2017 at 12:02 PM
    What the manual says. 10 miles once a month. Don't forget to run 4 low for just a minute when you can.
  3. Sep 12, 2017 at 12:30 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Oh wow. Never know!!
  4. Sep 12, 2017 at 1:01 PM
    badavis837
    Thanks!!!
  5. Sep 12, 2017 at 1:04 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    And don't do it on dry pavement
    NoobTruckin likes this.
  6. Sep 12, 2017 at 1:11 PM
    Unless it's on a straight road...
  7. Sep 12, 2017 at 1:32 PM
    badavis837
    I looked through my manual and didn't see this. Which manual is it in?
  8. Sep 12, 2017 at 1:39 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I put it 4hi-4low monthly, is it true you can't turn sharp in either modes?
  9. Sep 12, 2017 at 1:42 PM
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
    On pavement yes, it binds up the driveline and can cause problems. In snow/mud loose traction situations you can turn like normal as the tires can slip as needed to relieve binding.
    Samoan Thor[QUOTED] likes this.
  10. Sep 12, 2017 at 1:44 PM
    Welcome from Texas! O.P. post pics of your ride
