4wd low beeping
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Meis, Jul 15, 2019.
  1. Jul 15, 2019 at 12:30 PM
    Meis
    Meis [OP] New Member
    Brandon
    2018 SR5 gray
    I am a first time tundra owner with recently purchasing a 2018 trd sport. I tested out the 4wd low this past weekend and noticed on the dash that the 4wd high was lit up and the 4wd low just kept blinking and beeping the whole time. The beeping was extremely annoying so I was wondering if this is normal?
  2. Jul 15, 2019 at 12:33 PM
    cnoyes72
    cnoyes72 New Member
    CT
    2018 Tundra SR5 DoubleCab 4x4
    Driver-side assist handle, extang trifect 2.0 tonneau cover
    It means you weren't in 4lo. Did you put the truck into 4hi first, then put the transmission into neutral then into 4lo?
    15whtrd, Black Wolf and Meis[OP] like this.
  3. Jul 15, 2019 at 12:38 PM
    Meis
    Brandon
    2018 SR5 gray
    No, I didn’t. Is this what is needed to be in 4wd low? If so, why all the hoops to jump through just get there?
  4. Jul 15, 2019 at 12:43 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    So you dont accidentally break anything. IMHO
    Tundyfundy, Black Wolf and Meis[OP] like this.
  5. Jul 15, 2019 at 12:43 PM
    cnoyes72
    cnoyes72 New Member
    CT
    I'm not sure but if I had to guess (from the way 4lo works), it keeps people from wrecking their drivetrain by switching into it while going too fast (more than a mile or two per hour).
  6. Jul 15, 2019 at 1:10 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    did your truck come with a manual?
    1RONMAN81, bvia, gladecreekwy and 2 others like this.
  7. Jul 15, 2019 at 1:52 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Shifting from 4hi you need to stop, shift into neutral, select 4 low and wait 3 seconds. The dash will then indicate 4low. Same operation to shift back into 4hi.
    As a rule I do not operate 4 low above 20mph, if even that fast.
    Sunnier, joonbug, 15whtrd and 2 others like this.
  8. Jul 15, 2019 at 2:11 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Should also have had an easy reference card in the visor.
  9. Jul 15, 2019 at 2:29 PM
    phabej
    phabej New Member
    2018 Platnium
    Yes, that's what the manual states. page 27
    Yes, must be a Toyota thing.. my previous 16 Chevy Silverado was quite easy, didn't need to go to neutral but much easier to go to 4 Low.
  10. Jul 16, 2019 at 3:59 AM
    Boots
    Boots New Member
    Houston Tx
    2018 black tundra
    Procomp 6in lift w 35's 30in grill light bar Bac bed cover Taco tunes sq1 sound system Tinted windows Custom Masonic grill.
    When I bought mine it did the sam . Make sure your in neutral when you switch to 4l. You may hear some notching noise but it will go into gear. Also if it doesnt, roll forward and try it again. Hope this helps.
  11. Jul 16, 2019 at 4:13 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    There’s a card on your sun visor with steps on how to engage 4wd.
  12. Jul 18, 2019 at 8:36 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Not on the 2019.
  13. Aug 4, 2019 at 1:31 PM
    madmatt
    madmatt New Member
    Ocala Florida
    2018 Crewmax 4x4. TRD
    Last night my 2018 wouldn’t shift from 2wd to 4hi. It beeped for a couple minutes then stopped beeping but the 4hi light kept flashing. I was in a position where I couldn’t stop (unless I was SURE I was going to be able to employ 4wd) so I had to drive like that for about 5 minutes before I could stop. I turned back to 2wd and tried switching back to 4hi and finally it went. I was then able to switch from 2 to 4 hi at will. I think my truck wanted me to get stuck!
  14. Aug 4, 2019 at 1:36 PM
    cnoyes72
    cnoyes72 New Member
    CT
    How fast were you driving when you tried to engage 4hi?
  15. Aug 4, 2019 at 1:38 PM
    madmatt
    madmatt New Member
    Ocala Florida
    I’d have to guess between 15 and 20 mph.
  16. Aug 4, 2019 at 2:09 PM
    Toyota is very conservative with 4hi at 62. I shifted in and out on my 09 Taco and 07 Tundra well over 70 mph with no issues many, many times. All depends on road conditions and experience. Especially on my way up to AK with my Taco. Easy peasy....:burnrubber:
  17. Aug 9, 2019 at 4:52 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Keep in mind, 3rd Gen Tundras have something called a "brake stroke sensor" that can also cause the 4lo and 4hi to malfunction intermittently. Mine beeps at me and flashes 4lo sometimes when I start it. Can usually make it stop by shifting to neutral, quickly engaging and disengaging 4hi. Been doing it off and on for over a year. Doesn't appear to cause any other issues, but I do plan on fixing. Don't ask me why Toyota finds it necessary to measure brake stroke(??) I only know about it because my friend is a GM certified mechanic and he's replaced quite a few of them on Tundras. Hope this helps. And please, no stroke jokes. Well, maybe a few would be ok.
    15whtrd likes this.
  18. Aug 9, 2019 at 5:04 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I had to go to neutral or park or depress clutch on every Ford I owned to go to lo
  19. Aug 9, 2019 at 6:33 PM
    madmatt
    madmatt New Member
    Ocala Florida
    Dude! Don’t break it when you stroke it! That would be very bad!
    Kerch71[QUOTED] likes this.
