4lo does not engage
Discussion in '1st Gen Tundras (2000-2006)' started by 831.Tundra, Jun 17, 2020.
  1. Jun 17, 2020 at 6:37 AM
    831.Tundra
    831.Tundra [OP] New Member
    2002 Tundra 4x4 aces cab
    Hello so I’m knew to the tundra game and truck scene al together. I got my 2002 tundra 4x4 aces cab that goes into 4hi but not 4lo. I’ve tried it exactly the way the book says to do it but unfortunately it won’t go in. Any tips?
  2. Jun 17, 2020 at 6:58 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So what happens we you try it? Any noise? Flashing lights on the dash?
  3. Jun 17, 2020 at 9:15 AM
    831.Tundra
    No noise or flash on the dash or anything
  4. Jun 17, 2020 at 9:41 AM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    Are you sure you're in neutral when trying to engage lo?
  5. Jun 17, 2020 at 11:28 AM
    831.Tundra
    Yes I put it into neutral hold down the break and hit 4lo but nothing happens no light or anything
  6. Jun 17, 2020 at 11:35 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sometimes you need to allow the vehicle to roll a few inches so things can align and mesh. Sometime moving the steering wheel back and forth will do the trick as well.
  7. Jun 17, 2020 at 11:37 AM
    831.Tundra
    I’ll try that but I’ve tried moving the steering wheel a little but nothing
  8. Jun 17, 2020 at 1:03 PM
    fighthedude
    fighthedude New Member
    After you hit it do you put in drive or just stay in neutral because no light? Put in 4 lo then reengage tranny and see if that works
  9. Jun 17, 2020 at 1:04 PM
    ChillTree
    ChillTree New Member
    2019 Tundra Platinum
    TRD Pro Rims
    time for a new one :p
  10. Jun 17, 2020 at 2:46 PM
    Professional Hand Model
    Hand Protectors
    1) Engage 4HI and then stop.
    2) Put in Neutral.
    3) Engage 4Lo and wait for the ‘thunk’ and green light on button to light.
    4) Nothing?
    5) Put in drive and 4Hi still works?
    I’d check connections underneath. Maybe that tube is disconnected.
  11. Jun 17, 2020 at 9:15 PM
    831.Tundra
    Professional handle thank you so much that did it I was not pushing in the 4hi but I followed your steps and it worked I appreciate it
    Festerw likes this.
  12. Jun 17, 2020 at 9:21 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I guess that none of us thought to mention you must first put it into four-wheel drive high, then you can go from there to four-wheel drive low. You cannot go from two-wheel drive high, directly to four-wheel drive low in one step. Oh well, it looks like you figured that out! I'm glad nothing is wrong.
  13. Jun 17, 2020 at 9:38 PM
    831.Tundra
    Yea I’m new to the truck scene I have been driving ricers all my life. Thanks you guys for the responses they really helped out
    Wynnded likes this.
  14. Jun 18, 2020 at 3:56 AM
    Hand Protectors
    You are welcome. My handle is @Professional Hand Model, but I’ve been called worse. Give thanks to God because he is the one that drops these ideas in my head.
    Wynnded likes this.
