4in ready lift
Discussion in 'Suspension' started by Gak, Sep 2, 2016.
  1. Sep 2, 2016 at 11:07 AM
    Gak
    Gak [OP] New Member
    2016 Tundra SR5 Black Tss
    2016 cm tundra, can I run 35x12.5x20 on factory tss rims with a 4in ready lift?
    AnonVet likes this.
  2. Sep 2, 2016 at 11:14 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I'm no expert, but I'm inclined to say yes. There are a fair amount of guys on here running that size with a 3/1 coil over lift.
    Law323 likes this.
  3. Sep 2, 2016 at 11:18 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Oh yeah, but I would get some spacers with those rims. They'd be rubbing on the UCA's like crazy at that width.
    zcarpenter92 likes this.
  4. Sep 2, 2016 at 11:27 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Glad you picked up on the rims @Law323, cause it went right over my head ha.
    Law323 likes this.
  5. Sep 2, 2016 at 12:00 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    OP would've figured it out pretty fast anyways LOL
  6. Sep 5, 2016 at 4:31 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    I've got a 2015 CM that I'm trying to do the same with. I currently have a 3in level with 255/70r18 and after talking to CJ from here, I want to 4in block the rear and put a 3in spacer in the front. If you go with 35'something you should post some pics so I can see what it looks like.
  7. Sep 5, 2016 at 4:40 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    4 inch block in the rear? That's going to give it a pretty big (and noticeable) rake. If that's what you want, I'd go with shackles being its a much safer option than blocks (especially one that big)
  8. Sep 5, 2016 at 5:44 PM
    Gak
    Gak [OP] New Member
    If I can't run 35x12.5x20, what would be the best size to run?
  9. Sep 5, 2016 at 6:05 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You should be able to with a 3/1 and decent offset (18-35 should do it)
    I would go to a local tire shop you trust and get a test fit. Most 35's aren't even a true 35"
  10. Sep 6, 2016 at 8:55 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Agree with Law. You can fit 35s on a 3" or 4" lift with some minor cutting of plastic and possibly the cab mount chop (CMC) but....
    you will need to add 1.25" wheel spacers to the factory wheels. They have an offset of +60. With the 1.25" wheel spacer you will be at +20 which is a perfect offset to not stick out too far but look good.
  11. Sep 6, 2016 at 9:00 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    ^^^^ Brian said it all
  12. Sep 17, 2016 at 3:57 AM
    Gak
    Gak [OP] New Member
    Went with 4in Ready Lift, 285x65rx20 on stock TSS rims, had to trim skid plate about 1in on both ends. No rubbing, love the way it came out.
  13. Sep 17, 2016 at 9:05 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Good choice! I'm running that size on stock rims with a 3/1 and a TRD skid plate, and didn't have to cut anything. I'm surprised you had to trim your skid plate, but maybe the TRD is shaped differently.
