4Hi vs. AWD
Discussion in '3rd Gen Tundras (2022+)' started by Doofus, Aug 9, 2021.
  1. Aug 10, 2021 at 10:41 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  2. Aug 10, 2021 at 11:37 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Depends on the 4runner. My 2001 (like Tucsons) had 2wd, AWD, 4Hi (center locked), and 4Lo. My girlfriend's 4th gen (2003) has AWD all the time and then 4Hi (center locked) and 4Lo, but no 2WD capability at all. Some 4Runners are traditional and some have AWD, depends on the year (changes among even the same generation) and trim level.
    Wynnded likes this.
  3. Aug 10, 2021 at 12:32 PM
    bwh
    bwh New Member
    My 2012 Trail has a t-case with a manual shifter.
    4hi, 4lo, and 2hi.
    FO LO likes this.
  4. Aug 10, 2021 at 12:40 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I know the 3rd gen 4r had both depending on the engine in them.
    The V8 had full time but the V6 part time.
    Pretty sure the 4th gen are all part time but not betting money on it either!
  5. Aug 11, 2021 at 11:01 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    I've had AWD (Audi) and 4WD in Tundras. The AWD Audi was what I preferred taking to the mountains to ski when I lived in Vermont. The Tundra was good, but not quite as firm a feel on the road. And both had full on winter tires, Hakka 5's on the Audi, and Hankook Winter tires (Nokian tread) on the Tundra all the way around on both. I typically kept the Tundra in 2wd unless I was having to take off in deep snow, or things got very deep on the road. If I was having issues in 2wd, it meant time to slow down and think about maybe 4wd.
    TK1979 likes this.
  6. Aug 12, 2021 at 4:35 AM
    nodak67
    nodak67 New Member
    JR
    as long as you had the torsen version in the audi, the haldex versions were considered inferior and put in to save money.
    gj953[QUOTED] likes this.
  7. Aug 12, 2021 at 9:00 AM
    gj953
    gj953 New Member
    East Coast
    Yes, this was a 2002 a6, it was fun driving it in snow over the hood, with all 4 tires sending up rooster tails as they dug in! My wipers couldn't keep up with the snow coming over the hood at times!
  8. Aug 13, 2021 at 10:17 AM
    Stryder03
    Stryder03 New Member
    2017 Black Tundra
    My 2001 Land Cruiser and 2015 Sienna with AWD are outstanding in slippery conditions. This will be the first winter that I have had a selectable 4wd since I moved to Montana, so I am looking forward to seeing how it compares.
  9. Sep 6, 2021 at 12:25 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    should have 2wd, 4h, 4lo with manual selector just like God intended. No buttons needed
    snivilous likes this.
  10. Sep 6, 2021 at 2:40 PM
    ezdog
    ezdog New Member
    Gateway To The West
    If God had a plan here it would be whatever the Land Cruiser has and there is no manual selector there.
    How is this not obvious really?
    Wynnded likes this.
  11. Sep 6, 2021 at 2:56 PM
    FO LO
    FO LO New Member
    not 100% sure what that is but I hope it doesn't have 4x4 buttons on the center console where I'll always be bumping them
  12. Sep 6, 2021 at 4:33 PM
    JuicyJ
    JuicyJ New Member
    It kind of looks like the 4x4 control is at ground zero for drink spillage
  13. Sep 6, 2021 at 4:45 PM
    9DivDoc
    9DivDoc New Member
    Wisconsin
    2021 TRD PRO CM MGM 2021 SKM CM Limited
    Worked for the Soo Line before they got creative and made us all obsolete...that job was definitely ulcer material.
  14. Sep 6, 2021 at 4:51 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Land Cruisers are always in 4wd.
    If you can't avoid spilling your drinks there are groups for that too.
  15. Sep 10, 2021 at 10:45 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    4 Auto in the domestics usually sucks. It only sends power to the front axle when the rear starts to slip. Ram uses a Borg Warner transfer case with clutches that wear and eventually won’t keep the front driveshaft engaged when the front wheels have traction and the rear are slipping. It’s a terrible system but it will make it through the warranty period.
    I would love full time 4 wheel drive with a locking center differential in a pickup.
  16. Sep 15, 2021 at 11:43 AM
    kdehkordi
    kdehkordi New Member
    I read this thread looking for clarity but I'm more confused now that before. o_Oo_Oo_O
    First Question; what is the diff btwn AWD and 4WD? I thought the difference btwn them was that 4WD has a transfer case and is lockable, whereas AWD does not have a transfer case and uses the brakes to transfer power to the wheels with grip.
    What's so special about the Subaru system and can someone school me on it?
    Second Question; does the Tundra system allow you to use 4WD on asphalt or when it's raining. My primary concern and use for AWD/4WD is for commuting (going up and down hills) during inclement weather. For example when it's raining and cold, therefore the chance of black ice. Or when it's starting to snow but hasn't covered the entire roadway.
    I know some 4WD systems can cause binding and therefore should NOT be used on asphalt.
  17. Sep 15, 2021 at 12:19 PM
    snivilous
    SW UT
    GTFO poser.
    :D
  18. Sep 15, 2021 at 1:40 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I thought it might be obvious that I was talking about modern SUV style Cruisers and not the actual real things.
    Shame on you for not knowing between the lines!:boink:
    snivilous[QUOTED] likes this.
  19. Sep 15, 2021 at 1:46 PM
    #49
    snivilous
    SW UT
    Shit I was waiting for you to post a picture of your mom mobile and then I was gonna tell you it's not the actual real thing :D
    ezdog[QUOTED] and Cpl_Punishment like this.
  20. Sep 16, 2021 at 3:58 AM
    #50
    nodak67
    nodak67 New Member
    JR
    in a nutshell...
    most awd systems are based on the ecu using the brakes to modulate the traction.
    some have the ability to sorta e-lock the front/rear temporarily up to like 25-30 mph and they disengage (rav4, etc)
    some of the higher end awd have a center diff or front/rear/center diff's like the top of the line wrx sti's (but remember these a uni-body vehicles not BoF trucks, so its mostly for city/crap weather/tracking in the sti's sense)
    full time 4WD is rarity since usually they employ a center torsen diff (so you dont bind on pavement since you are sending power 40/60 typically all the time) and the ability have a low end gear (aka 4runner limited). some of the higher end full times have front/center/rear so you can lock the fronts (both spin together) center (front and rear spin together) or rear (both rear spin together), usually i see that on g class or other high end vehicles.
    and then you have the upper extremes with portal axles.
  21. Sep 16, 2021 at 6:08 AM
    #51
    JuicyJ
    JuicyJ New Member
    Not "most". Just "some"
    I've never owned a vehicle with such an AWD system, and we've owned plenty of Subarus and I currently own a AWD Q60, maybe some chintzy newer CUVs use the brakes to limit wheelspin, but certainly not most.
    ezdog likes this.
  22. Sep 16, 2021 at 7:43 AM
    #52
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    Yota could easily use the TOD (torque on demand) Borq Warner transfer case if they wanted to. Toyota currently use the Borq Warner SOTF (shift on the fly) transfer case. The TOD is more expensive than the SOTF because it has clutch plates and an electromagnet to allow slip.
    I had the TOD in a F150 and I thought it was great when you have patchy snow. I really like the front axle locking mechanism in the Toyota over the vacuum hubs of the Ford.
    JuicyJ likes this.
  23. Sep 20, 2021 at 3:06 PM
    #53
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    I assume that the question is 4WD vs AWD ? also confused of why this in the 2022+ Tundra section while we are talking about Fords o_O
  24. Aug 25, 2022 at 11:50 PM
    #54
    Monel
    Monel New Member
    I've been wanting to explore this for a while but have only found one build and that was for swapping a Land Cruiser transfer case (which is full time 4WD) into a Gen 2 Tundra. Have you seen any build threads for putting a full time Multi-Mode case from a Sequoia into a Gen 1 Tundra?
    Monel
  25. Aug 26, 2022 at 8:06 AM
    #55
    mass-hole
    mass-hole New Member
    I wouldn’t trade 4hi/4Lo of awd/full-time/4auto
    But having the option for awd would affect my truck buying decision. Luckily, GM Ford and Ram all offer 4Auto cases with 4hi and 4lo so its not an issue.
  26. Aug 26, 2022 at 8:06 AM
    #56
    mass-hole
    Because Ford(and GM and Ram) offers 4auto with 4wd, and Toyota sucks
    DFS likes this.
  27. Aug 26, 2022 at 8:13 AM
    #57
    mass-hole
    I wont speak to Ram or GM’s systems since ive never used them, but Fords 4auto doesnt just send power forward when the rears slip. Its constantly varying torque to the front.
    Ive not heard of people ruining t-cases on Fords unless they are trying to boost launch(supercharged 5.0 or Ecoboost) a tuned truck with 600+ ft-lbs of torque
  28. Aug 26, 2022 at 8:18 AM
    #58
    mass-hole
    Your missing the best part of your limiteds t-case. 4Lo unlocked. Great for moving trailers around the yard or general offroading
    You tcase shouldnt be binding though. My lexus GX has rhe same t-case and the system is virtually transparent
    Acedude likes this.
  29. Aug 26, 2022 at 9:50 AM
    #59
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    The Toyota multimode transfer cases do it all, 2WD, AWD in high or low, locked center diff in high or low.... the Torsen T3 center diff is excellent. The Tundra could probably utilize the rear Torsen from the LX600, which will certainly help.
    Wynnded and Acedude like this.
  30. Aug 26, 2022 at 10:06 AM
    #60
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I would atleast need to have a RWD option for the 3-5 donuts I do per year.
