4HI light keeps blinking
Discussion in '1st Gen Tundras (2000-2006)' started by faviles, Nov 20, 2018.
  1. May 27, 2020 at 5:24 AM
    Professional Hand Model
    Hand Protectors
    Glad to help. There is no way to ensure anything other than take a chance OR buy a new unit. Maybe you could find one at a local junkyard or online junkyard and have them open it up for you before purchase. This “ensures” you.
  2. May 27, 2020 at 9:58 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Same story here with my project TRD I'm rebuilding. Had the flashing 4HI light and no 4LO.
    I ended up buying a new front ADD actuator and found a very clean used Transfer Case actuator located in California. It came from a Sequoia. The motor on the Trans case actuator was frozen, and even after disassembly, cleaning, lubrication and reassembly, it wouldn't work.
    So, I would find one from a climate like California or Nevada, to reduce the likelihood of purchasing a corroded unit.
    Also, I purchased one from a seller who carried a 60 day warranty. After installing both actuators, I tested the system and all is well.
  3. May 27, 2020 at 11:47 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  4. May 28, 2020 at 5:43 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Can you drive with 4hi on, on the dry highway? I want to get some good miles in with 4wd on but not sure if that would damage anything. I think its okay because your not making any sharp turns at low speeds which would bind any gears..
  5. May 28, 2020 at 5:45 AM
    Hand Protectors
    Yes, as long as you are driving straight. The Toy Manual says to do this on a regular basis.
  6. May 28, 2020 at 5:49 AM
    Pucks18
    That sounds a little bit impossible, your bound to have to turn a little. But thanks!
  7. May 28, 2020 at 5:51 AM
    Hand Protectors
    Yeah a little turning/swerving is bound to happen on a road. Less than when 4 wheeling!
    Pucks18[QUOTED] likes this.
