4hi flashing, no cruise control, and only 2wd works
Discussion in '2nd Gen Tundras (2007-2013)' started by Dirtriding4life, Jan 1, 2021.
  1. Mar 15, 2023 at 3:56 AM
    Redkaz04
    Redkaz04 New Member
    In the tundra market
    My motor tests fine on the transfer case..it’s not getting electrical power. I just started the truck and the 4HI is flashing and cruise won’t work.
    I was not trying to engage 4x4 and there are no codes…..
    swede78 likes this.
  2. Mar 25, 2023 at 9:29 AM
    BT3100
    BT3100 New Member
    Not sure if you checked but I had a similar issue with the Sequoia 08'
    Ended up being a solenoid in the trans. Pulled the pan and changed it out. Works fine since. Been 2 years.
  3. May 14, 2023 at 3:46 PM
    Sierramare’
    Sierramare’ New Member
    Ted
    Alaska
    2007 SR5 DC 4wd
  4. Jun 16, 2024 at 11:53 AM
    stephanie23
    stephanie23 New Member
    Toyota sequoia
    This is a super old post but I’m hoping someone found out the issue. I just bought a 2017 Toyota sequoia 2 weeks ago. Noticed the horn doesn’t work, which we knew that when we bought it. The cruise control doesn’t work, the wipers work but the wiper sprayer doesn’t work. Today I heard something funny when turning then noticed the 4HI light on the dash is on and I can’t turn it off. Sounds like the same issue that some of you had. Are they all connected? Thanks for your help.
  5. Jun 16, 2024 at 12:50 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    The steering controls sound like the clock spring is bad.
    koditten likes this.
  6. Jun 16, 2024 at 1:00 PM
    stephanie23
    Toyota sequoia
    Thank you
  7. Jun 16, 2024 at 8:23 PM
    koditten
    Kirk
    Midland of the Mitten
    I agree. The clock spring or as it's also known as, the ribbon cable could be bad.
    Do you know if and rack and pinion, or tie rod work was done?
    Quite often workers are not aware that the steering wheel can only be turned left or right roughly 2.5 revolutions. If turned too far, the clock spring is stressed and breaks. Loss of horn, C control or various steering wheel stereo controls is common.
    stephanie23 likes this.
  8. Jun 17, 2024 at 12:23 AM
    stephanie23
    Toyota sequoia
    I do not know if or when those things could have been worked on. In your opinion would this have anything to do with the 4H coming on while driving when not being manually put on?
