$440 for body mount chop?
Discussion in '2.5 Gen Tundras (2014-2021)' started by mahmer09, Mar 6, 2020.
  1. Mar 6, 2020 at 12:26 PM
    TXTundra2722
    2015 Black Tundra
    Thanks, you're a life saver because 37s and 0 offset rims are going on in the next month
    joonbug[QUOTED] and mahmer09[OP] like this.
  2. Mar 6, 2020 at 1:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I would suggest chopping it but not plating it until the wheels are on.
    PeakIT, saybng, Inquiringone and 4 others like this.
  3. Mar 6, 2020 at 1:52 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I follow those guys on YouTube. They do some really clean work on Toyotas.
    mahmer09[OP] likes this.
  4. Mar 7, 2020 at 4:32 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    So much this. I had to chop more that I thought I would have, I was glad to not have to cut them back off.
    440.00 is a "we don't want to do it " price.
  5. Mar 7, 2020 at 6:45 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    $440.00 dang add two hundred bucks more and that’s the price of a good welder from Lincoln.
    TXTundra2722, Hbjeff and joonbug like this.
  6. Mar 9, 2020 at 4:34 PM
    mahmer09
    mahmer09 [OP] SR5 4x4
    Going with JBM Off-road in Orange. $289 otd, appointment on the 17th. I’ve got a ton of stuff this week. I’ll report back then.
    Hbjeff and saybng like this.
  7. Mar 9, 2020 at 4:44 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    For those who have done this to there own truck, when welding on the plate, do you guys disconnect the battery or not worry about it?
    TXTundra2722, LittleTRD and Pinay like this.
  8. Mar 9, 2020 at 4:45 PM
    saybng
    Gary
    Ventura CA
    Please post pics when you get it done..interested on how it turns out..:thumbsup:
    mahmer09[QUOTED][OP] and Pinay like this.
  9. Mar 9, 2020 at 4:56 PM
    LittleTRD
    LittleTRD New Member
    James
    Central California
    2015 Tundra Crewmax
    Camburg UCA's, Fox Factory 2.5's Front & Rear, Coachbuilder +3 Shackles, Decked Bed System, Snugtop Rebel Shell, switch pros 9100, and baja designs for all additional lighting.
    Definitely, disconnect the battery, easy cheap insurance to protect your electrical system.
    saybng[QUOTED] likes this.
  10. Mar 9, 2020 at 4:57 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I did. Also, weld small sections at a time to not heat it up too much. Pretty sure you can melt the rubber bushings on the cab mount.
    saybng[QUOTED], LittleTRD and Hbjeff like this.
  11. Mar 9, 2020 at 5:00 PM
    LittleTRD
    James
    Central California
    2015 Tundra Crewmax
    Yup, I second that, small welds are necessary. I also kept a bucket of water and rags to surround the bushing and also to dab the metal between welds for cooling.
    I did a little write up on my BMC. If you want to check it out.
    https://www.tundras.com/threads/3rd...op-w-relentless-fabrication-bmc-plates.63370/
  12. Mar 10, 2020 at 3:32 PM
    Inquiringone
    Ter
    NorCal 408
    I did unhook my battery at the negative battery post while welding on my cab chop. It’s not mandatory but it’s a good idea.
    My trucks brain, and radio, etc came back without any issues at all.
    I have a Lincoln mig welder 220 Volt W/gas mix bottle.
    Good luck to anyone who tackles this challenge. :popcorn::popcorn::popcorn:
  13. Mar 10, 2020 at 4:28 PM
    Jdubb33
    Jdubb33 New Member
    Jeff
    2020 Platinum
    hitech and Pinay like this.
  14. Mar 10, 2020 at 5:56 PM
    TXTundra2722
    2015 Black Tundra
    Where were those two areas that you cut from.... not talking about the body mount spot
    jewsNbrews likes this.
  15. Mar 10, 2020 at 10:09 PM
    Inquiringone
    Ter
    NorCal 408
    A few inches above the cab chop are 2 vertical seams that stick out, you’ll see it when you remove the plastic inner wheel well. tires will rub, if not delt with, some people hammer thoes seams flat. (Bend them over).
    I trimmed it, and then welded the seams together. Repainted black.
    Small white corner is the bottom of the fender flair
    bigger tires may require more need to message some inner structures.
    Hope that helps
    TXTundra2722[QUOTED] likes this.
  16. Mar 17, 2020 at 3:33 PM
    mahmer09
    Got it done today. JMB Off-Road in Anaheim was great. Took under 4 hours, looks great in my opinion.
    LittleTRD and jewsNbrews like this.
  17. Mar 17, 2020 at 4:38 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    They did a nice job, looks great
    Mountun Goat and jewsNbrews like this.
  18. Mar 17, 2020 at 4:59 PM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
  19. Mar 17, 2020 at 5:38 PM
    #49
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I built mine for free with scrap steel I had laying around the shop :) :cheers::crapstorm:
    Tundradrenalin likes this.
  20. Jul 12, 2021 at 6:50 AM
    #50
    BAPPO
    BAPPO New Member
    2017 superwhite tundra trd 4x4
    6112 front rear airlift bags with cradle and 5112
    Anyone know of places that would do bmc in miami
  21. Jul 12, 2021 at 8:47 AM
    #51
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
