4 Inch Lift SR5 w/TRD OR Pkg
Discussion in 'Suspension' started by Blankcheese, Jul 6, 2016.
  1. Jul 6, 2016 at 9:33 AM
    Blankcheese
    Blankcheese [OP] New Member
    Johnny
    '16 SR5 DC 4WD
    I've decided a 6 inch lift is too much for my 2016 SR5. Given I have the TRD OR pkg, does this affect which type of lift I should consider? I will not be doing much off-roading but read that spacer lifts at 4" or more are not ideal from a performance standpoint.
    Not sure if I'm going with 35s but would definitely be at least a 33-34. I like the look where the tire just extends slightly beyond the wheel well.
    My factory wheel may not have the back spacing to handle a larger tire without rubbing.
    CaptTyler likes this.
  2. Jul 6, 2016 at 9:36 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I personally would never get a spacer lift of more than 2.5".
    If you want 35" tires I would recommend a 3"+ lift, check out OME lift with a shackle in the rear.
    Unless you bought new wheels, you would probably have to get some wheel spacers from Spidertrax too to fit the 35s.
    Lots of options out there though! Plenty of people will chime in. Have fun with it :cheers:
  3. Jul 6, 2016 at 10:21 AM
    TheBeast The Beach
    Aftermarket wheels / 35" Toyos + Toytec BOSS kit with shackles. Done. ;)
    Blankcheese[OP] likes this.
  4. Jul 6, 2016 at 11:55 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Agree with this one. Either spidertrax wheel spacers or aftermarket wheels, 34.5 or 35" tires and Toytec Boss.
    TheBeast[QUOTED] likes this.
  5. Jul 6, 2016 at 11:58 AM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
    You can go up to 3" of lift with an Old Man Emu, Bilstein, or Coilover Kit. Some people have run up to 35s. To lift more than 3" you will need to go with a Drop-Bracket type of kit. These are not bad for street driven vehicles as the keep the suspension geometry close to stock, as well as the driving/handling characteristics.
  6. Jul 6, 2016 at 11:59 AM
    csuviper
    Broomfield, CO
    All of the different trim levels are built the same for the suspension. There is just a difference with the coilovers and shocks that are provided. The lift kit would be the same for all trim levels.
    If you do not off-road at all then a spacer suspension lift is ok. Make sure to get a quality one though like Toytec offers. Definitely don't go over 3" on a spacer lift.
    New coilovers and rear shocks will be helpful to get extended length for the change in height.
    Check out this thread: https://www.tundras.com/threads/guide-different-types-of-lifts.546/
    TheBeast likes this.
  7. Jul 6, 2016 at 2:40 PM
    veg hed
    veg hed Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    What size wheel spacers would you guys recommend for this set up?
  8. Jul 6, 2016 at 2:46 PM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
  9. Jul 6, 2016 at 4:35 PM
    Blankcheese
    Johnny
    '16 SR5 DC 4WD
    So its sounding like I'm not getting much bang for the buck out of the TRD off road pkg?
  10. Aug 13, 2016 at 4:29 PM
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    I have a 2016 SR5 with the TRD package. Add some rear shackles, new coil overs, and change out the the rear shocks and the TRD package becomes a waste of money. Only thing things left is the badging and thin skid plate. I would have did it differently.
