4 door Tundra Axle
Discussion in '1st Gen Tundras (2000-2006)' started by Davenos66, Sep 30, 2022.
  1. Sep 30, 2022 at 12:13 PM
    Davenos66
    Davenos66 [OP] New Member
    Dave
    2006 Toyota Tundra 4.7 4 door 2wd
    factory X-SP Package
    I have a 2006 Toyota Tundra 4 door 2wd. My axle is leaking grease badly.
    I was told by mechanic who works on these to find a full axle shaft assembly. Dorman makes after market parts but not for my model.
    The truck is not wort paying for genuine Toyota parts. For everything i would need would cost me an arm at least. Does anyone know someone besides Dorman that that makes aftermarket axle parts.
  2. Sep 30, 2022 at 12:53 PM
    shifty` All my rowdy friends have settled down
    4 door double cab or 4 door access cab?
  3. Sep 30, 2022 at 1:23 PM
    Davenos66
    Dave
    Double cab
  4. Sep 30, 2022 at 1:47 PM
    I mean, I can't talk to aftermarket but IIRC, the double cab is different housing than access/regular cab by an inch or fraction of an inch.
    I'm curious where it's leaking from, are you in the salt/rust belt and the pumpkin is rusted through?
    I'd probably be hitting www.car-part.com and trying to find a used complete rear axle from a 2005-2006 double cab Tundra. There's bound to be several out there...
  5. Sep 30, 2022 at 4:06 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Leaking grease??? I'm with Shifty, if you're situation is not a rusted through axle tube, than you have lots of options for repair. Leaking diff cover can be repaired, leaking axle seals can be repaired, leaking pinion seal can be repaired.
    Lots if us on here recommend Toyota OEM due to the lack of quality control in aftermarket parts. Manufacturers that produced ok parts a year ago are now sold/merged into megacorps that churn out parts that only last 12 months or 12,000 miles. Our OEM parts lasted 100, 150, 200k so we prefer to change it once and not have to deal with it again for a decade or so.
    FrenchToasty likes this.
  6. Sep 30, 2022 at 4:30 PM
    Davenos66
    Dave
    I live in the northeast so yea lots of road salt but nothing is rusted through that I can tell Im not sure exactly where it is leaking from.
    The inside of my brake housing and rim are covered in oil.
  7. Sep 30, 2022 at 4:32 PM
    Davenos66
    Dave
    I have limited tools and no garage to work in so I don't mind spending a little more money to make it easier.
  8. Sep 30, 2022 at 4:33 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Axle seals. @bmf4069 has done those.
    Does your truck have ABS?
    bmf4069 and FrenchToasty like this.
  9. Sep 30, 2022 at 4:34 PM
    Davenos66
    Dave
  10. Sep 30, 2022 at 4:35 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It might be worth looking at a junk yard for a complete rear end
  11. Sep 30, 2022 at 4:38 PM
    Davenos66
    Dave
    I have started to look but 2wd in northeast is hard to find
  12. Sep 30, 2022 at 4:39 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    2wd & 4wd are the same except for the pinion flange... Which can be swapped.
  13. Sep 30, 2022 at 4:54 PM
    Davenos66
    Dave
    Good to know
  14. Sep 30, 2022 at 6:49 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yup. It's not bad to replace the axle seals and retainers if you know someone with a 20 ton press. Me and @Mr.bee did them relatively easy. I'll give you a write up if you're interested.
  15. Sep 30, 2022 at 7:34 PM
    Davenos66
    Dave
  16. Sep 30, 2022 at 7:35 PM
    Davenos66
    Dave
    Sure that would be great.
  17. Oct 1, 2022 at 7:33 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I just wrote a whole writeup and it dissapeared when I went to get links. Check out this thread:
    https://www.tundras.com/threads/rear-axle-seals-bearings.39306/
    You'll need a seal puller and, if you're gonna do new wheel bearings and retainers, the Toyota axle tool.
    https://www.amazon.com/K-D-Tools-32...wicXNhIjoiMy44NCIsInFzcCI6IjMuNDYifQ==&sr=8-6
    https://www.amazon.com/NIXFACE-Bear...mzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
    There's some good links in that thread if my incoherent rambling doesn't make sense.
