4.9k stealership estimate
Discussion in '1st Gen Tundras (2000-2006)' started by bassman417, Dec 5, 2020.
Do you trust your local Stealership Shop
  1. Yes and worth the price too.
  2. Yes, but too expensive
  3. No, they cant be trusted
Results are only viewable after voting.
  1. Dec 6, 2020 at 6:27 PM
    #61
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
  2. Dec 6, 2020 at 6:47 PM
    #62
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    I used to work at a local dealer long time ago.
    I'll never take anything I own to a dealership ever.
  3. Dec 6, 2020 at 7:56 PM
    #63
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Most DIY compressors don't fit these coils properly. They're made for use on car coils, not for heavy truck coils.
    For the average wrenching guy I would take the coilover assembly to a shop and pay them an hours rate to swap shocks.
    For the risky wrenching guy I would do the move where you remove the top nut, jack up the car and remove the lower bolt. It isn't the best way to go but probably safer than those rental compressors.
  4. Dec 6, 2020 at 10:06 PM
    #64
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    That’s why I ended up buying a beefy spring compressor to do mine. Those rentals are WAY to scary and my face is WAY too pretty
  5. Dec 6, 2020 at 10:35 PM
    #65
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    I didnt read everyone’s responses but basically everything can be done relatively easily. Those prices are completely outrageous: If ur decent with tools you can tackle everything in a weekend, or even a day. The only thing thats mildly sketchy is compressing ur springs. But u could remove ur struts and take it to a shop and id bet they would swap it for u for cheap. U could replace the LCA’s and typically come with new bushings installed. I think u can even buy replacement struts with the springs on them for pretty cheap too. Rockauto is ur friend if ur on a budget.
  6. Dec 7, 2020 at 3:17 AM
    #66
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Some Autozone stores have that one as a rental or they can order it in.
  7. Dec 7, 2020 at 6:41 AM
    #67
    To summarize:
    1. That's way too much money to pay for parts or labor.
    2. Most of these are simple unbolt and bolt on new part jobs. Any of the jobs you can do at home will save on shop labor.
    3. If you're not comfortable tackling them yourself, get a friend, or order parts and find a reputable shop to perform the install that will charge much less than the stealership.
    Good luck, let us know how this story plays out.
  8. Dec 7, 2020 at 7:37 AM
    #68
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Threadjack, but have you been happy with that set? It's the same cost as it is to pay a shop and I'd rather have the tool if it works well.
  9. Dec 7, 2020 at 7:56 AM
    #69
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Honestly man call around some reputable mechanics in your area or just straight up give them that list of things, have them confirm if it needs done, then have them give you a quote. That's really all it comes down to
    Glock 40 and bassman417[OP] like this.
  10. Dec 7, 2020 at 8:17 AM
    #70
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    The ignore button works wonders ...
    :thumbsup:
  11. Dec 7, 2020 at 8:42 AM
    #71
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    As everyone else has stated, those prices are crazy high. You could pay for another members roundtrip flight, upgraded parts, new tools, and beer and spend much less and come out of it all with more knowledge, a new friend, new tools, and a truck in better shape.
    Honestly, if you were closer I would say come over and we'll knock it out in a weekend. I think shop around, and try some stuff yourself. You'll be surprised at what you can do yourself with support of everyone on this forum and if you screw up, you can take it to a shop.
    Tundra2 and bassman417[OP] like this.
  12. Dec 7, 2020 at 8:46 AM
    #72
    That is so depressing to hear. Seriously
    Tundra2, Tyman, Darkness and 2 others like this.
  13. Dec 7, 2020 at 9:20 AM
    #73
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    As for the struts, I've done the no compressor method by using a floor jack below the LCA. It's not hard. The only part I had to have help for (solo install) was helping me get the strut in on one side while holding down the LCA (I didn't loosen the cam bolts, next time I would). As others have said, if you're not comfortable with this have a local shop press them. Schedule your appointment and have a lunch/beer break while they're doing it. With their floor press, it's probably a 30 minute job, tops.
    The labor prices are stupid. Do it yourself. Good luck!
  14. Dec 7, 2020 at 11:52 AM
    #74
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Sadly, at least in my region, the bad techs and bad business greatly outweigh us good guys.
    but this is also Chicagoland where every business is corrupt in some way.
  15. Dec 7, 2020 at 11:55 AM
    #75
    The Toyota dealer up north in Colorado Springs is pretty solid. I had no complaints other than needing to drive 30 miles round trip when I lived within 4 miles of a craptastic Toyota dealership.
    empty_lord[QUOTED] likes this.
  16. Dec 7, 2020 at 12:09 PM
    #76
    Canuck07
    Canuck07 New Member
    New Brunswick, Canada
    2008 Sequoia Platinum
    Front 2" Leveling Kit Rear Dobinsons 1.75" lift springs Sitting on 275/65/20
    The prices seem crazy high to me although I find the dealerships are always crazy high. Hop on rockauto and see what their prices are, I just replaced rear LCA and sway bar links on my 2nd gen Sequoia and they were $300 on rock auto while the dealership wanted over $3000 and that was just parts. I had a 05 Tundra Quad Cab Limited before and all my parts experiences were the same from the dealer to rock auto.
    bassman417[OP] likes this.
  17. Dec 7, 2020 at 3:29 PM
    #77
    Professional Hand Model
    Hand Protectors
    You have a better angle on your Transmission Mount? Empty Lord had a look at mine and said it looked fine. Here is the pic of it will 170k miles.
  18. Dec 8, 2020 at 7:36 AM
    #78
    bassman417
    bassman417 [OP] "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    @empty_lord
  19. Dec 8, 2020 at 8:57 AM
    #79
    empty_lord
    05 rollover special
    Some cracking in the rubber... but it doesn’t look like it’s broke
  20. Dec 8, 2020 at 10:10 AM
    #80
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Agreed... I wouldn't bother with it, unless the rubber was severely cracked and you felt lots of vibration when putting it into reverse.
  21. Dec 8, 2020 at 10:49 AM
    #81
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    See this is why I come to this forum all the time, the helpfulness of everyone on here is amazing. Kudos to all on here that help out the inexperienced man like myself with the guidance and direction.
  22. Dec 8, 2020 at 10:52 AM
    #82
    bassman417
    Paul
    Las Vegas
    According to the experts, it was "collapsed"?
  23. Dec 8, 2020 at 10:57 AM
    #83
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    methinks they want your wallet to be collapsed. ;)
    betotundra, CodyP, vegas4x4 and 8 others like this.
  24. Dec 8, 2020 at 12:30 PM
    #84
    empty_lord
    05 rollover special
    Nope. It’s a big chunk of rubber, if the rubber breaks or cracks badly it’s shot. When a trans mount is bad you’d know it when shifting and and out of reverse and stomping on the gas.
  25. Dec 8, 2020 at 1:28 PM
    #85
    bassman417
    Paul
    Las Vegas
    Thank you Lord, (has new meaning now):):amen:
    Tundra2 and empty_lord[QUOTED] like this.
  26. Dec 8, 2020 at 1:31 PM
    #86
    bassman417
    Paul
    Las Vegas
    Should i reply, and what would be appropriate?Screenshot_20201208-132917_Messages.jpg
  27. Dec 8, 2020 at 1:33 PM
    #87
    Hand Protectors
    Interesting in the difference between the 2wd and 4wd mounts designs.
    Tundra2 likes this.
  28. Dec 8, 2020 at 1:35 PM
    #88
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Reply: STOP
    CodyP and Glock 40 like this.
  29. Dec 8, 2020 at 2:49 PM
    #89
    empty_lord
    05 rollover special
    It’s automated. Just text stop
    Tundra2 likes this.
  30. Dec 8, 2020 at 3:15 PM
    #90
    bassman417
    Paul
    Las Vegas
    Yeah stop trying to rip me off......
    Stuck in the '00s and Tundra2 like this.
