4.88 or 5.29
Discussion in 'Performance and Tuning' started by turboser91, Jan 30, 2019.
  1. Jan 30, 2019 at 7:46 PM
    turboser91
    turboser91 [OP] New Member
    Fresno
    06 DC 4x4
    6" RCD lift
    I've been researching and can't decide which one to go with. I want to run a 37" tire if I can fit it but the smallest would be a 35". I know a couple of guys here run 4.88 but will 5.29 be a over kill?
    TRDGen likes this.
  2. Jan 30, 2019 at 7:56 PM
    Mnorris1206
    08 tundra
    I have been running 35s for 2 yrs with pulling a camper no problem a little bit of power loss up hills but thats it. I think with 37s 4.88 would be plenty .
    Sunnier and Rica25 like this.
  3. Jan 30, 2019 at 8:03 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm running one of the first sets of 5.29s, not sure how available these are yet.
    I find 'em a little low for 35s unless towing but expect they'll be perfect with 37s.
    Jsena, Joe Dirt, jc153 and 7 others like this.
  4. Jan 30, 2019 at 8:06 PM
    5.29’s will put you back closer to stock gearing/tire size feel. Since you have a 1st gen, you are not rocking the 5.7L.
    Rica25, HappyGilmore and 831Tun like this.
  5. Jan 30, 2019 at 8:47 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I had 4.88 on 33s. Felt stock. I vote 5.29.
    ZeroAlpha2, Bo-Hunter and 15whtrd like this.
  6. Jan 30, 2019 at 9:00 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Always over gear it with dramatically heavier tires
    JuanTon21 and GNTundra like this.
  7. Jan 30, 2019 at 9:06 PM
    Casper421
    In the woods
    06 DC
    4.88
    chugs, Midway, Joe Dirt and 2 others like this.
  8. Jan 30, 2019 at 9:12 PM
    Only things a gear chart doesn’t calculate for is wind drag and weight. Purely mathematical viewpoint. In reality, much different.
    JuanTon21, chugs, tundra_20 and 6 others like this.
  9. Jan 30, 2019 at 9:45 PM
    15whtrd
    15whtrd Mr. Blonde
    Im curious if you gain a few mpgs.
    831Tun[QUOTED] and ColoradoTJ like this.
  10. Jan 30, 2019 at 9:51 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So far it seems to be having the opposite effect but it's too soon to draw any conclusions. I feel very certain it will do far better towing on the highway, around town driving...:notsure:
    joonbug, GodlessPro and 15whtrd like this.
  11. Jan 30, 2019 at 10:13 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I have a first gen with 35's and 4.88's and it is perfect. If you are regearing and you don't have a locker or LSD, that's the time to put one on.
  12. Jan 31, 2019 at 2:15 AM
    Sunnier
    Sunny
    San Diego, CA
    Haha! His question was, for 35's, should he get 4.88 or 5.29? And your answer is 'yes'. LOL!!
    a_double, JuanTon21, alb1k and 10 others like this.
  13. Jan 31, 2019 at 3:54 PM
    turboser91
    Fresno
    06 DC 4x4
    6" RCD lift
    thanks for everyone's input. I'm going to try 37's this weekend and if it fits I'll be getting 5.29. Pretty sure it will fit with minor trimming.
    Jsena, OR18TRD and Sunnier like this.
  14. Jan 31, 2019 at 4:15 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    To get this straight I am running 275 70 R18 tires which is 33.2" tires. I'm I losing power and performance with stock 4.30 gear ratio? When I look at the chart I see more power with 4:88 but much worse fuel consumption, that seem right? Seems like I would need to step up to 35" to make a gear change to 4:88 worth it.
  15. Jan 31, 2019 at 4:25 PM
    15whtrd
    15whtrd Mr. Blonde
    Your stock gears are 4.30s
    OR18TRD likes this.
  16. Jan 31, 2019 at 4:29 PM
    Mnorris1206
    08 tundra
    You have the 5.7 ?
  17. Jan 31, 2019 at 4:32 PM
    alpinepro4
    Pat
    Yes
    Mnorris1206[QUOTED] likes this.
  18. Jan 31, 2019 at 4:35 PM
    Mnorris1206
    08 tundra
    I really don't have a huge power lose with my truck on 35s. Not enough to gear I don't think. I mean I can burn the tires of the thing any time .I do when pulling the camper but thats to be expected.
  19. Jan 31, 2019 at 4:57 PM
    Professional Hand Model
    Hand Protectors
    Somemedic, TRDGen, chugs and 2 others like this.
  20. Jan 31, 2019 at 4:59 PM
    alpinepro4
    Pat
    33 is best overall performance. Sounds like 4:30 right on for 32-33’s according to the graph.
    OR18TRD and 15whtrd like this.
  21. Jan 31, 2019 at 5:03 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I'm planning on 34.6 falkens but I am also going to regear to 5.29 since I tow a lot.
  22. Jan 31, 2019 at 5:04 PM
    Mnorris1206
    08 tundra
    I see now .I guess if its a daily I would defiantly gear mine also but I don't drive it but maybe 25 miles a week. And when pulling a camper its mainly high way driving . o thanks for the graph !
  23. Jan 31, 2019 at 5:09 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I'm still running the 4.30's on my 35's and have no plans to change them. It runs exactly how I want it to right now. However, when everything is all said and done and the truck is a helluva lot heavier, I may jump up to 4.88's.
    5.7TRDProm and 15whtrd like this.
  24. Jan 31, 2019 at 5:29 PM
    Mnorris1206
    08 tundra
    What brand of gears does everyone use ? Looking on eBay just for price.
  25. Jan 31, 2019 at 5:47 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I have nitro 5.29’s
    831Tun and Mnorris1206[QUOTED] like this.
  26. Jan 31, 2019 at 6:06 PM
    HappyGilmore
    Trent
    Lakewood CA
    G2 has always been good for me. They shim up nice, and have a good wear pattern.
    Mnorris1206 likes this.
  27. Jan 31, 2019 at 6:18 PM
    Nitro and Yukon is what I use on the Jeeps, drag cars were motive or US gear.
    Darkness and Mnorris1206 like this.
  28. Jan 31, 2019 at 6:30 PM
    Mnorris1206
    08 tundra
    I just wonder what problems I may have in the future if I never gear my truck. With 35s on it .
    ColoradoTJ likes this.
  29. Jan 31, 2019 at 6:32 PM
    Sas
    OKC, OK
    Shouldn't have any.
  30. Jan 31, 2019 at 6:40 PM
    Added Drivetrain stress, especially on transmission/transfer case (when in use).
