4.88 gears for 295/70/18?
Discussion in 'Performance and Tuning' started by yoneytan, Jun 4, 2018.
  1. Jun 5, 2018 at 6:06 PM
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    I have a Hypertech Speedo Calibrator coming.
    Skid Plates are in my garage.
    Suspension will be here Friday.
    35s are on the truck already.
    ECGS is my next call. I'm hoping on the Tundra they'll do the exchanges same as they do on the Taco. I'm seriously considering buying ARB lockers front and rear with the 4.88 gears.
  2. Jun 5, 2018 at 6:19 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I'm running 4.88's on my 2003. I have 315 70 r17. I feel like it drives pretty close to the way it did before the big tires. Regearing is also a grate excuse to put in a locker too.
  3. Jun 5, 2018 at 6:20 PM
    Lars
    Lars
    Cedar Creek Texas
    now, if only Marlin made a crawl box for the 5.7
  4. Jun 5, 2018 at 6:26 PM
    ZPMAN
    Minnesota
    I installed the hyperteck shortly after installing the 35s , it has corrected my Speedo, one thing i had to deal with was because of the larger tires was if it down shifted for the slightest grade (@70 to 75) and it would not go back into full torque converter lock (highest gear) while using the cruise control. What i did find out that cured that was if moved the shifter over to manual shift and put into 6th then set the cruise , then it would go into full lock after a grade. As for going to 4.88s thats next on my list (have to wait for the wifes eyebrows to go back down after SC) and would be nice for MPGs now that i have to run premium. Keith @dirtydeeds wanted to know about running the hypertec and bully dog together? Speedo seems to be still correct but i believe the BD is off.
  5. Jun 5, 2018 at 8:35 PM
    15whtrd
    15whtrd Mr. Blonde
    1rst or 2nd gen? I plan on going from 275/65/18 to 275/70s 32”-33” am I going to see that much of a drop in mpg in my 3rd GEN?
    831Tun likes this.
  6. Jun 5, 2018 at 9:18 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Nope, doubt you'll even notice the difference.
    15whtrd[QUOTED] likes this.
  7. Jun 5, 2018 at 9:20 PM
    15whtrd
    15whtrd Mr. Blonde
    Sweet. Thanks!
    831Tun[QUOTED] likes this.
  8. Jun 10, 2018 at 3:14 PM
    yoneytan
    yoneytan [OP] New Member
    Asi
    14 CM
    considering the price of gearing is $1100 would it make more sense to get a tune(DAP) for $600 instead? I ask because it seems many advise against 4.88 for 34" tires.
  9. Jun 10, 2018 at 3:36 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Only one way to find out brother! I bet you will notice a difference after you DAP tuned it.
  10. Jun 10, 2018 at 3:53 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I've done both with 295/70/18 STT Pro's. I did the tune first, and I still felt sluggish off the line. The gears help more in that area.
    Watt maker likes this.
  11. Jun 10, 2018 at 4:02 PM
    yoneytan
    Asi
    14 CM
    Can you tell me how the tune changed the shift times? I find the shifting to be super slow.
  12. Jun 10, 2018 at 4:06 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I can't give any hard numbers, but it just holds gears a little longer than the stock tune. You can tell the difference with just normal driving and when you stomp on it. The shifts seem to be "firmer" too. I switched back to the stock tune for a couple days and the shifts seemed noticeably slower/softer. Makes the truck more fun to drive all around.
  13. Jun 11, 2018 at 8:34 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Running 285/70/18 are you on stock suspension and stock wheels? If so did you have any rubbing with that size?
  14. Jun 13, 2018 at 7:07 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Hands down the gearing is the best bang for the buck. And makes the most difference.
  15. Aug 25, 2018 at 4:44 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I got the calibrator aswell. But what about tuning for gear ratio? can we do that with the recal too?
    dirtydeeds likes this.
  16. Aug 25, 2018 at 6:16 AM
    Rica25
    Ricardo
    Tulare
    I have same problem now with size tire si thinking about re gearing also
  17. Aug 25, 2018 at 9:02 AM
    dirtydeeds
    Keith
    USA
    He’s you can. You have to either change settings trial and error, or try to do the calculations in the instructions. Or a little of both.
  18. Aug 25, 2018 at 9:02 AM
    dirtydeeds
    Keith
    USA
    Gimme a holler. I’ll hook it up.
  19. Aug 25, 2018 at 1:58 PM
    #49
    Lars
    Lars
    Cedar Creek Texas
    The version of the Hypertech software I have asks what the stock gear ratio was, and what the new ratio is. Same with Tire Size corrections. You need to do both at the same time when you flash the calibrator.
    Tracker[QUOTED] likes this.
