4.7 timing belt
Discussion in '1st Gen Tundras (2000-2006)' started by sidewinder81, Jun 20, 2017.
  1. Mar 25, 2021 at 11:41 PM
    #241
    Shoei1
    Shoei1 New Member
    When going through rock auto I didn't see the Aisin(which is what I would agree is best). This is the thought I had as well. But it just has such low miles I didnt really know if it was needed.
  2. Mar 25, 2021 at 11:50 PM
    #242
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    assassin10000 likes this.
  3. Mar 25, 2021 at 11:51 PM
    #243
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Timing belts have both a mileage OR time replacement schedule. If either passes, it's best to replace it.
    empty_lord likes this.
  4. Mar 25, 2021 at 11:51 PM
    #244
    empty_lord
    05 rollover special
  5. Mar 26, 2021 at 1:25 PM
    #245
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    agreed! I did my belt around 65k due to age...
  6. Aug 5, 2021 at 9:20 AM
    #246
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    Working on PM's this morning. Got a chance to inspect my timing belt....
    I'm gonna park it.
  7. Aug 5, 2021 at 9:23 AM
    #247
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    You’re a lucky feller.
  8. Aug 5, 2021 at 9:23 AM
    #248
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Prophetic on your part.
    How many miles on this truck?
    N84434 likes this.
  9. Aug 5, 2021 at 9:26 AM
    #249
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Do we have a record on here for oldest OE timing belt?
    Sirfive likes this.
  10. Aug 5, 2021 at 10:00 AM
    #250
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    I have the aisin kit and thermostat and rubber ring gasket on order. Is there a paper thermostat flange gasket also?
  11. Aug 5, 2021 at 12:28 PM
    #251
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    07 Tundie and BubbaW like this.
  12. Aug 5, 2021 at 1:16 PM
    #252
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Wow! that’s one of the worse I’ve seen. Good save!
    GIN•OKUMA likes this.
  13. Aug 5, 2021 at 1:20 PM
    #253
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Gasket material is always worth having around. Get the thickness you need, and double thick just in case. Templating isnt hard, and you can make punches by grinding an edge on the right size or slightly smaller pipes.
  14. Aug 5, 2021 at 4:43 PM
    #254
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    No, the o-ring around the thermostat is all that seals it. No gasket required.
    mbreed2[QUOTED] likes this.
  15. Aug 5, 2021 at 8:57 PM
    #255
    empty_lord
    05 rollover special
    i replaced one with 300k on it that looked better than yours (and yes. it was indeed the original. i personally knew the owner.)
  16. Aug 5, 2021 at 9:16 PM
    #256
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Wow, maybe it's age that's making mine look worse.
  17. Aug 6, 2021 at 8:34 AM
    #257
    shifty` We call it “riding the gravy train”
    I know I could RTFM to get this info, but if anyone has it on the tip of their brain, what is the age part? Mine was replaced about 20k miles ago (@50k-ish miles), near its 10yr anniversary.
  18. Aug 6, 2021 at 8:49 AM
    #258
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    shifty`[QUOTED] likes this.
  19. Aug 6, 2021 at 10:26 AM
    #259
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Interesting . . . I'd heard that before as well.
    When I bought my 2006 DC last November, it only had around 56K miles on it, but he just had the timing belt replaced before I bought it.
    Good info, thanks.
  20. Aug 6, 2021 at 10:27 AM
    #260
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I'm coming up on 90k mi on the second timing belt and have been feeling a little anxious. I'm feeling much better now. May I'll even put it off until next year.
  21. Aug 6, 2021 at 7:32 PM
    #261
    Heavyopp
    Heavyopp New Member
    2000 V8 Tundra AC
    I just pulled my timing belt this week — 2000 tundra v8 — 70,000 miles — 2nd owner
    original owner is a friend and had all service receipts — no evidence of it ever being done, toyota had no record of it either
    old belt looks new, if it still had the paint markings you would not be able to tell old from new
    I did however have some red crystalized substance just above and below the stationary idler pulley — evidence of a water pump leak — luckily I had planned to change that as well
  22. Aug 6, 2021 at 8:45 PM
    #262
    05tundra916
    05tundra916 New Member
    2005 Toyota Tundra Double Cab
    Run a car fax report on the vin and it should show you the service records.
  23. Aug 7, 2021 at 10:20 AM
    #263
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    I got the belt ready to come off. I had to bump the starter to get the crank bolt off. My Snap-On impact didn't fit. Worked like a charm though.
    I see I should replace my crank seal so I'm gonna order that. Hopefully Toyota has it in stock. Lastly, this....
    Anyone else have what looks to be a bent crank sensor?
    Thinking I can leave well enough alone. It looks like it is easily serviceable if it goes bad.
  24. Aug 7, 2021 at 10:25 AM
    #264
    Desert Dog
    I've never seen the sensor on mine yet but as you noted it's easily replaced if necessary. If it's working I wouldn't bother with it. However, I would replace the cam front seals also while you're there. They may not be leaking but you're there. Far less costly to do it now.
    Edit: Wait a minute. I just noticed a mark running down the center of the sensor. Any idea what it's from?
  25. Aug 7, 2021 at 11:16 AM
    #265
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Probably dirt being slung off the inductor ring or belt material being slung. I would at least loosen the 2 bolts holding the crank sensor in place and clean all the debris out, and see if you can reposition it at all.
    @mbreed2 keep up the fine work!
    Desert Dog[QUOTED] and mbreed2 like this.
  26. Aug 7, 2021 at 2:16 PM
    #266
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Did any of you get your seals aftermarket? Wondering if I should put an order in on Amazon now or check local parts stores or wait until Monday and check with dealer.
  27. Aug 7, 2021 at 3:48 PM
    #267
    Desert Dog
    Agreed.
    I'd strongly encourage you to go with OEM.
  28. Aug 7, 2021 at 3:50 PM
    #268
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    :eek:
  29. Aug 7, 2021 at 3:54 PM
    #269
    GIN•OKUMA
    Fish
    26.57°
    Environment has a big effect on rubber. Extreme Heat/cold, humidity etc.
  30. Aug 7, 2021 at 4:03 PM
    #270
    Heavyopp
    Heavyopp New Member
    2000 V8 Tundra AC
    I don’t have a picture but my sensor isn’t centered in the hole either — I’m too far into re-assembly to get a pic
