4.7 timing belt
Discussion in '1st Gen Tundras (2000-2006)' started by sidewinder81, Jun 20, 2017.
  1. Aug 1, 2020 at 7:01 PM
    #211
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I remember someone else having this problem possibly @FirstGenVol
  2. Aug 2, 2020 at 6:17 AM
    #212
    Professional Hand Model
    Hand Protectors
    Are you saying Toyota replaced the 4” with the 3.5” Pulley?
    I believe there is a TSB on the tensioner causing a squeal in cooler temps and Toyota changed the tensioner and recco’d the new tensioner be replaced along with an A/C Compressor Bracket. Maybe the bracket makes up for the smaller 3.5” Pulley?
  3. Aug 2, 2020 at 6:20 AM
    #213
    Hand Protectors
  4. Aug 2, 2020 at 6:42 AM
    #214
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    If he's talking about the serpentine tensioner and not the timing belt tensioner it wasn't me but a buddy's GX470.
    My buddy ended up just replacing the bearing rather than the entire tensioner. I think his dad had one just laying around that worked. I have no idea part number the bearing is unfortunately.
    Edit- he just text me back and said they pressed the old bearing out and went to a shop that sells them and had them find a match. Pressed the new one in.
    Festerw[QUOTED] likes this.
  5. Aug 4, 2020 at 5:37 PM
    #215
    Hand Protectors
  6. Aug 4, 2020 at 7:28 PM
    #216
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yea it was something like that. Never actually done the TSB nor do I know anyone that did. But supposedly the brackets different for the new style tensioner
  7. Aug 5, 2020 at 3:31 AM
    #217
    Jamie6279
    Jamie6279 New Member
    Jamie
    2003 Tundra
    I just had mine replaced about 3 weeks ago right after purchasing it. It had 213k on it and no record if it were ever changed. Belt, H2O pump, main seal, and drive belt done at Camelback Toyota Phx, AZ was $979 out the door.
  8. Aug 5, 2020 at 11:42 AM
    #218
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    Welcome from Gilbert!
    Jamie6279[QUOTED] likes this.
  9. Aug 5, 2020 at 11:59 AM
    #219
    brobert225
    brobert225 Firm grasp of the obvious
    I am at 230 and probably overdue slightly for my 3rd belt. I am not too worried about it. Still on original water pump and may change this time. Curious if I can get another 10 yrs out of it. 20 and counting...
  10. Aug 17, 2020 at 7:28 AM
    #220
    Yoda123
    Yoda123 New Member
    New on this forum I have an 03 4.7L. 460kms. Timing belt was done at 320 and it just went/ or something caused it to go. Just wondering. What are the chances that the engine is now pooched?
  11. Aug 17, 2020 at 7:50 AM
    #221
    There's an excellent chance that internal damage was done to the pistons and valve train. Did you change the belt yourself or have a shop do it? I would think you would have some recourse against a shop or manufacturer if it failed within a certain amount of mileage or KM. You are well within the recommended change interval of 90k miles or 144kms. A tensioner is the most likely cause if it slipped time. Did the belt break?
  12. Aug 17, 2020 at 8:27 AM
    #222
    sixteen2nd
    sixteen2nd Shadetree Mechanic
    2003 White Tundra Access Cab TRD
    2003 means no VVTI right, doesn't that make timing belt failure a bit less catastrophic?
  13. Aug 17, 2020 at 9:21 AM
    #223
    Yoda123
    Yoda123 New Member
    Ya belt broke. Took one of the covers off and I can’t see the belt so it probably piled up somewhere
  14. Aug 17, 2020 at 9:33 AM
    #224
    Festerw
    Festerw New Member
    04 Tundra DC
    The few I've read about that broke, if it was at start up or idle you might be lucky and didn't have any damage. If it was driving down the road chances are higher something else is damaged.
    4 options as I see it.
    1. Quick and dirty way would be to grab a cheap borescope from Amazon and pull the plugs to get a look at the pistons/valves with it.
    2. Throw a new timing belt on it and hope for the best.
    3. Pull the heads and inspect.
    4. Pull the engine and put in a lower mileage junkyard or rebuilt.
  15. Aug 17, 2020 at 9:49 AM
    #225
    4.7 V-8 is an interference engine. If your timing belt broke, you'd have to be darn lucky not to bend a valve at the very least. Pulling the heads to inspect would be highly recommended. An engine could continue to function with damage to the valves, especially a V-8, plenty of extra cylinders to keep things going. The side effects however would be highly undesirable. Cylinder compression has to go somewhere, right out the non-sealing valve. Chances are the damage would be severe enough to not allow motor function. Broken pieces inside the cylinder, valve bent into the stuck open position causing continued contact with the cylinder etc. As I like to tell the people that work on my team, hope is a terrible strategy.
  16. Aug 17, 2020 at 11:41 AM
    #226
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Original water pump?
  17. Aug 17, 2020 at 12:33 PM
    #227
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    In the few years I've been around here we've actually seen a few members have a belt break and it not do damage. :notsure:
    bmf4069 and Casper421 like this.
  18. Aug 17, 2020 at 12:42 PM
    #228
    Casper421
    In the woods
    06 DC
    Same. Here, t4.org and in person. Interference vs non interference is always a fun topic.
  19. Aug 17, 2020 at 1:09 PM
    #229
    Yoda123
    Yoda123 New Member
    Thanks for the input. Looks like she’s now a parts truck.
  20. Aug 17, 2020 at 1:13 PM
    #230
    ezdog
    ezdog New Member
    Gateway To The West
    I feel your pain.
    I lost a VVT 4Runner like this when a newish belt broke and rendered mine a parts truck too.
    Luckily 4Runners are so crazy in demand that I really didn't turn out losing as bad as I thought?
  21. Aug 17, 2020 at 2:33 PM
    #231
    Hand Protectors
    And why did your newish belt break?
  22. Aug 17, 2020 at 2:53 PM
    #232
    ezdog
    ezdog New Member
    Gateway To The West
    Some moron installed it badly.
  23. Aug 17, 2020 at 2:54 PM
    #233
    Hand Protectors
    Ugh. I hope I don’t mangle mine. :rofl:
    bmf4069 likes this.
  24. Aug 17, 2020 at 2:55 PM
    #234
    ezdog
    ezdog New Member
    Gateway To The West
    I dont mean me either,some other moron did mine!
  25. Aug 17, 2020 at 2:59 PM
    #235
    Hand Protectors
    The water pump stalactites was why I did my TB.
    Speaking of which, Toy offers two water pumps as parts replacement. One made in Japan and the other Made in USA (comes with the gasket). I’ve selected the USA one in my cart when I do the TB.
    revtune[QUOTED] likes this.
  26. Aug 18, 2020 at 11:02 AM
    #236
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Need help? :wave:
  27. Jan 10, 2021 at 2:42 PM
    #237
    coveredinlube
    coveredinlube New Member
    sam
    2003 Toyota Sequoia SR5
    Recently traded the parents for a 2003 sequoia. 188k miles and still on the stock timing belt. Probably going to change it next week
    N84434 likes this.
  28. Jan 10, 2021 at 2:50 PM
    #238
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Welcome to the club!
    coveredinlube[QUOTED] likes this.
  29. Mar 25, 2021 at 10:27 PM
    #239
    Shoei1
    Shoei1 New Member
    Hey all,
    I have a 2003 Toyota Tundra SR5 Limited(I believe with the tow package) with about 70k miles. My grand parents really only used it to tow their 2 horse hauler(they had mini horses) and hay once in awhile. I believe pretty much all is stock and I plan on doing a over haul before I start hauling(pulling small travel trailer no more than gvrw7k) with it. When I got it 3yrs ago I did a full fluid flush(everything!) and brake pads and serpentine belt and that was at about 60k.
    So should I do a timing belt kit with my overhaul? Anything else I may be forgetting?
    Currently in my cart for parts for over haul.
    Radiator Hose upper and lower
    Trans. Oil cooler (shows sign of past leak)
    Thermostat and seal
    Ball joints upper and lower
    Shocks and struts with hopefully a leveling kit.
  30. Mar 25, 2021 at 11:26 PM
    #240
    empty_lord
    05 rollover special
    if the belt has not been done, being its an 05 that belt would be 16 years old now. it is likely drying out and i would indeed do the belt + water pump. BUY OEM or AISIN, from a REPUTABLE source. cheaping out on the t-belt can be a costly mistake. Rockauto sells the full AISIN t-belt kit i believe, this comes with all the same stuff the factory toyota stuff is
