4.7 timing belt
Discussion in '1st Gen Tundras (2000-2006)' started by sidewinder81, Jun 20, 2017.
  1. Apr 20, 2020 at 6:16 PM
    #181
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Right. I gave the impact a few taps on the switch and the bolt gave up it's grip. Then I laid on the impact for a few seconds to tighten it when it was time to put it together because I didn't have a torque wrench with that much range.
    41bigdawg[QUOTED] likes this.
  2. Apr 20, 2020 at 6:30 PM
    #182
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    Did you get her all back together?
  3. Apr 20, 2020 at 8:11 PM
    #183
    Spobrien84
    Spobrien84 New Member
    2006 Tundra limited
    Totally agree there is no need to take an easy risk. I told him he needs to get it done he just keeps saying he keeps forgetting.
  4. Apr 20, 2020 at 9:18 PM
    #184
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    this is the one I use at work, don’t even need to remove the radiator. And unless someone previously overtightened the bolt, it rips it right off.
    Ingersoll Rand 35MAX Ultra-Compact Impactool, 1/2 Inch https://www.amazon.com/dp/B01EN7GEGY/ref=cm_sw_r_cp_api_i_MpNNEbHBNRFQ3
    theBIGnaud likes this.
  5. Apr 22, 2020 at 4:54 PM
    #185
    Northern
    Northern New Member
    I just got an 04 and had my mechanic change the belt and he said the water pump was leaking, so as it didn't get a lot of driving before I got it, I figured seals were old. The mileage was 120K.
    The 05 V8 is next. That has 13K on it, but again, not a lot of driving on it, so belt and pump for the seals. Figure the tensioners, etc. will be OK.
  6. Apr 22, 2020 at 4:59 PM
    #186
    empty_lord
    05 rollover special
    The cam seals on the 05 are going to cost an arm and a leg if they need to be done just a warning. to replace cam seals on a vvti 4.7 you have to remove the valve covers and pull the cams
  7. Apr 22, 2020 at 5:02 PM
    #187
    Northern
    Northern New Member
    OUCH! That's some s*ck*ss engineering. Thanks for the head's up
    bleach likes this.
  8. Apr 22, 2020 at 5:10 PM
    #188
    empty_lord
    05 rollover special
    It’s because of the vvti being added after the engine existed. Chances are yours are fine, but if not be ready. I did mine because they were leaking, but I also have 192k
  9. Apr 23, 2020 at 7:04 AM
    #189
    Northern
    Northern New Member
    Yeah, did a check and vvti came into being in 05 and stuck on an engine already in production. Hopefully mine will be fine as I have better things to spend money on, like a topper, hunting and fishing gear, etc.
    empty_lord likes this.
  10. May 14, 2020 at 3:14 PM
    #190
    TurtleWrench
    TurtleWrench New Member
    Dom
    2013 Sequoia Platinum
    I been looking everywhere , how do you do the cam seals on the 4.7? Mine is a 2000.
    Thanks
  11. May 14, 2020 at 3:49 PM
    #191
    Professional Hand Model
    Hand Protectors
    I have never done a timing belt, nor the cam seals, before. I will possibly attempt these when the time comes in about 30k miles, or 3 years, which ever comes first. Assuming I still have the truck which most likely I will.
    The cam seals look like they should be done while the belt is off. Might as well do it all at the same time.
  12. May 14, 2020 at 4:00 PM
    #192
    ezdog
    ezdog New Member
    Gateway To The West
    When mine hit 90K I asked the lead mechanic at the Toyota Store where I did some other work whether he thought I should get the belt done at the time.
    His answer to me was that after the Apocalypse the only things he thought would be left intact were Cockroaches and the 4.7 liter timing belts.
    He said that as a Master Toyota Tech for 30 years that he had never seen one go bad or break and we talked about it a little and I have still not done mine yet.
    He of course did happily do them all the time and made the store lots of money in the process.
    Now I also bought a V8 4runner a few years ago that had just had the Timing belt done and the motor seized as the result of that.
    Again no mechanic who I talked to about it had ever seen that happen either but the moron who did the work evidently did not clean the whole belt path before putting it all back together and crap got in there and sort of derailed the belt for lack of a better way to describe it.
    So I am not saying which is right and if money were not an object to me I am sure I would just have the job done at 90K or whatever interval is suggested but I also take some comfort in the Toyota Mechanic saying I should really not worry about it too much.
    Better safe than sorry I am sure,if you can afford it at the time.
  13. May 14, 2020 at 4:10 PM
    #193
    Hand Protectors
    I wrote an observation the other day, on another thread about the timing belts, in that I’ve never recalled seeing someone here on this site saying their timing belt broke from being old. Not saying it can’t happen. Plenty of threads complaining about their timing belts failing due to improper fresh installations or poor/off brand parts.
    revtune and ezdog[QUOTED] like this.
  14. May 14, 2020 at 4:30 PM
    #194
    TurtleWrench
    Dom
    yes but I dont see any guides how to do the cam seals or crank shaft seals but I did read if they are not leaking dont worry about it/?
  15. May 14, 2020 at 4:39 PM
    #195
    Hand Protectors
    Mine are leaking slightly at 169k. They will be replaced during the belt change out.
    Edit: I see I had a typo in my original quote that you quoted. I said ‘did’ where I should have said ‘will do’ water pump and cam seals. My leaking ones are the originals still.
  16. May 14, 2020 at 5:14 PM
    #196
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    The aisin kits come with mitsuboshi T belts.
  17. May 14, 2020 at 5:23 PM
    #197
    revtune
    revtune New Member
    Dane
    Houston Texas
  18. May 14, 2020 at 7:07 PM
    #198
    TurtleWrench
    Dom
    how many gallons of coolant did you need? do I order 3 or 4 bottles of 50/50?
    also did you replace cam seals? know a good link to buy them on Amazon?
  19. May 14, 2020 at 7:27 PM
    #199
    revtune
    revtune New Member
    Dane
    Houston Texas
    2-3 bottles of the 50/50 pink zerex should do the job. You can actually go to Walmart or their website and get the valvoline brand.
  20. May 14, 2020 at 7:29 PM
    #200
    revtune
    revtune New Member
    Dane
    Houston Texas
  21. May 15, 2020 at 4:02 AM
    #201
    Hand Protectors
    I prefer to use the pre-mix due to eliminating dumb hand model mixing errors. Its so cheap just to buy Zerex Asian Pink. Think my local auto store was less than wallace wurrld when I did mine. $17isH a gallon IIRC. Need 3 gallons plus .1 gallon per spec. So, just buy 4 gallons and do a flush at your heater core (pro tip) which most overlook. That uses about 1/4 gallon.
    4 gallons of Zerex Pink will do you. Buy a new Denso radiator cap is another pro tip. $14ish on big gurrll.
    revtune likes this.
  22. May 15, 2020 at 5:08 AM
    #202
    revtune
    revtune New Member
    Dane
    Houston Texas
  23. May 15, 2020 at 5:11 AM
    #203
    Hand Protectors
    How much does shipping add? Good price on the gallon! Does shipping kill it?
  24. May 15, 2020 at 5:13 AM
    #204
    revtune
    revtune New Member
    Dane
    Houston Texas
    Local, online or wherever you can get it the cheapest. I also agree with just getting the 50/50 mix. It seems much easier that way.
  25. May 15, 2020 at 5:19 AM
    #205
    revtune
    revtune New Member
    Dane
    Houston Texas
    I do like rock auto but cost wise on liquid type products like this, local is probably a better bet. From also looking on the Tacoma boards and numerous post about it here, this Asian zerex pink mix is a very good substitute for the Toyota stuff. It meets all the requirements.
  26. May 15, 2020 at 5:29 AM
    #206
    Hand Protectors
    Yeah. I checked for all the Toy and Japanese certs and the Zerex Asian meets them.
    revtune[QUOTED] and YardBird like this.
  27. May 15, 2020 at 5:32 AM
    #207
    Hand Protectors
    If the cost saving was hugely, I’d do the concentrate. All those distilled plastík bottles and harming the nozone is a deal breaker. :D
    theBIGnaud[QUOTED] likes this.
  28. May 20, 2020 at 1:44 PM
    #208
    ToyotaJim
    ToyotaJim New Member
    My 4Runner with the same 4.7L was done at 91,000 at the dealership, and cost was about $1000 (a decade ago). They showed me the belt and it looked pristine. But we changed it anyway. I'm now at 200k and will be doing it myself when the weather improves.
    Just bought a 2000 Tundra with 155k miles on the 4.7L. I don't know if it's ever been done, but will be tackling this repair myself too. I'm curious to see how it is. But it drives very strong.
  29. Aug 1, 2020 at 6:28 PM
    #209
    theleeb
    theleeb New Member
    Tom
    Upper Marlboro, MD
    2002 Tundra Access-cab SR5 4x4 4.7L; 2016 Tundra Crew Cab - Limited
    I need to replace the 4" tensioner pulley and also the idler pulley. But they replaced the 4" tensioner pulley with a 3.5" pulley. Problem is that the washer/cover and bolt do not come with the replacement pulley and those original parts won't fit the replacement. So now I'm thinking about just replacing the bearing for the 4" tensioner pulley and the idler pulley. Anyone know of a bearing part number that will work? 2004 Tundra 4.7L SR5
  30. Aug 1, 2020 at 6:55 PM
    #210
    ToyotaJim
    I don't but I have found the Toyota service departments to be extremely helpful when ordering parts - they'll look up the parts and confirm wht you need. They have saved me from some costly wrong part install mistakes.
