4.7 timing belt
Discussion in '1st Gen Tundras (2000-2006)' started by sidewinder81, Jun 20, 2017.
  1. Mar 26, 2020 at 6:35 AM
    #151
    speedtre
    speedtre New Member
    Inland Northwest
    I could see a fleet truck single cab that doesn't haul much in the way of weight, but needs a p/u bed....but yea, outside of that, no thanks....
    bmf4069 and FrenchToasty[QUOTED] like this.
  2. Mar 26, 2020 at 10:51 AM
    #152
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I fixed that for ya. :thumbsup:
  3. Mar 28, 2020 at 7:41 AM
    #153
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    @speedtre fist gens only came with the 4.7l. Thats what i said, i never said 2nd gens didnt come with the 4.7l.. lol
  4. Mar 28, 2020 at 8:00 AM
    #154
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    They also had the 3.4 and 4.0 V6 as well. And you could get those with a 5spd and 6spd manual as well.
    speedtre likes this.
  5. Mar 28, 2020 at 8:10 AM
    #155
    speedtre
    speedtre New Member
    Inland Northwest
    Saved me some typing...:thumbsup:
    bmf4069[QUOTED] likes this.
  6. Apr 3, 2020 at 2:47 AM
    #156
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I'm doing mine now. 227,000 miles. There is no evidence that the belt has ever been changed. my truck had a single owner for most of its life, and all the dealer service records are available...I even called the service manager to check. Nothing! I've been worried about this since I got the truck, however needlessly so. It looks nearly new!
    Well, I'm in there now, so I'll change it out. I have the Aisin kit so I hope I won't have to worry about it for another 200,000 miles.
    Cruiserpilot likes this.
  7. Apr 3, 2020 at 5:25 AM
    #157
    Pucks18
    @w666 wow. Hey i know these belts last a long ass time, but why not just do it every 90-110k just to be safe? These trucks are the last of a dying breed and we need to keep as many of them around as possible. Why risk it
  8. Apr 3, 2020 at 5:28 AM
    #158
    w666
    Maryland
    Because...I bought the truck with 226,000 mi
  9. Apr 3, 2020 at 5:34 AM
    #159
    Pucks18
    @w666 i took " hopefully it lasts another 200k" as hopefully the belt lasts 200k again, instead of just the truck in general, my bad
  10. Apr 3, 2020 at 7:19 AM
    #160
    w666
    Maryland
    Apparently the water pump was already leaking...
  11. Apr 3, 2020 at 7:38 AM
    #161
    speedtre
    speedtre New Member
    Inland Northwest
    Mine looked like that at 84K miles and 13 years...
  12. Apr 6, 2020 at 11:29 PM
    #162
    TurtleWrench
    TurtleWrench New Member
    Dom
    2013 Sequoia Platinum
    So I am thinking of getting this kit Here seems more OEM type parts HERE
    Has anyone installed the cheaper kit like this HERE
    Just trying to save money where I can since it will be replaced in 100k.
    :deadhorse:
    :cheers:
  13. Apr 6, 2020 at 11:39 PM
    #163
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Our parts truck is a 07 4.0 reg cab. 330k on it and it still gets 18-20mpg... crazy with a truck so large.
  14. Apr 6, 2020 at 11:41 PM
    #164
    empty_lord
    05 rollover special
    I would avoid the eBay route at all costs. Unless it’s coming from an toyota dealer. Counterfeit parts are rampant on eBay. You do not want to cheap out on parts because of the belt fails, your replacing the engine.
    Aisin timing belt kits are oem without the Toyota price tag
    TurtleWrench[QUOTED] likes this.
  15. Apr 6, 2020 at 11:43 PM
    #165
    empty_lord
    05 rollover special
    That top kit likely isn’t real OEM the seller is based out of HongKong.
    I believe aircabinman is the trusted eBay oem source
  16. Apr 8, 2020 at 5:10 AM
    #166
    Twest130
    Twest130 New Member
    Travis
    2000 sr5
    I would just use the Aisin Kit. If you do the work yourself you are already saving $800-$1000 in labor. I was very impressed with the parts included when I did mine, they were the same as the parts I pulled off.
    TurtleWrench likes this.
  17. Apr 10, 2020 at 5:31 AM
    #167
    w666
    Maryland
  18. Apr 19, 2020 at 12:16 PM
    #168
    TurtleWrench
    Dom
  19. Apr 19, 2020 at 3:44 PM
    #169
    I used the Aisin kit to do mine. Paid $179 i believe on Amazon. Replacement went great and all the parts were direct replacements. After 15k miles or so, I noticed I have a "whir or whine" that sounds like a tensioner pulley bearing gone bad that wasn't there before. It's possible it could be the water pump included in the kit that i replaced also. The factory hose clamps for the radiator hoses wouldn't reseal the hoses upon replacement. I replaced the radiator that was leaking from a crack by the filler neck and all the hoses at the same time. Definitely need new hose clamps if your replacing those. I'm not sure that my timing belt had ever been replaced before I did it. Bought the truck with 99k miles on it and no definitive service records. Replaced it all at 212k. Zero issues up till then and the belt looked great upon replacement. I would buy the Aisin kit again, I would steer clear of cheap kits. This is a rather involved job that I wouldn't want to repeat because of cheap parts that fail prematurely. I highly recommend having another like minded mechanic or friend assist with the job. Someone needs to laugh at you when you bust your knuckles, open a fresh beer for you when your hands are greasy and celebrate the finished job with you when it miraculously fires up again.
  20. Apr 19, 2020 at 4:07 PM
    #170
    wildduk
    wildduk New Member
    Atlanta
    2006 DC 2WD
    I have a 2006 with the 4.7. Can anyone confirm if this is an interference engine or not. I’ve read conflicting reports. I have 105k miles and am about to pull the trigger on this....
    Thx
  21. Apr 19, 2020 at 4:37 PM
    #171
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It is. Do it
  22. Apr 19, 2020 at 4:57 PM
    #172
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    It is an interference motor for sure...you are living on borrowed time....buy the Aisin Kit and change that belt, water pump and cam seals ASAP.
    Rex Kramer likes this.
  23. Apr 19, 2020 at 5:07 PM
    #173
    wildduk
    wildduk New Member
    Atlanta
    2006 DC 2WD
    Ok. Thx. I’ll get on it.
    41bigdawg likes this.
  24. Apr 19, 2020 at 6:34 PM
    #174
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I found the same issue with mine when I changed the belt a few months ago. I used the Aisin kit plus I bought an OEM thermostat and seal.
  25. Apr 19, 2020 at 10:10 PM
    #175
    Spobrien84
    Spobrien84 New Member
    2006 Tundra limited
    My uncle has 250k on his 04 and never changed the timing belt yet
  26. Apr 20, 2020 at 5:05 AM
    #176
    wildduk
    wildduk New Member
    Atlanta
    2006 DC 2WD
    What seems to be the best way to remove the crankshaft bolt. Probably the only tool I’ll need to buy for this job....
    impact wrench, etc....
  27. Apr 20, 2020 at 8:09 AM
    #177
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Impact off, impact on.
  28. Apr 20, 2020 at 8:43 AM
    #178
    41bigdawg
    Robert
    Tennessee
    2013 Tundra DC 5.7
    This is not an issue of how far you can go with a timing belt! When it fails it is game over, your engine will be completely ruined! I am sure that these belts will last much longer than the recommended replacement time but taking that risk is foolish unless you want to fork over several thousand dollars for a new motor.
  29. Apr 20, 2020 at 10:44 AM
    #179
    wildduk
    wildduk New Member
    Atlanta
    2006 DC 2WD
    Ok thx. So no need to hold crankshaft pulley if using an impact wrench?.
  30. Apr 20, 2020 at 10:56 AM
    #180
    41bigdawg
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Get a good quality impact and you should have no problem with that bolt. No need to hold the crank pulley.
    bleach likes this.
