4.6L towing capabilities
Discussion in 'Towing & Hauling' started by tctundra, Sep 11, 2015.
  1. Sep 11, 2015 at 6:07 PM
    tctundra
    tctundra [OP] New Member
    tony
    2014 metallic grey Tundra
    My tundra is 2014 with 4.6L. Thinking of a travel trailer and was wondering if anyone on the forum has the small block and used it for towing.
    JROCK915 likes this.
  2. Sep 11, 2015 at 7:06 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I think the max rating for your truck is 6800 pounds, unless you have a 4x4. Then it would be lower. Did your truck come with a tow package?
  3. Sep 12, 2015 at 9:49 AM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    My 2011 DC with tow package is rated at 8200 lbs.
    TruckyTruck likes this.
  4. Sep 12, 2015 at 10:14 AM
    TruckyTruck
    Gary
    I think the rating went down in 2014
  5. Sep 12, 2015 at 10:41 AM
    tctundra
    tony
    It came with a tow hitch and it is a 4x4x. I know I would need to put in a transmission cooler. Not sure about a larger capacity oil sump. It was the "work truck Pkg". Wanted the 5.7 but that's a whole pkg. and I couldn't afford a $5k bump up. Ended up losing my job 6 months after I bought the truck. Had to sell my 71' Vette that I bought new. The car only had 44k original miles. It hurt but it was that or loose the Tundra. That wouldn't have been smart.
  6. Sep 12, 2015 at 10:42 AM
    tctundra
    tony
    That's pretty good!
  7. Sep 12, 2015 at 11:23 AM
    TruckyTruck
    Gary
    Bummer man... I probably would have let the tundra roll into a lake first... Ha, jk. Work package huh? I'm not sure what is included with that. Have you checked to see if you have a transmission cooler? Since you are 4x4 I believe the rating is 6500 pounds. One thing to check is what class hitch you have. If they matched the trucks rating, you won't want to get past that 6500 mark. I'm not sure what's changed from previous years to now for the 4.6, but i bet its the standards of how they rate the truck. I would imagine nothing has physically changed from then to now.
  8. Sep 12, 2015 at 11:24 AM
    TruckyTruck
    Gary
    Also, does your truck come with a tow/haul button?
  9. Sep 12, 2015 at 5:22 PM
    JROCK915
    JROCK915 Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    2011 SR5 RWD 4.6! Own a 7x16 twin axle cargo trailer. Towed it from Florida, to California (2300 miles). Never knew it was even back there. I'm rated for 8200lbs. Had the tow button on.
    fyi....bed and trailer were packed to the hilt. 200 lbs worth of Dobermans in the back cab, me & my wife up front
