4.6 needs power
Discussion in '2.5 Gen Tundras (2014-2021)' started by mcclay13, Sep 7, 2019.
  1. Sep 7, 2019 at 2:25 PM
    mcclay13
    mcclay13 [OP] New Member
    Hello all. new to the forum. Got a 4.6 tundra for my son. Now that it's mine again it's really underpowered. Love to keep it but it needs help. Any suggestions?
    MRQZTNDR93 likes this.
  2. Sep 7, 2019 at 2:27 PM
    15whtrd
    15whtrd Mr. Blonde
    Regear! And maybe a pedal commander to make it feel more snappy
    Kerch71 and Trooper2 like this.
  3. Sep 7, 2019 at 2:29 PM
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    cold air intake,flowmaster exhaust and pedal commander is what i did and im pretty satisfy with it for what i use it
    Trooper2 likes this.
  4. Sep 9, 2019 at 12:11 PM
    awlafleur
    awlafleur New Member
    2016 Black SR5 Tundra
    Leveling spacer in front
    Which cold air intake did you install for the 4.6?
  5. Sep 10, 2019 at 10:58 AM
    MRQZTNDR93
    San Diego CA
    Airaid cold air intake i bought it off REALtuck .com
  6. Sep 10, 2019 at 11:15 AM
    The Tundra already has a cold air intake from the factory. Do the SABM with a K&N or AFE dry drop in filter. +1 on the Pedal Commander. It is a day and night difference with it.
    awlafleur likes this.
  7. Sep 10, 2019 at 11:19 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    I've heard a lot of good things with pedal commander.
    Need to eventually do that myself.
  8. Sep 10, 2019 at 11:31 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Tundra has a CAI stock. Many seem to think changing out nets very little if any gains. They do claim some sound improvements for what that is worth. The SABM makes more sense, gets more air to the in take.
    Tundra234 likes this.
  9. Sep 10, 2019 at 11:33 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I had a 4.6 before. I installed an air aid intake, very very loud. Only made power above 4k rpm, which you never drive in. Waste of money
    The 5.7 and 4.6 use the same stock intake. If it is good enough for the 5.7, it flows plenty of air for a smaller engine.
    The 4.6 is great, regear to 4.88 and it will drive much better
  10. Sep 10, 2019 at 12:08 PM
    What does the regear actually help with? I'm not too familiar with a 4.88 setup. I have the 4.6 with 285/70/18's and a Pedal Commander.
  11. Sep 10, 2019 at 12:19 PM
    Trooper2
    JR
    Most that regear do so with larger diameter tires. 35's and up. Increase in tire size changes the ratios designed with transmission, gears, and stock tires. Larger tires hurt the low end, take off, can make truck feel sluggish. Regearing helps with that.
  12. Sep 10, 2019 at 12:21 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The regear allows the motor to spool up more. I felt like the 4.6 was horrifically undergeared from the factory. It needs 4.56 stock, not 4.10. Thats why i traded the truck in, i just hated how it drove with the gearing. Stupid me, they came out with 4.88 gears for it two years later, i wish i would have just kept the truck!!! I liked the 4.6 alot.
    You REALLY want 4.88’s with those taller tires. It will feel like a new truck
  13. Sep 10, 2019 at 3:13 PM
    Gotcha. So you recommend the 4.88's with my 285/70/18's (34's) to go along with my PC?
  14. Sep 10, 2019 at 3:33 PM
    Trooper2
    JR
    I would research this a bit. 4.10 may be all you need.
    @dirtydeeds may have some good input. An exhaust may help as well.
  15. Sep 10, 2019 at 3:39 PM
    Thanks for the info. I'll kit Keith up at some point. I have an exhaust already so I'm good there. I'm still trying to figure out what CO's I want to go with to replace the ReadyLift 3/2 kit. Looking at the Toytec Boss kit and shackles.
  16. Sep 10, 2019 at 3:42 PM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Sell it and get a 5.7?
  17. Sep 10, 2019 at 3:56 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There have been some long gear change threads lately.
    I think you would love it. Remember 4.6 trucks have 4.10 gears not 4.30. So you would benefit even more than 5.7 guys are. Im doing 4.88 with 295/70 tires as soon as my current tires burn out
  18. Sep 10, 2019 at 4:09 PM
    MGM2018OR
    MGM2018OR New Member
    Craig
    2018 MGM OR dbl cab ( gone but not forgotten )
    I went build a 2019 and the 4.6 shows 3.91 rear axle..
  19. Sep 10, 2019 at 6:33 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Omg they changed it again? Uhhg the wrong direction too
  20. Sep 10, 2019 at 6:52 PM
    I think it depends on if the truck has the towing package or not. Mine has the tow pkg with the 4.10's.
  21. Sep 10, 2019 at 6:55 PM
    Sounds like you need the five point seven modification.
    Willy224 and Crunch527 like this.
  22. Sep 13, 2019 at 5:13 AM
    awlafleur
    What is SABM?
  23. Sep 13, 2019 at 5:19 AM
    15whtrd and awlafleur[QUOTED] like this.
  24. Sep 13, 2019 at 5:21 AM
    awlafleur
  25. Sep 13, 2019 at 5:25 AM
    No problem. I have had mine for about 7 years. They run about $85.00 I don't remember where I bought mine but someone here will know who sells them currently.
  26. Sep 13, 2019 at 6:19 AM
    Trooper2
    JR
    You can Google it and get several options and videos.
    Some have made their own kit for like $20, PVC parts from hardware store.
  27. Sep 13, 2019 at 7:04 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Trooper2 and Rica25 like this.
  28. Sep 13, 2019 at 7:11 AM
    Rica25
    Ricardo
    Tulare
    Yes I did
  29. Sep 13, 2019 at 7:11 AM
    Rica25
    Ricardo
    Tulare
    Yes for about 15 bucks
  30. Sep 13, 2019 at 8:34 AM
    Rica25
    Ricardo
    Tulare
