3rd gen wheels on 1st gen
Discussion in '1st Gen Tundras (2000-2006)' started by Gta3214, Jun 9, 2022.
  1. Nov 7, 2022 at 7:36 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You need to covert the hub size and convert the lug stud size from I believe m12 to m14. OP said $500 for the spacers alone and a bad experience. May want to reach out to Bora and see if they can help you.
  2. Nov 7, 2022 at 7:40 PM
    shifty` Countin' and breathin', disappearin' in the fade
    Someone posted a link around here somewhere to a place that will custom-cut (lathe off) any adapter you need. But hell if I can find it...
  3. Nov 8, 2022 at 5:43 AM
    Tundradownunder
    Tundradownunder New Member
    N CA
    05 Tundra 4x4 SR5
    @brajTaco
    I ordered custom spacers from USWheel adapter using the specs above. As mentioned, converting from m12 106 to m14 95.1. I’ve been told Bora performs the same service, possibly with better customer service. The only other key item is OEM lugs from a ‘22. I used (x5 for 6 lug) PT076-0C200-02 (black) for about $100. There are cheaper options for lugs and spacers if you find a local speed/machine shop and aftermarket lugs.
  4. Nov 8, 2022 at 5:51 AM
    Tundradownunder
    N CA
    05 Tundra 4x4 SR5
    also depending on the overall diameter of your wheels you may want a leveling kit. Mine are ~32-33" overall w20" rims. Yours may not have clearance issues.
  5. Nov 8, 2022 at 11:08 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I guess this is for future reference, 4Runner and Tacoma takeoffs fit with no modifications and are pretty plentiful at dealerships and craigslist. I see them all the time for $500-$800 with less than 50 miles on them.
  6. Nov 8, 2022 at 11:15 AM
    Offset isn’t the same, people will experience less “poke” with 4Runner and Tacoma take offs. May get UCA rubbing with some wider tire choices. Many have needed spacers to run these with popular tire sizes.
  7. Nov 8, 2022 at 2:43 PM
    Richid
    Richid New Member
    I use this: Same offset and bolt pattern are old trucks, 4runners, and FJ. Tons of people unloading their 4runner wheels for the new TRD ones - they do look cool and the dealers actually sell them relatively cheap. I got my whole set, with tires (< 5k miles) for $550. Well worth it.
    FJ wheels are ugly but I may get one as a spare.
  8. Nov 8, 2022 at 2:44 PM
    rock climber
    I thought it was the other way around where the new wheels have positive offset meaning they are sucked in?
    FrenchToasty likes this.
  9. Nov 8, 2022 at 4:09 PM
    aren’t we saying the same thing? :monocle:
  10. Nov 9, 2022 at 9:34 AM
    rock climber
    I'm pretty sure most 4runner and Tacoma wheels are between 15 and 25 offset, the 3rd gen tundra wheels are 60 offset. Most first gen wheels are 15 so the 4runner and Tacoma wheels are stock or very close to stock and won't need spacers 3rd gen wheels will be sucked in a lot and need spacers/adapters.
  11. Nov 11, 2022 at 2:08 PM
    brajTaco
    brajTaco New Member
    Spencer
    2001 Tundra 4x4 Sr5 TRD
    Toyota factory Frame Rust package
    Yall are awesome thank you very much. I'll probably go the route that OP did as I can't find anyone who will be buying these 95.1s from the 3rd gen '22 Tundra. They really screwed those of us trying to get a deal on takeoffs.
    Thanks again fam
  12. May 30, 2023 at 11:47 PM
    101gearhead
    101gearhead New Member
    Cesar
    2004 Tundra crew cab limited
    Zero
    Well late May 2023 and just ran in to the same problem. Thank you all for sharing the wealth of knowledge and info. Just one thing who is Bora and how can I contact them. To get this problem situated and over with.
  13. May 30, 2023 at 11:49 PM
    NickB_01TRD
    Nick
    KY
    Bora is a company that makes quality spacers (among other things I assume). Looks like this is the company that makes them.
    https://www.motorsport-tech.com/lan...eel Spacers,Lifetime Warranty in the industry.
  14. May 31, 2023 at 12:01 AM
    101gearhead
    Cesar
    Zero
    Thank you NickB_01TRD.
  15. May 31, 2023 at 5:52 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    Correct me if I am wrong, but if I had a m14 lug nut and wanted to use it on a M12 stud, would some kind of heli-coil work to fill in the gap on the m14 lug nut.
  16. May 31, 2023 at 6:29 AM
    Let’s say it does. You gonna bolt those wheels up to your truck and load up the fam on 24 helicoiled lugs? Seems sketchy to me.
  17. May 31, 2023 at 7:17 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
  18. May 31, 2023 at 8:25 AM
    For real. You really trust a helicoil on that much mass, spinning at that RPM, with those shear forces involved? @NetGnome what kinda hold-my-beer type shit you trying to do over there? :rofl:
    Elevatorguy, bmf4069 and HBTundra like this.
  19. May 31, 2023 at 8:47 AM
    #49
    HBTundra
    HBTundra New Member
    2006 DC 2wd
  20. May 31, 2023 at 8:48 AM
    #50
    Darwin!
    Tundra2 likes this.
  21. May 31, 2023 at 9:10 AM
    #51
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Pack those lugs with jb weld.
  22. May 31, 2023 at 10:33 AM
    #52
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Someone dump a buncha wheel spacers at chrisb's place. He has a lathe, i think. Hog out 3rd gen spacers to fit the 106 hubs.
  23. May 31, 2023 at 2:06 PM
    #53
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Tundra2 likes this.
  24. Jun 1, 2023 at 4:13 PM
    #54
    There was a nice older p-car down the road from where we ate pizza with the kids last Saturday. Thought about @chrisb before I realized I'd still like to have one.
    KNABORES and Tundra2 like this.
  25. Aug 30, 2024 at 7:40 PM
    #55
    BenSko
    BenSko New Member
    Ben
    2006 Sequoia
    2024 Tundra Wheels
  26. Sep 23, 2024 at 6:05 PM
    #56
    Schleigerj
    Schleigerj New Member
    2000 Toyota tundra
    @BenSko
    Did you get a 1.25” or 1.5” offset?
    Can you post a picture?
