3rd Gen Tundra Door Panels in 2nd Gen Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Caruso, Mar 31, 2018.
  1. Mar 31, 2018 at 12:00 PM
    Caruso
    Caruso [OP] New Member
    While this may have been mentioned before or may just be rather obvious I figured I would post this to help anyone else that may be interested in doing the same.
    I installed a set of 2016 Toyota Tundra door panels in my 2010 Tundra today. Direct fitment and very straight forward install. Simply remove the old door panels and install the new ones.
    Just wanted to post some info up as I found nothing when I originally searched for compatibility between generations.
    RainMan_PNW, 1UPPER, TheBeast and 9 others like this.
  2. Apr 12, 2018 at 11:15 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Thanks! I’ve been wanting to change mine out. Good to know it’s a direct swap.
  3. Apr 13, 2018 at 12:41 AM
    Quebec
    Quebec New Member
    Without pics...
  4. Apr 13, 2018 at 3:19 AM
    X2 ^^^^
    15whtrd and DalTee like this.
  5. Apr 13, 2018 at 5:15 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s your MO! Haha
  6. Apr 13, 2018 at 5:52 AM
    Huh? What? Me?
    15whtrd[QUOTED] likes this.
  7. Apr 16, 2018 at 4:24 PM
    airosey
    East TN
    We need pics!!!
  8. Apr 16, 2018 at 5:11 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'd like to see how that came out. I wanna go the other way and put the older panel in my 3rd gen to recover the little storage in the arm rest.
    Phantastic81 likes this.
  9. Apr 17, 2018 at 1:22 PM
    digdug
    digdug New Member
    Doug
    2008 Crewmax
    Toytec Ultimate kit w/ Bilstein Fabtech UCA TRD stabilizer Boss shocks - Rear Airlift wireless one 35x12.5x20 Nitto G2 Grappler
    Pictures please!!!
  10. Apr 17, 2018 at 3:49 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME !
    :worthless:
  11. Oct 24, 2018 at 7:22 AM
    Caruso
    Apologies for the major delay in response to this post. I’ve attached a few pictures of the front panels.
  12. Oct 24, 2018 at 8:22 AM
    TTCrewmax
    TTCrewmax New Member
    What steering wheel is in your truck?
    TRD-tv likes this.
  13. Oct 24, 2018 at 8:48 AM
    Caruso
    It’s a Lexus GS300 steering wheel. I just rebadged it with the Toyota emblem.
    DalTee likes this.
  14. Oct 24, 2018 at 4:25 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    what's the advantage?
    TRD-tv and Rex Kramer like this.
  15. Oct 24, 2018 at 5:10 PM
    Caruso
    No advantage really. When I purchased my truck it was in rough shape. Steering wheel and air bag both needed replacing and I decided to upgrade to a decent wood grain steering wheel.
    TRD-tv and nuclearlemon[QUOTED] like this.
  16. Oct 24, 2018 at 5:38 PM
    TheBeast The Beach
    nice work. where did you find the panels ?
  17. Oct 24, 2018 at 6:28 PM
    Caruso
    I sourced them from eBay. I had to look around for a while and buy them all individually from different used parts dealers. If you’re patient you can find good deals on them. I spent around $500 on all four I believe. Also if you find panels that do not include window switches you can buy the bezel from the dealer for pretty cheap and your old window switches will mount right up. I had to do this for the driver side door panel.
  18. Nov 11, 2018 at 10:57 PM
    TundraV2
    TundraV2 New Member
    Parker
    07' Tundra SR5 Double Cab
    3"F/1"R leveling kit
    Great idea. Is this on a double cab or crew cab? Also, did everything line up correctly(pins, clips, etc.)?
    Rica25 likes this.
  19. Nov 12, 2018 at 3:19 AM
    Caruso
    This is a double cab and yes everything lined up perfectly.
  20. Nov 15, 2018 at 4:45 AM
    Zoren Tundra
    Zoren Tundra New Member
    Eric
    2012 TRD off road 4x4
    Off topic but do you think the new 3rd gen model steering wheel would work as direct swap with gen 2 as well?
  21. Nov 15, 2018 at 5:15 AM
    Twinky
    07 double cab work horse
    Thats a nice bit of info. My 07 panels are starting to show thier age and a gen 3 swap sounds better than painting or heat gunning them.
  22. Nov 15, 2018 at 4:37 PM
    Caruso
    It will mount up just fine but if you want functional steering wheel controls you may need to do a bit of work to make it work properly. I was considering doing the same swap originally but I found this wheel and air bag for a good price and couldn’t pass it up.
    Zoren Tundra[QUOTED] likes this.
  23. Nov 29, 2018 at 7:51 PM
    Bmxrider1331
    Bmxrider1331 New Member
    Brendan
    NEW JERSEY
    2013 tundra 4x4 4.6....
    3 inch toytec eibach kit on 35s
    I find this interesting. Tbh I like the room on the pannel on the floor and the little change cubby atleast what i use it for. Looks less room but deffintly nice
    airosey likes this.
  24. Mar 4, 2021 at 12:31 AM
    Sky/cc
    Sky/cc New Member
    JC
    '08 Black Ltd DC TRD (RIP), '16 BBP Ltd DC TRD (RIP), '19 MBM Ltd DC TRD
    Thanks for this OP! I don't know how I never found this post before. I've been looking to go to <'14 panels just for the puddle lights. I have no idea why they took them out (like the a-pillar grab handle) but they're much more functional than any aftermarket side mirror-mounted puddle lights in my opinion. Plus, like 831 said, those little storage cubbies under the window switches were nice. I'm just curious why you wanted the newer panels. Makes me wonder if I'm missing some cool new thing that compensates for what they took away. Besides the lights & cubbies I thought they were identical.
    Also, way late I know, but for Zoren I believe the steering wheel cores from '07 on are interchangeable, along with many years of 4-Runners & Sequioas. You just have to switch over any switches, bezels, cruise control, etc. to maintain full functionality of your current vehicle.
  25. Mar 5, 2021 at 9:17 AM
    Mulligan1305
    Mulligan1305 New Member
    NC
    2011 Tundra SR5 DC, 4WD
    Puddle lights...? Are you saying there are puddle lights (or at least pre-wires) in the 07 - 13 panels?
  26. Mar 5, 2021 at 1:40 PM
    Sky/cc
    Sky/cc New Member
    JC
    Puddle lights, courtesy lights, whatever you want to call them, I know my '08 had them in the bottoms of all four doors. Why they deleted those, alont with the driver's side a-pillar handle is beyond me. That truck also had the same molded in can/bottle holder pockets in the rear door panels that the fronts doors had/have.
    To clarify, those lights were in the bottoms of the door panels, not in the mirrors.
    Mulligan1305 likes this.
  27. Mar 5, 2021 at 4:12 PM
    Mulligan1305
    NC
    Cool. Mine doesn't have them but maybe they're prewired...? Another thing I'm gonna check this weekend.
  28. Mar 7, 2021 at 12:42 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Sky/cc likes this.
  29. Mar 14, 2021 at 6:31 PM
    BlueCrushSC16
    Charleston, SC
    Did the LED courtesy light door mod this weekend.
  30. Mar 14, 2021 at 6:39 PM
    BlueCrushSC16
    Charleston, SC
    Pull the 7.5A interior light fuse. Drill 11/16" holes in the locations on the doors for mounting. Cut the OEM connectors off and solder on the new ones. The LEDs are polarity sensitive. Hook everything up. Reinstall the fuse and voila. Done.
    Sky/cc likes this.
