3rd gen transfer case fix/stuck in 4wd fix
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jimes, Jul 17, 2020.
  1. Dec 12, 2022 at 11:47 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Same here. I've never been back. Haven't needed to. Hence the fix-it-yourself suggestion. But if I had a legit transfer case actuator issue that still hung up even after two weeks of regular, warmed up exercise, I would go make them make good on the warranty.
  2. Feb 26, 2024 at 1:15 PM
    Mityota
    Mityota New Member
    2018 Cement Limited Crew Max 4x4
    Snorkel 3” Fox Lift with Deaver Leafs Many interior mods OTT Tune
    I’m so happy I have found this thread. I missed it because it says 3rd gen Tundra. I regularly engage 4hi and 4lo as my truck is mostly off road. I probably use 4hi once a week or more, now it’s having all kinds of issues. I’ll be trying this out and hopefully it’ll work and I haven’t destroyed anything in the tcase. I’ve done routine maintenance to the tcase and diffs, but for some reason this 2018 won’t shift out of 4hi. I got stuck in snow the other day, no issue getting unstuck, but it became a nightmare to get it from 4lo, which I was in before getting stuck, all the way back into 2wd.
  3. Mar 2, 2024 at 4:34 PM
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    these trucks usually fix their self if you keep trying. i had one take over a month to finally engage 4wd after not being used for a year. i just kept trying and eventually it engage and then 4 lo worked and now it instantly goes in and out no problem. just engage it once a month and youll never have any problems
  4. Mar 3, 2024 at 6:54 AM
    Mityota
    Mityota New Member
    They generally don’t just fix themselves. I engage 4wd on a weekly basis. If it wasn’t for finding this fix I’d be without 4wd. I didn’t have 4lo for almost a year, went into 4hi just fine, but it wouldn’t go into lo until I found this thread and fixed it.
  5. Mar 5, 2024 at 9:36 AM
    Nikwho
    Nikwho New Member
    Nik
    Black 2015 Limited TRD Tundra
    Yes
    I had this same issue in my 2015 Tundra, after wheeling in Moab! I thought I was stranded. I'd love to convert to a manual T-case shifter, but will be saving this info and digging into it soon! Thanks for posting!
  6. Aug 24, 2024 at 4:23 PM
    Jackjack
    Jackjack New Member
    Jack
    White tundra
    Just fixed mine following this post! Thanks!
    NoMoreGreen likes this.
