3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Nov 2, 2023 at 7:17 AM
    #1531
    Eglitis416
    Eglitis416 New Member
    Justin
    2023 Sr5 Tundra
    I will be throwing on some King 2.5 shocks next month and was curious what everyone is doing for the rear? I would like the truck to sit nice and level. If I left the stock springs would it be nose high?
  2. Nov 3, 2023 at 11:00 AM
    #1532
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    Any rubbing with that ? I’m on 285 -75r18 and have rubbing right now on a 2” level but zero offset wheel. I was looking at going to the ims kit
  3. Nov 5, 2023 at 7:17 PM
    #1533
    911turbo
    911turbo New Member
    Quick question- installing icon stage 4 lift and it calls for removing axle nut. It’s listed as a 38mm 12 point on the icon instructions but it doesn’t appear to be a proper fit. The older tundras and other Toyotas have used a 39mm 12 point. Is this the case for the gen 3? Is it even necessary to remove the axle nut? Looks like coil over can fit with loosening the Lca and removing the lower knuckle bolts.
  4. Nov 5, 2023 at 7:29 PM
    #1534
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    You can install them without removing the axle nut like they describe. Just make sure you control the loosy goosy axle and knuckle when everything is loose and able to freeley move around.
    Kap1 likes this.
  5. Nov 7, 2023 at 7:47 AM
    #1535
    tony22longBed
    tony22longBed New Member
    tony
    2022 lunar rock long Bed
    Planning to run 2" spring in the rear and a panhard... would I need an 1" inch extended shock?
  6. Nov 7, 2023 at 8:12 AM
    #1536
    AND
    AND New Member
    Washington, PNW
    Yes
    tony22longBed[QUOTED] likes this.
  7. Nov 7, 2023 at 3:55 PM
    #1537
    Miketundra603
    Miketundra603 New Member
    22 Tundra 1794 TRD OR
    Has anyone upgraded their non pro tundra with the trd pro fox suspension? Wondering how the ride improves. Also curious if anyone swapped their trd pro suspension to the trd 3” lift and changed in ride quality. I am going for ride quality and not looks but need to stay with Toyota products due to worrying about all of motor issues and something aftermarket being blamed. PFA of my truck.
  8. Nov 7, 2023 at 4:14 PM
    #1538
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Yes. Ping @ryanwgregg who, I believe, installed a take-off TRD Pro suspension on his truck. He can weigh in on the ride quality change.
    I believe so. Check out the search function or the OE TRD 3" Lift specific thread. You'll have better luck reading through that thread for this answer.
    In looking at your picture, if you're really worried about this, then you've already got enough aftermarket parts on your truck for a dealer to blame whatever they want on aftermarket parts. :) If they really wanted to be awful to you, they could blame interference of the electrical system causing whatever issue they didn't want to repair. lol. Honestly, you've already cracked that egg and I wouldn't worry about it...but I'm bias. My suspension hasn't been close to stock for a long time.
    BTW Welcome to the forum! Good looking truck.
  9. Nov 9, 2023 at 12:30 AM
    #1539
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
  10. Nov 9, 2023 at 7:21 AM
    #1540
    Joshuak175
    Joshuak175 New Member
  11. Nov 9, 2023 at 11:51 AM
    #1541
    Durtywrench
    Lou
    23 Tundra platinum
    None
    Same here ! Are these linear or digressive ? I’m curious to what the ride is tailored for
    iiawah808 and Joshuak175[QUOTED] like this.
  12. Nov 9, 2023 at 4:07 PM
    #1542
    Aggiesdm
    Aggiesdm New Member
    Derek
    2016 Crew Max Platinum 4X4; '25 Limited 4X4
    '16: 2" lift and Retrax bed cover
    Had the 3" Readylift installed yesterday and paired it with BFG KO2's (285/65R20's). I have AVS/Air Bags, so I bought the appropriate kit from RL and it looks awesome! I've driven it about 25 miles so far and its drives awesome. It actually feels like it drives smoother than stock! If you have AVS/Air Bags, I'm highly recommending at this point! I'll report back if I find any problems.
    As a bonus, I found out that I had a TRD skid plate already installed. I've had the truck for a month and never even looked cuz I assumed it was a stock skid plate! The RL kit drops the front differential about 2", so I need to buy some longer bolts and steel spacers to mount the skid plate, but it was a nice surprise!
    Dfrink and Yaboy like this.
  13. Nov 10, 2023 at 10:29 AM
    #1543
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    ADS/+2” Dobinsons heavy rear springs. Just needs 38s or 37s!!!
  14. Nov 15, 2023 at 10:21 AM
    #1544
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    Toyota dealer installed Icon Stage 3 on my Tundra yesterday. This kit does not include UCAs and only lifts approximately 2 1/4 in. Plan is to eventually get aftermarket UCAs and adjust the front coilovers to 3 in. I'm happy with how it turned out and I can tell a difference in the quality of ride. Have 295/60/20 tires on it. Will eventually purchase 18 in aftermarket wheels and put 35/12.50/18s on it. This will do for now.
    Dfrink likes this.
  15. Nov 15, 2023 at 10:52 AM
    #1545
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  16. Nov 15, 2023 at 1:28 PM
    #1546
    socaldad
    socaldad New Member
    23 SR5 crewmax TRD-sport
    Just installed rough country m1 adj strut, set at 1.75” and added 275/65/20 Nitto recon grappler.
    Dfrink, Cfairbank and iiawah808 like this.
  17. Nov 15, 2023 at 2:59 PM
    #1547
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    Those struts are what I'm leaning towards. . How do you like them? Looks great! I think I want about 1.5" myself. . .
  18. Nov 16, 2023 at 4:21 PM
    #1548
    ryanjay11
    ryanjay11 New Member
    Anyone running the Fox setup yet?
    Mine should be here pretty quick, then I'll just have to figure a time to get it installed.
    pnw.tundra likes this.
  19. Nov 20, 2023 at 6:43 PM
    #1549
    kleangpun88
    kleangpun88 New Member
    2022 Tundra TRD Sport
    Did you have to use wheel spacers?
  20. Nov 21, 2023 at 4:50 AM
    #1550
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    It seems each truck is a little different based on mfg stackups. I have 285/65 on stock 1794 wheels without spacers. I'm fairly certain I could fit a true 35 without spacers.
  21. Nov 21, 2023 at 4:56 AM
    #1551
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    Have 2” icon coilovers and 285/75/18 Goodyear duratracs (35.1” per manufacture specs) and it’ll rub just doing a u turn
  22. Nov 21, 2023 at 3:31 PM
    #1552
    Durtywrench
    Lou
    23 Tundra platinum
    None
    What offset wheel ?
  23. Nov 21, 2023 at 3:59 PM
    #1553
    TexasTacoma713
    2023 SR5
    18x9 +18
    Durtywrench[QUOTED] likes this.
  24. Nov 22, 2023 at 8:32 AM
    #1554
    Txrx
    Txrx New Member
    Patrick
    Bellingham WA
    2023 Silver tundra Limited TRD OR, Crew max, 5.5ft
    MX4 Tonno, Go Rhino E-boards, Method 705, BFG AT 285/75/17, Rigid amber fog lights
    Have pics of your tundra to see profile and poke? Did you leave the rear end stock with that tire/ wheel set up?
  25. Nov 22, 2023 at 8:57 AM
    #1555
    TexasTacoma713
    2023 SR5
    Txrx[QUOTED] likes this.
  26. Nov 22, 2023 at 1:06 PM
    #1556
    AND
    AND New Member
    Washington, PNW
    Can anybody confirm we have 2 bump stops per side in the front? Have pics?
  27. Nov 22, 2023 at 1:11 PM
    #1557
    TexasTacoma713
    2023 SR5
    Just 1 per side… And their pathetic, size of an Oreo cookie
    AND[QUOTED] likes this.
  28. Nov 22, 2023 at 1:24 PM
    #1558
    KroppDuster
    Bilstein 5100s
    Huh? I had/have front and rear bump stops. Swapped out the rears for Icon extended bump stops and the fronts have a spacer (.5” or 1”) that came it my Icon kit.
  29. Nov 22, 2023 at 2:02 PM
    #1559
    AND
    AND New Member
    Washington, PNW
    My question comes from PerryParts stating our trucks have 2 bump stops in the front per side.
    copied from perryparts website:
    “Please allow up to 10 days for shipment of new orders | Each order is for a pair of PerryParts Bumpstops*
    This vehicle has mounts for 4 front bump stops. We recommend you start with 1 order of PerryParts, mounted in the rearward location, and if you want a more progressive feel, add a second set up front.”
  30. Nov 22, 2023 at 2:04 PM
    #1560
    KroppDuster
    Bilstein 5100s
    Odd. Yeah…only a small one up front.
