3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Jul 29, 2022 at 11:13 AM
    #121
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Just to baseline: The spring rate is the spring rate regardless of the vehicle it's on. The only difference is how that vehicle is affected.
    As I understand it, spring rate is the amount of weight required for 1 inch of spring compression. 2 springs at 227 lbs would (I believe) require 454 lbs of payload to compress the springs roughly 1". That payload # also includes the weight of everything above the spring including the weight of the bed itself.
    romanlegion likes this.
  2. Jul 29, 2022 at 11:14 AM
    #122
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    It means with a 227 lbs load the spring will compress by an inch. You obviously have 2 rear springs (1 on each side), so it would take about 450-460 lbs to compress them by an inch or the rear end of your truck to sag by an inch. I suppose s 227 lbs spring rate is fine.
  3. Jul 29, 2022 at 11:15 AM
    #123
    KroppDuster
    Bilstein 5100s
    The spring rate of the C59-167 (2") and the C59-169 (2.5") are the same, I believe. I think the only variable between the 2 springs is the spring height itself. Both are reported to work on the MY22 Tundra, though it seems the 167 is the more popular option people are going with.
    romanlegion[QUOTED] likes this.
  4. Jul 29, 2022 at 11:15 AM
    #124
    romanlegion
    Roman
    Katy, TX
    You are correct.
  5. Jul 29, 2022 at 11:21 AM
    #125
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Ok, so for me I HATE the classic Tundra sag so I’d go for the 169 and 2.5”. I understood leaf springs better and had Deaver Stage 2’s on my Tacoma which worked well. Thanks for the clarification.
    Any idea what the stock spring rates are?
  6. Jul 29, 2022 at 11:59 AM
    #126
    KroppDuster
    Bilstein 5100s
    No clue on the stock spring height and rate TBH. Just a guess, I imagine it's similar to the Ram spring rate. Rams are the only other trucks (other than the Raptor, I think) that run rear coils. Everyone else is still running rear leafs.
    And, I completely feel you. I'm used to the days of add-a-leaf, HD rear leaf springs, or building bastard packs from the junkyard. Rear coils have been a little of learning for me since I've been planning my build.
    PapaDave418[QUOTED] likes this.
  7. Jul 29, 2022 at 12:16 PM
    #127
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    your statement wouldn’t apply to 2WD models Lol
    PapaDave418 likes this.
  8. Jul 29, 2022 at 7:42 PM
    #128
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Lifted 2 wheel drives are just dumb
    Scooter73, Keon and Yaboy like this.
  9. Jul 30, 2022 at 8:02 AM
    #129
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    :popcorn:
    9OH1 likes this.
  10. Jul 30, 2022 at 3:10 PM
    #130
    KroppDuster
    Bilstein 5100s
    90% of desert prerunners would whole heartedly disagree with you. Desert race trucks are lifted & most of them are 2WD.
    Lifting a truck isn't always about rock crawling and overlanding. There are other types of "off roading" out there.
    Just playing devil's advocate. Living in the desert and seeing these race trucks is pretty cool.
    mayan, montera.built, 9OH1 and 3 others like this.
  11. Jul 31, 2022 at 6:07 AM
    #131
    DexterL
    DexterL New Member
    Well aware of the pre runner set ups- those are completely different animals vs what the vast majority of lifted 2wd’s on the street are.
    Keon likes this.
  12. Jul 31, 2022 at 7:12 AM
    #132
    KroppDuster
    Bilstein 5100s
    A large majority of lifted 4WDs will never leave the pavement in their life time either.
    ¯\_(ツ)_/¯
    benca1, 22PlatWCP and 9OH1 like this.
  13. Jul 31, 2022 at 7:56 PM
    #133
    DexterL
    DexterL New Member
    Very true, the majority of those have pucks, bracket or bilstein 5100’s.
    my point in the quote is 99.9% of folks asking about a 2wd lift are not going to be using it functionally, purely for looks cruising the strip
  14. Aug 1, 2022 at 2:53 PM
    #134
    Shave Ice
    Shave Ice New Member
    j.robert
    2022 Tundra Sport
    For reference this is 1150lbs of payload. Dobinson 2.5” springs with Procomp 1” spacer on top A4643C24-A493-44C6-B582-DA2F2CA02F0B.jpg
  15. Aug 1, 2022 at 3:00 PM
    #135
    Keon
    Keon New Member
    Canada
    '10 Jeep Wrangler, 2.5" lift and 33s
    That's also dumb. Why would anyone lower the practicality and comfort of their truck to not benefit? Looks alone don't warrant it IMO.
    DexterL likes this.
  16. Aug 3, 2022 at 2:08 PM
    #136
    KroppDuster
    Bilstein 5100s
    I reached out to Icon directly to see if they a solution (similar to the Total Chaos UCAs) for the DS & PS ABS lines/brackets. For both the Tubular & Billet UCAs, I'm not sure what they're solution is for that quite yet.
    In the final figure for the UCA install guide, it shows them dangling and there's no reference as to what to do with them. See below. Full install instructions are attached.
    Anyone with the Adventure Motors kit (that uses the Pro Comp UCAs) that can share a pic of how those UCAs handle the ABS line relocation?
    On a side note: For anyone performing the UCA install, it requires the removal of the ECU. It looks like both Total Chaos and Icon both provide similar installation guidance. You have to come in from the top, remove the air box, undo some wiring harnesses & grommets, and then remove the ECU in order to gain access to the UCA bolts.
    jgoliath and PapaDave418 like this.
  17. Aug 3, 2022 at 3:30 PM
    #137
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    Their instructions for the front coil-overs state to replace the sway bar link end with a p/n that doesn’t exist, so I’m not surprised by this.
  18. Aug 3, 2022 at 3:40 PM
    #138
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Isn’t it suppose to bolt to the top of the UCA like stock? I see there is a threaded hole there.
  19. Aug 3, 2022 at 5:47 PM
    #139
    KroppDuster
    Bilstein 5100s
    Funny you mention that. I saw that too, but the Icon rep said that you don't need new end links since the kit comes with a sway bar drop spacer. I guess we'll see.
    You're probably right. It's tough because this is the highest resolution pic I can find of the 2022 Tundra UCAs. I couldn't tell if that's a threaded area or some type of offset zerk fitting for the Delta joint. I won't have these in hand for 2-3 months so I'm trying to pre-plan (i.e. avoid) installation hiccups. lol
    I noticed for the total chaos UCAs, the instructions basically have you zip tie the ABS line to 2 small u-channels they've welded to the side of the UCA.
  20. Aug 3, 2022 at 5:59 PM
    #140
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Found this pic from another site. It has a Allen bolt there.
  21. Aug 4, 2022 at 3:07 PM
    #141
    DexterL
    DexterL New Member
    hybrid, so might be slightly different
  22. Aug 4, 2022 at 3:11 PM
    #142
    KroppDuster
    Bilstein 5100s
    Looks like the Pro Comps go with the same zip tie solution as the Total Chaos UCAs. Thanks for sharing.
  23. Aug 4, 2022 at 3:14 PM
    #143
    KroppDuster
    Bilstein 5100s
    You win the prize. :)
    Heard back from the Icon CS Team:
    TakiEvo[QUOTED] likes this.
  24. Aug 4, 2022 at 7:21 PM
    #144
    DexterL
    DexterL New Member
    yep, there are mounts to zip them into place
  25. Aug 5, 2022 at 8:56 AM
    #145
    naddysaad
    naddysaad New Member
    2022 Tundra TRD Pro
    How does the dobinsons rear coil springs and shocks compare to fox that comes on the TRD Pro's?
  26. Aug 5, 2022 at 9:08 AM
    #146
    montera.built
    montera.built New Member
    Jordan
    2022 AG Toyota Tundra TRD Offroad
    The higher end Dobinsons are likely going to be better than the stock Fox Toyota setup. The rear is going to have a larger reservoir for fluid dissipation and likely will have increased travel. Plus they're 3-way adjustable, high speed, low speed and rebound control, so you can really dial in your ride.
    The foxes that come on Toyota's are nice, but they're nothing like the higher end kits that come on raptors and the like.
    DexterL likes this.
  27. Aug 5, 2022 at 9:18 AM
    #147
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    LOL this made me chuckle. Thanks. I'm happy to out run anyone in 2 wheel drive. lol
    mayan and Roctane84 like this.
  28. Aug 5, 2022 at 6:06 PM
    #148
    DexterL
    DexterL New Member
    Exceptions are part of the deal, but come out here and you won’t make it very far
  29. Aug 5, 2022 at 6:49 PM
    #149
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    guess I’ll just use 4wheel drive then lol
    Roctane84 likes this.
  30. Aug 7, 2022 at 6:01 PM
    #150
    jgoliath
    Dmon187 and 2T2 like this.
