3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Jul 26, 2022 at 6:21 PM
    #91
    Mgrande0311
    Mgrande0311 New Member
    Did you happen to ask icon what spring rate their coilovers were using? My only experience is with king, but some shops will let you swap out standard springs for heavier ones if you’re running armor and a winch. Might save you some time dealing with finding the right amount of preload for the standard icons.
  2. Jul 26, 2022 at 9:06 PM
    #92
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I didn’t get the specs on the spring rate, but can ask when I talk to the shop next time. The shop did confirm that these are a higher rate than stock because the Icon rep immediately jumped to this kit once they told him my bumper & winch combo is estimated at around 290lbs.
    Originally, we were thinking of going the Icon coilovers without the Icon springs and just using the OE springs. However, factoring in armor threw that out the window.
  3. Jul 27, 2022 at 4:22 AM
    #93
    Mgrande0311
    Yeah I’d be really interested hearing what they have to say. Am I understanding you correctly that they offer a standard spring and a heavy spring option? On all their kits I see for sale online, there doesn’t seem to be any indication of optional HD spring rate.
  4. Jul 27, 2022 at 9:19 AM
    #94
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Following... I thinking Icon Stage 4 front and all Dobinson rear with 2" spring. I'm not planning on adding a whole lot, just enough.
  5. Jul 27, 2022 at 10:49 AM
    #95
    KroppDuster
    Bilstein 5100s
    Partially.
    They offer an Icon Coilover Kit that does not include a spring. On these 22 kits...they don't offer a standard spring, per say.
    The Stage 1 & Stage 2 kits are just the coilover shocks and you utilize the OE springs. You'll have to disassemble the stock front coilovers and transfer the OE spring to the Icon coilover kit. All Stage 3 kits & up use an Icon spring for the coilover that is a higher spring rate. At least, that was how it was described to me.
  6. Jul 27, 2022 at 6:42 PM
    #96
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    Got a pic of the Tundra now that it's lifted? Just want to see the end product!
  7. Jul 27, 2022 at 7:16 PM
    #97
    romanlegion
    Roman
    Katy, TX
    I'm on the same boat as you. Maybe I'll add the 2" rear spring lift to compensate for the 300 or so pounds that I plan to add in accessories on the truck bed.
    Any idea how much weight you've added on your truck bed?
    PapaDave418[QUOTED] likes this.
  8. Jul 27, 2022 at 8:33 PM
    #98
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    My rear has about 450lbs loaded for off road
    Red13 and romanlegion[QUOTED] like this.
  9. Jul 28, 2022 at 12:54 AM
    #99
    Shave Ice
    Shave Ice New Member
    j.robert
    2022 Tundra Sport
  10. Jul 28, 2022 at 1:13 AM
    #100
    Kepaniamekolea
    Kepaniamekolea New Member
    Kendall
    Kailua-Kona, HI
    2022 WCP 1794 TRD Off-Road
    Cherry setup looks awesome! Seen you driving around town. Did you get all that installed at Top Notch? If you don't mind me asking about how much did all that cost? Researching for when my 1794 comes in.
    Shave Ice[QUOTED] likes this.
  11. Jul 28, 2022 at 1:29 AM
    #101
    Shave Ice
    j.robert
    2022 Tundra Sport
    thanks! Yeah Top Notch did the work and they were great! They are super detail oriented and they do everything right.
    I’m in this lift more than I wanted to be, probably around $4500. The rear is absolutely dialed, the Dobinson springs, Dobinson IMS shocks and Panhard bar are plush and work amazing off road. We had to preload the ProComp coilovers 2 full turns to get the ride height we needed in order to get closer to the 3.5” rear lift. With the preload the coilovers feel “jumpy,” especially when stepping down a sharp drop. I did 37” tires so it needed a little more lift, but if your doing a 35” I’d definitely recommend the 2.5” Dobinson springs and IMS or MMR shocks without the 1” Procomp spacer on top and then do the Procomp coilovers at the regular height. That would be a perfect setup for ride off-road IMO.
    We also used some brake line brackets, diff drop and a couple other parts from the Rough Country kit.
    You have an eta on your 1974?
  12. Jul 28, 2022 at 5:55 AM
    #102
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Or buy the adventure motors kit that has all of that pre packaged but with sway bar relocation kit, brake lines, bump stops and Fox front shocks- much higher quality than pro comp and about the same price for the total kit!
    Kepaniamekolea likes this.
  13. Jul 28, 2022 at 8:21 AM
    #103
    Shave Ice
    j.robert
    2022 Tundra Sport
    The only component that was really different is the front coilovers, which are Fox 2.0 and adapted to fit the tundra. The Procomps are 2.5” bodies and now made by Walker Evans. They are arguably a better strut. I wasn’t planning on running away bars so I didn’t need the relocation bracket. Additionally getting Adventure motor sports to ship to Hawaii wasn’t cost effective.
    I’ll probably swap out the front coilovers to a Dobinson as soon as they release one. The Dobinson products are top quality.
    Bo-Hunter and Kepaniamekolea like this.
  14. Jul 28, 2022 at 10:13 AM
    #104
    Kepaniamekolea
    Kendall
    Kailua-Kona, HI
    Thanks for the info! Definitely thinking about 37s although my 5ft wife might disagree. Haha!
    Ordered my tundra on Dec 2nd from hilo. They've been getting tundras that were ordered in Oct so hopefully I get mine in Sept. No solid eta. Guess cause it's an upper trim there's been lots of delays. Supposedly it was built back in May. Waiting for the call!
  15. Jul 28, 2022 at 10:24 AM
    #105
    KroppDuster
    Bilstein 5100s
    Good luck with that! My wife is 5' 2" and she's already read me the riot act about going to up my 34.5" tires. haha.
    I'm still debating what to pair with my front Icon setup. Either the Dobinsons 2" springs or keeping the stock springs and just add the ProComp 1" spacer. The spring spacer would be the cheaper route since I wouldn't have add in a rear track bar....though I've seen some folks run the stock rear track bar with the Dobinsons just fine.
  16. Jul 28, 2022 at 11:18 AM
    #106
    romanlegion
    Roman
    Katy, TX
    Thanks for the info. I may go with the 2" springs.
  17. Jul 28, 2022 at 11:20 AM
    #107
    romanlegion
    Roman
    Katy, TX
    Looks badass. What's the lift height on the front and rear, again? 4" and 3" ?
  18. Jul 28, 2022 at 1:11 PM
    #108
    DexterL
    DexterL New Member
    Ahh didn’t realize you were in Hawaii!
  19. Jul 28, 2022 at 1:20 PM
    #109
    AND
    AND New Member
    Washington, PNW
    Anybody have any updates on front suspension from dobinsons or if Old man emu is in the works?
  20. Jul 28, 2022 at 2:14 PM
    #110
    KroppDuster
    Bilstein 5100s
    ARB (who owns OME) is notorious for taking their time releasing new products. In fairness...that's one of the reasons why their stuff is premium (& expensive). They spend a lot of time on R&D. Dobinsons is kind of the same way. The only reason they hit the market so quick with the rear components was they realized their existing LC80 springs just so happen to work on the new Tundra.
    AND[QUOTED] likes this.
  21. Jul 28, 2022 at 4:21 PM
    #111
    romanlegion
    Roman
    Katy, TX
    My order is placed for the ICON Stage 6 with Billet UCA. I'm likely going to add the 2" rear coil spring lift from Dobinsons. It's now just a waiting game. Ugh.
    DexterL and wxman91 like this.
  22. Jul 28, 2022 at 4:25 PM
    #112
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    What are their wait times looking like? Wondering if I should just wait a little longer for the Kings.
  23. Jul 28, 2022 at 4:29 PM
    #113
    romanlegion
    Roman
    Katy, TX
    10-12 weeks, but you know you need to add 4-6 weeks to whatever they tell you. LOL
    DexterL likes this.
  24. Jul 28, 2022 at 4:32 PM
    #114
    KroppDuster
    Bilstein 5100s
    Nice! I really debated going with the billet UCAs. My only worry was the rep mentioned that because of the Heim joints, it often times limits your alignment options to off road shops only. He said most of the usual automotive places don't know how to handle the additional adjustments of the billet UCAs. They do look pretty sick though!
    I'm still debating 1" spacers or the 2" Dobinsons. Thinking about ordering the Dobinsons and having them installed to see how the truck sits.
    Ordered my Icon Stage 4 kit on Monday. The Icon rep said 12-16 weeks for the lead time.
  25. Jul 28, 2022 at 4:38 PM
    #115
    romanlegion
    Roman
    Katy, TX
    I'll have between 300-350 lbs loaded in the bed so I think the 2" coils will sag about an inch and I'm fine with that.
    Probably best to take the rig to a shop that specializes in those types of alignment. An ICON dealer should be able to handle that type of alignment work, but if not, then there's got to be at least one in your city that can do it.
  26. Jul 28, 2022 at 5:31 PM
    #116
    KroppDuster
    Bilstein 5100s
    Unfortunately, no. That's why I went with Icon's tubular UCAs vs the billet. The nearest dedicated off road shop, the one I'm using, is 59 miles from my house. I live out in the boonies so I needed to ensure my setup was accessible. I didn't want to tear up my tires in the event I smack something, knock it out of alignment, and have to drive the 60 miles to get an alignment. The closest thing my little town has to a dedicated off road shop is a small Kawasaki side-by-side dealership. lol.
    romanlegion[QUOTED] likes this.
  27. Jul 29, 2022 at 10:55 AM
    #117
    romanlegion
    Roman
    Katy, TX
    Does anyone know what the spring rates are for the Dobinsons rear spring lifts? Having this info would give us an idea of how much the springs would sag/compress at a give load. Thanks.
    PapaDave418 likes this.
  28. Jul 29, 2022 at 11:03 AM
    #118
    KroppDuster
    Bilstein 5100s
    The 2" lift C59-169 has a spring rate of 227lbs.
    dragokvm likes this.
  29. Jul 29, 2022 at 11:08 AM
    #119
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    So 227lbs, meaning they start to flex with 227lbs added? Or max 227lbs? And it’s rated for a LC so is our truck bed lighter? Does the 2” lift translate to Tundras? So many questions!! :help:
  30. Jul 29, 2022 at 11:10 AM
    #120
    romanlegion
    Roman
    Katy, TX
    Kinda low spring rate in my opinion. So, around 450 lbs load the two rear springs would compress about 1 inch.
