3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Mar 22, 2023 at 9:06 PM
    #961
    urmomspad
    urmomspad New Member
    SoCali
    23 Tundra TRD OR
    Hi! I just got my lift installed and thought I’d share some info for those interested. After much back and forth I decided on the Dobinson’s IMS kit. The deciding factors were reputation, price, option for springs (color, size, and weights), and most of all customer service. The US distribution team has been awesome in answering all the questions I had. Probably some of the best and fastest correspondence you can ask for.
    I went with the 2” front and 1” rear springs in 0-110lbs (10% stiffer than stock). I have yet to take it off-road but on-road it’s damn near close to stock. The added stiffness makes a discernible difference in body roll and sway support. On the freeway it really soaks up any potholes and whoops. At very slow speeds hitting square edge bumps is a little jarring but I attribute that to the E rated Toyo OC RT Trails. As far as regular driving speeds in the city (30-50mph) it’s been comfortable and this is where it feels most like stock.
    Overall I’m stoked with the setup!
    I paired up the suspension with the following wheel setup:
    Method 318 17x8.5 +25 offset
    Toyo Open Country RT Trail 35x12.5R17
    97AE5A56-7BEC-479A-9D02-8127F3A44B37.jpg 704D6367-5498-47C4-8B57-7B44E762DAC8.jpg F9213994-9A13-4BAF-AD2D-E2A0F8593260.jpg
  2. Mar 22, 2023 at 10:21 PM
    #962
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Thanks for sharing…looks really good.
    Any reason why you went with the Icon arms rather than the Dobs?
    urmomspad[QUOTED] likes this.
  3. Mar 22, 2023 at 10:34 PM
    #963
    urmomspad
    SoCali
    23 Tundra TRD OR
    Honestly the main driving factor was price. I got a solid deal on them. Also, the fact that the delta joints are fully sealed, plus the increased angularity.
    bigjuice[QUOTED] likes this.
  4. Mar 23, 2023 at 5:10 AM
    #964
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Also we're still some months away from the Dobinsons billet adjustable UCA's coming into stock.
  5. Mar 23, 2023 at 8:59 AM
    #965
    Bneff89
    Bneff89 New Member
    2023 SR5 TRD Sport Blueprint
    Right on good to hear. I just ordered the Stage 4 kit yesterday, pretty stoked about it!
    Neonbelly22[QUOTED] likes this.
  6. Mar 24, 2023 at 11:07 AM
    #966
    Bird Dog
    Bird Dog New Member
    Dave
    Lindsay, ON Canada
    2022 Tundra CMLB Lunar Rock
    I am looking for some input on my rear spring choice.
    I am putting my order in for the Dobinson 2"/1" IMS. I am going with the 0-110lbs springs in the front. I have no intention to install a bumper or winch.
    I am not sure what to install in the rear... 0-110lbs or 220-440lbs. I have a cap and bedslide installed on the truck. Secondly, do you think I will need after market UCA's?
    Thanks in advance,
  7. Mar 24, 2023 at 11:16 AM
    #967
    crikeymike
    Just add up the weight of the cap and bedside and that will give you the weight range you need to choose for the springs to give the lift height you want
    Yaboy likes this.
  8. Mar 24, 2023 at 1:55 PM
    #968
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    As noted above, get the weight (plus weight you carry in the truck at all times) and then call dobinsons- they are super helpful with this stuff.
  9. Mar 25, 2023 at 7:02 PM
    #969
    Keeferton
    Keeferton New Member
    Keith
    Bend, OR
    22 Tundra TRD Off-road DC
    The 835V are 200lbs/inch spring rate and the 837V are 228lbs/inch. Got that info directly from dobinson. I wound up going with the 837.
  10. Mar 25, 2023 at 9:19 PM
    #970
    Cdunner
    Cdunner New Member
    2023 White Sequoia SR5 TRD Off-road
    Is there a front coil spring lift available? I lifted my 2017 4runner with toytec 3” front coil springs and 5100s. This worked like a dream for me. I’m just looking to level the front.
  11. Mar 26, 2023 at 6:09 PM
    #971
    Cdunner
    Cdunner New Member
    would you know if I could run a dobinsons 2in spring and 5100s? Looking to do something better than just a spacer. I ran toytec 2in coil spring and 5100s on my 17 4runner. Best suspension I’ve ever had.
  12. Mar 27, 2023 at 3:31 PM
    #972
    trailhunters
    trailhunters New Member
    I'm going to be going in to Eibach for their prototype testing for their Pro Truck kit with HD springs to support my static weight - bed rack/RTT. Should be dropping off truck within the next week or so. I'll report back.
    urmomspad, AND and KroppDuster[OP] like this.
  13. Mar 28, 2023 at 5:52 AM
    #973
    WrapCO
    WrapCO New Member
    Eagle , CO
    2022 Toyota Tundra 6.5’ CM
    Westcott lift, Method 316 17” wheels, 35x12.5x17 Toyo Open Country AT3
    I went 2” in the rear, but they are currently backordered, so I haven’t gotten to install that with the Panhard bar yet. I’m sitting on the stock spring with Westcott space still and the rear is sitting an inch lower than the front. I will definitely update pics and a post once it’s 100% done.
    I’m not one to experiment with mismatched parts. I wouldn’t personally run a 5100 ever again after going back and forth, but that’s just due to the way I drive.
  14. Mar 29, 2023 at 1:56 AM
    #974
    wavyota
    wavyota New Member
    Spike
    Lunar Rock Limited
    Dobs 2/1
    Toyo AT3 35x12.5x17
    dragokvm, Yaboy, Kap1 and 5 others like this.
  15. Mar 29, 2023 at 7:04 AM
    #975
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Looks really clean! No rub on the tires? Assuming you had to do some minor pining/trimming?
  16. Mar 29, 2023 at 7:06 AM
    #976
    crikeymike
    That does look awesome. That wheel and tire combo also looks sick, heaps of sidewall. I love it.
    wavyota[QUOTED] likes this.
  17. Mar 29, 2023 at 9:02 AM
    #977
    urmomspad
    SoCali
    23 Tundra TRD OR
    Wow this came together great!!
  18. Mar 29, 2023 at 9:40 AM
    #978
    wavyota
    wavyota New Member
    Spike
    Lunar Rock Limited
    Thanks! Minor rubbing at full lock, because of the -10 offset. Ordered the Westcott bracket that replaces the body mount for more clearance so I won’t have to cut. Will see how it goes. Other than that it rides great.
    Dfrink[QUOTED] likes this.
  19. Apr 1, 2023 at 8:54 AM
    #979
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I got my lift done from my buddy that dose private work took him about 6 hours and 1 hour at toyota for alignment, here’s what got done with pictures to follow.
    -OME 2866 rear springs
    -Dobinsons IMS rear shocks
    -YM rear extended break lines
    -Icon bump stops front/rear
    -TRD lift UCA
    -Elka 2.0 with 2”-3” lift front shocks set to 2.75” above stock height. They come with Eibach springs and I got the heavy ones because of availability, I will not use a steel bumper/winch.
    I did have a 2” block in the front to level it and with stock OR 265/70/18 wheels from the ground to bottom of fender was 39” all 4 sides, now it sits 40.75” front and 41” rear with just the tonneau on and 295/70/18 tires. I still have mud flaps and it rubs slightly at full lock drivers side, it’s fine. Total coast of the lift was $4882 Canadian
  20. Apr 3, 2023 at 4:54 PM
    #980
    crikeymike
    Does anyone have the compressed and extended lengths of the TRD Pro rear shocks?
    ryanwgregg and kilocharlie106 like this.
  21. Apr 3, 2023 at 6:51 PM
    #981
    Tundra-G
    Tundra-G New Member
    2022 Tundra Ltd 4x4 TRD Off-road
    Installed this weekend. 2" lift up front with Kings (1-3/4 more turns / preload on top what came from King) and 1" at the rear with Dobinson C59-835V model-specific springs. Still have a tiny rake, which I prefer to allow for load. Before and after photos are below.
    I had the TRD UCA's, but ended up not installing them as the stock UCAs had more than enough clearance and aligned fine*** (not really, see below). The droop on these Tundras is not limited by the UCA; it is limited by the giant sway bar.
    EDIT: since my original install, I have to make addend the above statement.
    the original UCA was articulating fine, and was clearing the resi hose for the King. However, it was rubbing and scruffily the hose at full droop.
    I ended up swapping the UCAs to the TRD UCAs. Problem solved. These cost me $350 for the pair. I couldn’t justify a reason to go for aftermarket expensive options. This thing works.
    DEF6BA17-58A9-44F7-8100-0A860AF8B308.jpg A67F8BE0-222F-483A-833C-44C6E51F77DE.jpg 97F06B2C-F372-451E-A842-92BB8A8264E4.jpg
    T-MAC, crikeymike, urmomspad and 3 others like this.
  22. Apr 4, 2023 at 4:46 PM
    #982
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    Got my Dobinson’s IMS kit on today. 2 inch in the front with 1 in the rear. Rides significantly better than my Westcott kit. Close to stock. Took some poor quality photos for y’all. Was around $2400 for the kit plus install. 57C209EE-EA6D-4C09-A7B7-42903937197F.jpg 1E69DBEA-1A7E-4FF4-863B-78DC65482FFF.jpg 37E82061-12A3-4D99-8CA9-528C9D0984E5.jpg
  23. Apr 4, 2023 at 5:01 PM
    #983
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Nice truck man.
    I just got quoted $450 shipping for Dobinsons IMS Kit to Hawaii. Ouch....
  24. Apr 4, 2023 at 5:08 PM
    #984
    crikeymike
    I'm sure you could pick it up instead of having it shipped
  25. Apr 4, 2023 at 5:22 PM
    #985
    iiawah808
    Oahu, HI
    I really wish I could. Out in Hawaii, it’s a little but of distance to pickup
  26. Apr 4, 2023 at 5:52 PM
    #986
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    If you plan on getting it installed at a shop, maybe try finding a shop that makes orders with Dobinsons and have them place the order for you. I had my shop place the order for me and it ended up being 5% off with free shipping because they just shipped it out with the rest of their Dobinsons stuff they’d ordered
    iiawah808[QUOTED] likes this.
  27. Apr 4, 2023 at 8:41 PM
    #987
    urmomspad
    SoCali
    23 Tundra TRD OR
    I just got the exact same setup and couldn’t be happier.
  28. Apr 6, 2023 at 4:45 PM
    #988
    trailhunters
    Got my truck back from Eibach testing their prototype Pro-Truck (Stage 1) lift kit. The kit will be released in a few months, but this is going to be a nice kit for those not wanting to spend too much on a kit. I'll be taking more photos of the setup later and posting photos on my IG @trailhunters.
    DMackler, Kap1, dan81 and 6 others like this.
  29. Apr 6, 2023 at 4:48 PM
    #989
    Cdunner
    Cdunner New Member
    Can you tell us what the stage 1 includes?
  30. Apr 6, 2023 at 5:05 PM
    #990
    Pandarturo
    Pandarturo New Member
    I just want an airbag delete kit already damn it!
    Cdunner likes this.
