3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Mar 19, 2023 at 10:22 AM
    #931
    ODShaun
    ODShaun New Member
    This is great, awesome review of the dobinson kit. I also have a 6.5 bed with the westcott kit and I feel the same way, and for those of you that are on the fence about the westcott kit, its a great spacer kit and drives good for on road use or super mild off road when aligned to their specs. But my preferred style of driving off road is more dessert style with moderated speed. I've been holding off on moving forward on getting a true suspension and lift only because of what was available and to my liking. I'm sure as time goes on, the availability and ingenuity for these trucks will excel. In actuality, I really do hope that Total Chaos, Camburg, Muzulla or Dirt King come out with an extended or better yet a long travel kit for these trucks, I'm assuming it will be a couple years out. Don't know if I want to wait that long and this is why I appreciate your post. Do you have any side shots of your truck? And I'm not sure if you mentioned it already, did you go with a 1" or 2" taller rear spring?
  2. Mar 19, 2023 at 11:47 AM
    #932
    jpfa1979
    jpfa1979 New Member
    Juan Pablo
    Thanks! I just want 1" to level and trying to keep original equipment, honestly i dont know anything about suspension
  3. Mar 20, 2023 at 6:23 AM
    #933
    Sparky916
    Sparky916 New Member
    Blake
    22 Lunar Rock Limited TRD OF
    BK is the only one that has a LT kit out right now I believe.
    https://www.bajakits.com/i-31570344...ravel-prerunner-kit.html?ref=category:1459208
    ODShaun[QUOTED] likes this.
  4. Mar 20, 2023 at 10:45 AM
    #934
    Bneff89
    Bneff89 New Member
    2023 SR5 TRD Sport Blueprint
    Hey all, I do not know too much about truck suspensions and I have learned quite about reading through this thread and many others on this forum since I have purchased my '23 TRD Sport last November. Without doing too much research and being sold by Westcott's great marketing, I had their 3/1 preload collar kit installed at the time of purchase. After 5,000 miles, I have very unhappy with the stiffness of the ride. I understand now the engineering behind it now and why the ride stiff ride.
    Therefore, I am on the verge of purchasing either the Icon 2"-3.5" Stage 4 or 5 kit. The stage 4 is in stock now and the stage 5 comes with rear shocks with remote reservoirs is on a 4-8 week lead time. I am leaning toward the stage 4 due to its availability and I don't think I really need remote reservoirs for the rear. My question is if I install either kit, should I keep the stock rear springs with the Westcott 1" rear spacer or should I install a new spring that gives 1" lift in the rear?
    Currently the rear bucks pretty hard when driving over any road bumps over 45 mph. I am hoping that the upgraded rear shocks in either of the Icon Stage 4 or 5 kits will alleviate this issue or is that rear spacer causing the issue. Anyone's thoughts or feedback would be greatly appreciated.
  5. Mar 20, 2023 at 11:37 AM
    #935
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Do you haul heavy loads in your bed or do you tow? If yes to either get the rear adjusters and absolutely 100% ditch the stock springs and spacer- get dobinsons rear coils and some extended brake lines.
  6. Mar 20, 2023 at 11:46 AM
    #936
    Bneff89
    Bneff89 New Member
    I don't tow or have heavy loads in the bed that often but when I do I wouldn't want the rear to sag. What do you recommend for rear adjusters and which dobinsons rear coils? I already have extended rear brake lines from Yotamafia installed.
  7. Mar 20, 2023 at 12:19 PM
    #937
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
  8. Mar 20, 2023 at 12:32 PM
    #938
    Sparky916
    Blake
    I have Icon stage 6 and kept my spacer in the rear from my westcott lift. Night and day difference in ride quality IMO between the 2. You can get 1" springs, but I'd just run the spacer and see if you need them later e.g. if you have constant weight in your bed or towing a lot.
    Yaboy likes this.
  9. Mar 20, 2023 at 4:01 PM
    #939
    wavyota
    wavyota New Member
    Spike
    Lunar Rock Limited
    Got my Dobinsons lift in, and before I drop $1200 on the install I’m wondering how hard it is to do myself? I did springs on my previous car (FK8), and that was a pain in the dick. Im assuming suspension is a little easier on a truck? What’s the hardest part, things to look out for, etc?
  10. Mar 20, 2023 at 4:12 PM
    #940
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Did you opt to get the fronts fully assembled from Dobinsons? - If not, then that's a tough nut to crack without using a shop-style (wall mount) compressor.
    Are you doing new UCAs up front? - UCAs on these trucks are bit of a PITA. Not super major PITA but more they're involved then other trucks I've worked on. On the DS, you have to dismount the ECU or at least get it unbolted to move it out of the way. You have to tackle the UCA from the top.
    Extending your rear brake lines might be tough if you're not used to doing brake work. Outside of those things...it's pretty straight forward.
  11. Mar 20, 2023 at 4:25 PM
    #941
    wavyota
    wavyota New Member
    Spike
    Lunar Rock Limited
    I ordered through Exit so no they aren’t fully assembled. Im assuming the coil needs to be compressed over the shock to be put into place right? Was thinking if I needed a spring compressor to rent one from Auto Zone or something.
    Also keeping the stock UCA for now, and only got the 1” rear spring in which Dob said I shouldn’t need to extend the brake lines.
  12. Mar 20, 2023 at 4:57 PM
    #942
    KroppDuster
    Bilstein 5100s
    There's quite a few folks that have battled with the coils using rented or Amazon compressors. Just prepare for a bit of a fight. It can be done, but so can disarming a bomb. lol.
    In all seriousness, the coils are truck coils. They're a lot beefier than coils on something like a Jeep or a Taco. If you've got a spare car and a friendly local shop, I'd just pay $50 - $100 to have them swapped over for you. Westcott has a video of them compressing the stock springs with an Amazon compressor and it looked a little more serious than the guy was letting on. But, it might just be me. I've seen first hand what it looks like when a cheap compressor lets go. Oof. :eek2:
    ODShaun likes this.
  13. Mar 20, 2023 at 5:24 PM
    #943
    ODShaun
    ODShaun New Member
    If you do end up installing this kit, I highly dont recommend the compressor tool from autozone or harbor freight. You're better off buying the set from Amazon, kinda like the one Westcott uses on there that also can be seen on there install videos. And Yes the coil needs to be compressed to get the top cap button down. And since you're not installing the upper arms, you probably want to contact dobinson to see where to set the preload collar at so you don't add to much lift to where you might bind the stock a-arm and possibly ruin it if you decide to off road or hit. This will assist on getting the best alignment for you r setup as well since caster is limited.
    You should be OK without the extended brake lines if you're only going 1" over stock, if it were me, I'd do the rear extended lines, and call it a day and never mess with it again. With that said, Id also do the aftermarket upper a-arms as well so if you ever want to adjust the coilovers to 2.5-3" and gain the additional caster for alignment. Try calling around to get quotes for the front only with alignment, the rear is pretty straight forward.
  14. Mar 20, 2023 at 5:34 PM
    #944
    ODShaun
    ODShaun New Member
    Yeah, Im fully aware and its good looking kit. I've been trying to ask them for video footages of that lunar rock truck in action. They post still shots on there social media and what not. The only time I saw that truck moving was in a pack with other trucks at 5mph. Id like to see that kit boogie as it was intended before I drop 10-13K.
    Sparky916[QUOTED] likes this.
  15. Mar 20, 2023 at 5:45 PM
    #945
    ODShaun
    ODShaun New Member
    YUP!. I installed the Westcott kit myself with the Autozone compressor tool. It was a bitch forsure, Not only did I have compress the spring once but at least twice on one coilover and 3X one the second one. Oh Man was it super sketch. I had to compress the spring to a point where the compressors threaded shaft were bent and hot tp the touch. I was so surprised that it actually held in place. I did scuff the stock springs trying to remove the damn tool. I was almost to a point where I was in the middle of the install, asking myself "what did I get myself into" with a bunch of "Oh shi!t" moments..LOL... I snapped out of it and man-up to the task as safe as I could and got'er done.
  16. Mar 20, 2023 at 6:35 PM
    #946
    cruiserhead
    cruiserhead New Member
    Man I don’t deal with that stuff. Most compressor tools scare the crap out of me with their sketchiness. I just take stuff down to Les Schwab and pay them a few bucks to do it (which in the past was swapping springs or shocks on the struts).
    KroppDuster[OP] likes this.
  17. Mar 20, 2023 at 6:41 PM
    #947
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    I can confirm the AutoZone rental compressor will not work on Icon coilovers. So I’m pretty sure it wont work on dobinsons.
    You need a compressor with slimmer hooks to grab the coils like this
    BILITOOLS 2-Piece Coil Spring Compressor Tool Heavy Duty Macpherson Strut Spring Compressor Set with Safety Jaws and Holder, Max Load.2645LB https://www.amazon.com/dp/B09PYR6NVF
  18. Mar 21, 2023 at 11:26 AM
    #948
    Neonbelly22
    Neonbelly22 2023 Tundra SR5 TRD Sport 4x4
    2023 Tundra TRD Sport
    Before and after.
    Icon Stage 4
    1" Rear spacer
    Lift was 4" Front 2" Rear
    OEM TRD Sport Wheels
    Nitto Recon Grappler 295/65/20
    Only rubbing is at full lock left or right on the sway bars.
    Justinfro and crikeymike like this.
  19. Mar 21, 2023 at 11:58 AM
    #949
    Sparky916
    Blake
    How did you net 4" in the front and 2" in the rear with 1" spacer in the rear?
  20. Mar 21, 2023 at 12:21 PM
    #950
    KroppDuster
    Bilstein 5100s
    His truck is a TRD Sport. They yield a higher lift in the end than the TRD OR or other models.
  21. Mar 21, 2023 at 12:23 PM
    #951
    TexasTacoma713
    2023 SR5
    Did ya install different axels?
  22. Mar 21, 2023 at 2:23 PM
    #952
    Bneff89
    Bneff89 New Member
    Looks good! I am looking to buy the Icon stage 4 or 5 for my TRD Sport, how do you like the ride compared to stock?
  23. Mar 21, 2023 at 2:29 PM
    #953
    Bneff89
    Bneff89 New Member
    Right on thanks for the insight. I am now looking into the stage 6 kit over the stage 4 as for just $444 more, you get front and rear shocks with remote reservoirs. Can you send pictures of your rig? What tire/wheel specs are you running? I thinking I shouldnt have any issues with rubbing if these kits can give me the same lift as the Westcott.
  24. Mar 21, 2023 at 2:32 PM
    #954
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    Got an alignment at the dealer recently some numbers are out of spec do I need to go back? Can someone look these over they don't match exactly with the alignment specs Ryan posted.
  25. Mar 22, 2023 at 6:13 AM
    #955
    Sparky916
    Blake
    Only thing I had to do was pin back the wheel liner and remove my OEM mud flaps. I'm running Toyo OC AT3s 35x12.5x18 wrapped around some methods +18 offset.
    urmomspad, Justinfro and Yaboy like this.
  26. Mar 22, 2023 at 10:29 AM
    #956
    Bneff89
    Bneff89 New Member
    Good looking truck, thanks for sharing!
  27. Mar 22, 2023 at 1:15 PM
    #957
    Neonbelly22
    My bad, one inch in the rear...
    For the front, its stated that the Icon lift is higher than normal for the sports due to the lowered stock suspension.
  28. Mar 22, 2023 at 1:17 PM
    #958
    Neonbelly22
    I love it.
    I've only rode the stuck suspension for about 800 miles...
    with the Icon and E-rated tires, I can tell only when riding over smaller bumps, but thats about it. It's not even noticeable. If the Icon stage for ride was stock, I'd still be happy.
    Bneff89[QUOTED] likes this.
  29. Mar 22, 2023 at 8:31 PM
    #959
    Molly815
    Molly815 New Member
    Marty
    2023 Solar Octane Tundra TRD PRO
    Bed Cover
    So I see a lot of folks on here don't think much of the Wescott design or ride quality either. With just a spacer how can it make the ride worse?
  30. Mar 22, 2023 at 8:43 PM
    #960
    TexasTacoma713
    2023 SR5
    Black widow TRD, Dfrink and Yaboy like this.
