3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Jan 24, 2023 at 1:22 PM
    #721
    moonrover
    moonrover New Member
    2022 Tundra SR5 TRD OR
  2. Jan 25, 2023 at 1:20 PM
    #722
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Can someone explain WHEN you need to get the longer front axles? I'm asking because I have a non TRD SR5. It had the black Hitachi shocks on the front. I did a 2" coilover for a front lift. I talked with the guy who did the install, he didn't see any reason why I would need longer axles. But then I see folks here talking about having the TRD sport and needing longer axles to do the lift. So I'm concerned... Sorry for my ignorance, I have read through this entire thread and I'm not sure it has been answered for my specific situation.
  3. Jan 25, 2023 at 1:29 PM
    #723
    vegask
    vegask New Member
    Kurt
    Northern NV
    2023 Tundra SR5 Premium
    You would only need longer CVs if you changed out the upper/lower control arms. Of if you did one of the bracket style lifts (fabtech for example).
    Unless there is something revolutionary different about the front suspension on the Tundra that I am not aware of. (I have done a lot of lifts on 3rd/4th/5th gen 4runners, tacomas and even a 1st gen sequoia).
    Lhh305 and Dfrink[QUOTED] like this.
  4. Jan 26, 2023 at 6:18 AM
    #724
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    That makes sense. I'm not seeing any lift companies saying you need longer axles for a 2" lift (i.e. no UCA / LCA). I emailed RoughCountry, they said I didn't need different axels. So I'm sticking with what I have for now. Thanks!
  5. Jan 26, 2023 at 7:54 AM
    #725
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    I have an extra TRD Differential Wire Harness extension bracket PT413-34220 from the Trd lift kit if anyone sees this and wants it for free as long as I can ship it cheap. Pm me.
  6. Jan 26, 2023 at 5:44 PM
    #726
    AccountingSucks
    AccountingSucks New Member
    Has anyone had any luck trying to use universal fox shocks on their 3rd Gen yet?
  7. Jan 26, 2023 at 6:23 PM
    #727
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    BDS has part numbers for rear fox shocks that you can get with their leveling kit for the 22+ tundras
    AccountingSucks likes this.
  8. Jan 26, 2023 at 6:50 PM
    #728
    AccountingSucks
    Thanks! I'll look into it! i also went on 4wd did a search by vehicle and it was able to match fox 2.5 universal kits. So I wonder how that will be also
  9. Jan 27, 2023 at 5:44 AM
    #729
    clrprop
    clrprop New Member
    I asked this in another thread. pertaining to the TRD OEM lift.
    I'm curious if the front wheels/tires stick out any further than stock due to the extended CV axle? I understand that lifting would essentially "shorten" the stock CV due to angle (at least in theory it makes sense) but does the TRD extended CV actually cause the stance to be wider?
    I'm trying to determine if a +18 offset will still sit as it would with the stock CV or will they essentially look more like a 0 offset with the new TRD lift CV?
    I'm interested if 'poke' will remain unchanged.
  10. Jan 27, 2023 at 6:21 AM
    #730
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    Not sure if this has been covered before, but I'm hoping for a Fox DSC suspension kit custom tuned by Accutune offroad. I've called FOX and while they don't have any updates, they stated it's in the works and are targeting sometime later in the year.
    I realize the Kings shocks are already announced, but I've had great experience with my custom tuned Fox on my 2020.
    If anyone hears otherwise, please share.
  11. Jan 27, 2023 at 7:07 AM
    #731
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Axels won’t make the wheels stick out, you need a full front end with so much more parts to do that, a wheel alignment can play with camber after a lift and that will just adjust the wheel as you look at it vertical it can tilt in or out or plumb. After my front level the wheels tilted outward from being pulled up.
    Kap1 and clrprop[QUOTED] like this.
  12. Jan 27, 2023 at 7:34 AM
    #732
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    Ordered icon stage 4 tubular from rogue off-road a month go. Had it in stock when I ordered but now they’re saying out of stock and no eta available
    Honestly rather run a Bilstein or Eibach set up tho.., Anyone have any intel on these brands?
  13. Jan 27, 2023 at 12:13 PM
    #733
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    contact adventure motor sports in KC, I have fox fronts from them.
  14. Jan 29, 2023 at 9:23 AM
    #734
    TexasTacoma713
    2023 SR5
    Do you have any more info on this? Is it wider or thinner?… Kinda tired of waiting and now considering mounting 2nd gen bilstein 6112s
  15. Jan 29, 2023 at 9:28 AM
    #735
    TexasTacoma713
    2023 SR5
    Comparison of lengths from a Rough country 3.5” lift strut to a 2nd gen bilstein 6112.. First pic is from RC website and second pic is from shock surplus website data.
    72FCD662-8982-40E3-B59E-239AEDD9A548.jpg 0CD24FE1-7521-4D86-BED4-9ED86343A062.jpg
  16. Jan 29, 2023 at 9:47 AM
    #736
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    The LCAs are a different design. Look at the difference between a 3rd Gen LCA and a 2.5 Gen LCA where the lower portion of the front shock mounts. On the 22+, the mounting point/cradle is on TOP of the LCA. On the 21's & older, the mounting point/cradle is in front of the LCA. I don't have 2 LCAs to compare the width & depth of the cradle so I can't speak to that. All I know is that design is different and that's why every aftermarket company had to create a new design for the 3rd Gen.
    I'd wait if I were you. Otherwise, you're going to have to tread where no major aftermarket house was willing to go...which is trying to make the 2.5 gen design fit the 3rd gen.
    Personally, I'd wait for Icon over Bilstein. I've burned through multiple sets of 5100's over the years, but a lot people love them. Totally up to you. I have no experience with Eibach. If you were near me, I'd give you my Bilsteins that I took off from my OR package. :)
    Top pic is of a 2022 Tundra LCA:
    2020 Tundra LCA:
  17. Jan 29, 2023 at 10:09 AM
    #737
    TexasTacoma713
    2023 SR5
    Damn it. I’m just gonna order some RC 2” loaded struts while I wait for my Icon order to come in.. Best I could find is 5% off on eBay
    KroppDuster[OP] likes this.
  18. Jan 30, 2023 at 6:42 AM
    #738
    kap1425
    kap1425 New Member
    2023 SR5 DC
    Has anyone else come across ABS wire issues with a lift?
    I just installed the Icon Stage 7 kit on my truck and the ABS wire between the sensor and the UCA is too tight to re-install the metal bracket towards the top of the spindle. Has anyone worked past this issue?
  19. Jan 30, 2023 at 6:52 AM
    #739
    jgoliath
    You need the piece from the Trd lift kit for the abs wire extension bracket (or come up with something to extend them yourself). Your parking brake lines and rear brake lines are also at risk for getting stretched. Extended brake lines and the parking brake extension bracket from the Trd lift kit fixes those.
  20. Jan 30, 2023 at 6:57 AM
    #740
    kap1425
    kap1425 New Member
    2023 SR5 DC
    Cool, thanks. F/R Brake lines have been done but I'll need to check on the parking brake extension bracket. If it's just a matter of changing the bracket I'll probably just fab something up myself :thumbsup:
    jgoliath[QUOTED] likes this.
  21. Jan 30, 2023 at 7:00 AM
    #741
    jgoliath
    Basically this step with these items form the Trd kit instructions.
    kap1425[QUOTED] likes this.
  22. Jan 30, 2023 at 7:14 AM
    #742
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    What part numbers are those brackets from this trd lift parts list.
  23. Jan 30, 2023 at 7:28 AM
    #743
    jgoliath
    PT767-34310 For the parking brake. You need 2 of them.
    Youll also need two 90119- A0536 for the parking brake.
    PT413-34220 For the abs line.
    iiawah808 and Yaboy[QUOTED] like this.
  24. Jan 30, 2023 at 7:48 AM
    #744
    kap1425
    kap1425 New Member
    2023 SR5 DC
    amazing, thanks for the very helpful info!
  25. Jan 30, 2023 at 8:02 AM
    #745
    TexasTacoma713
    2023 SR5
    Mind sharing the part number for your Fox shocks?
  26. Jan 30, 2023 at 8:08 AM
    #746
    KroppDuster
    Bilstein 5100s
    You actually shouldn't need that part. The OE bracket should mate up to the UCA just fine. This is my setup with the OE bracket on the tubular Icon UCAs. I have plenty of slack, even at full droop.
  27. Jan 30, 2023 at 8:26 AM
    #747
    kap1425
    kap1425 New Member
    2023 SR5 DC
    Yep I'm running the same UCA's, and the bracket on the UCA bolted right up as well. But the abs line between the UCA and the mounting location near the hub is pulled almost taut (circled in red). before it had enough slack to bolt it to the brake line bracket on the spindle (circled in blue).
    Maybe I just need to pull the wire through a little more to get more slack but just wanted to see what y'all thought of it before doing anything
  28. Jan 30, 2023 at 8:31 AM
    #748
    jgoliath
    Ah shit. I thought he was talking about the rear of the truck.
    Agreed, up front, no issues with the abs line
    kap1425 likes this.
  29. Jan 30, 2023 at 8:33 AM
    #749
    kap1425
    kap1425 New Member
    2023 SR5 DC
    All good! But you bring up a good point. I'll get under it later and check the rear as well.
  30. Jan 30, 2023 at 8:33 AM
    #750
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    What do we need in the rear other than brake lines?
