3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Dec 28, 2022 at 3:24 PM
    #631
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Heck yeah, down travel is highly overrated! :thumbsup::eek2:
  2. Dec 28, 2022 at 10:19 PM
    #632
    WildatheartTundy
    WildatheartTundy New Member
    Joe
    2022 SR5 TRD Off Road
    FINALLY! don’t have all the specs but here is my icon stage 5 set up with 35 Falken wildpeaks 0 offset on 17 Method NV 305s. Front is set at 2” back didn’t get any lift. Looking to add dobinson springs and possibly the icon rear links in the future.
  3. Dec 28, 2022 at 10:34 PM
    #633
    WildatheartTundy
    Joe
    Just had my stage 5 installed been on and off road for about 100 miles. No sounds or creaking.
  4. Dec 29, 2022 at 7:25 AM
    #634
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    Ordered Icon stage 4 tubular arm kit. Best price I found was with rogue off-road.
    I don’t have off-road trim but install notes state that I’ll need a diff drop kit (icon part 55156). I can’t find this part anywhere, including icons own website.
    Only plan on lifting the front 2” and doing a the install myself. I’ll keep y’all posted on how it goes.
    KrisCPFD and iiawah808 like this.
  5. Dec 29, 2022 at 7:02 PM
    #635
    KrisCPFD
    KrisCPFD New Member
    Kris
    2022 Tundra Sr5
    Air lift load lifter 5000 bags. Wireless one compressor. DRL’s and sequential front blinkers. TRD grill. 35” tires. 17” Method wheels. Leveling kit. Soon to be Icon suspension.
    Idk if ur in southern CA but I got a buddy who owns a shop and gets a really good deal on Icon stuff. Doing a stage 6 on my 22 tundra in a couple weeks when parts come back in. $2800 OTD in stalled alignment etc.
    SD.Tundra.858 and socaldad like this.
  6. Dec 29, 2022 at 9:11 PM
    #636
    socaldad
    socaldad New Member
    23 SR5 crewmax TRD-sport
    Can I get your buddy’s shop info? I’m in San Dimas. Looking around for install prices
    thanks
  7. Dec 29, 2022 at 9:49 PM
    #637
    KrisCPFD
    KrisCPFD New Member
    Kris
    2022 Tundra Sr5
    Koritas Tire in Yucaipa. Ask for Carlos. Tell him Kris sent you.
    socaldad[QUOTED] likes this.
  8. Dec 30, 2022 at 3:55 AM
    #638
    RayRay12
    RayRay12 New Member
    2022 Tundra Limited TRD
    Any body install the Elka's on their gen 3 yet? I'm looking for more of a fire road ripping and daily driver setup and am considering a king or elka setup and am new to lifts. The elka's look sweet but I can't find a lot about them. Thanks!
    iiawah808 likes this.
  9. Dec 30, 2022 at 8:23 AM
    #639
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    I have a couple questions, how much dose the OME 2866 springs lift the rear compared to the dobinsons C59-169 spring that says 2” lift? I want to pair these with the Elka front and rear shocks and adjust the front height accordingly for some rake, i haven’t decided on the 2.0 or 2.5 IFP yet. TRD lift dose not use a new panhard track bar with its 2” rear spacer, if I only go 2” max in the rear with a spring will I need adjustable panhard bar at all? One more thing, what’s good to take from the TRD lift other than the UCA and rear break lines I have a credit at the dealership and want to cherry pick from the factory lift parts. I have a parts list here
    PapaDave418 likes this.
  10. Dec 30, 2022 at 2:55 PM
    #640
    Steveeee
    Steveeee New Member
    Anyone have a suggestion for what they think would be the most comfortable on-road suspension setup? I have a 2023 1794 TRD OR hybrid, and I want to get the softest, so-to-speak, suspension setup. Not looking to corner hard or anything like that; looking for as plush of a ride as possible.
    Any suggestions would be appreciated :)
    Kap1 likes this.
  11. Dec 30, 2022 at 3:21 PM
    #641
    KrisCPFD
    KrisCPFD New Member
    Kris
    2022 Tundra Sr5
    Stay with the stock setup. Unless u wanna lift the truck? What’s ur plan with wheels and tires?
  12. Dec 30, 2022 at 3:23 PM
    #642
    Steveeee
    Steveeee New Member
    Don't really want any lift because my wife is short. Wheels and tires I'm probably going to eventually swap out to Methods or similar, with an AT tire.
  13. Dec 30, 2022 at 3:27 PM
    #643
    KrisCPFD
    KrisCPFD New Member
    Kris
    2022 Tundra Sr5
    just do a leveling kit so u can fit the tire size u want and give it ur truck a more aggressive look.
  14. Dec 30, 2022 at 3:28 PM
    #644
    Steveeee
    Steveeee New Member
    Thank you.
    So I take it coilover setups like Elka and King do not provide any additional on-road comfort?
  15. Dec 30, 2022 at 3:30 PM
    #645
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    Depends on how how valve them and what spring rate
  16. Dec 30, 2022 at 3:31 PM
    #646
    Steveeee
    Steveeee New Member
    If I could purchase one of the aforementioned setups and have it adjusted to run as soft as possible, that works too. I just don't have any experience with these suspensions.
  17. Dec 30, 2022 at 4:23 PM
    #647
    TexasTacoma713
    2023 SR5
    Per rogue off-road website, OME 2862, should raise the rear by .75”
    https://rogue-offroad.com/ARB-Rear-Coil--75-_p_13459.html
    Kap1 and Yaboy[QUOTED] like this.
  18. Dec 30, 2022 at 4:23 PM
    #648
    KrisCPFD
    KrisCPFD New Member
    Kris
    2022 Tundra Sr5
    Yes that will work but honestly, your factory shocks are well designed parts. If you’re not going to be doing heavy off-road stuff, ur just throwing ur money away for nothing. Do some YouTube research.
  19. Dec 30, 2022 at 4:32 PM
    #649
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Stick with the stock setup…won’t even need a level kit as you can fit up to a 295 tire with no rub with stock or similar offset wheel if you wanted to go methods or other aftermarket.
    Oh…stay away from load E tires also as it would be a big culprit in quashing your soft ride dreams
    socaldad likes this.
  20. Dec 30, 2022 at 4:38 PM
    #650
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
    I have an Elka set up on my FJ and they’re fantastic both off road and on road.
  21. Dec 31, 2022 at 9:09 AM
    #651
    Steveeee
    Steveeee New Member
    Softer on road Kusala?
  22. Dec 31, 2022 at 9:12 AM
    #652
    AZxp
    AZxp New Member
    Elka, unlike everyone else, does custom valve and shim packs for every customer. If you tell them you want softer on road (and therefore less bottom resistance) they can do it easily.
    I have elkas on different sxs and one I set up for pillow soft and the other for big impacts. Elka did both to near perfection
  23. Dec 31, 2022 at 9:20 AM
    #653
    Bbgunasassin
    Bbgunasassin New Member
    23 Tundra Limited Hybrid Trd Offroad LR
    295/65 r20 Icon Stage 7
    Good info! Researching lift options but I see this on many of icons setups.
    TECH INFO:
    • APPLICATION NOTE #145: WILL NOT WORK WITH HYBRID EQUIPPED VEHICLES.
    Any idea the reason it wont work for the hybrid tundras?
  24. Dec 31, 2022 at 9:24 AM
    #654
    Steveeee
    Steveeee New Member
    Thanks a lot AZxp. What helpful and applicable information.
  25. Dec 31, 2022 at 9:48 AM
    #655
    AZxp
    AZxp New Member
    PM if you go the Elka route. I will introduce you to the number one elka guy in the US who will best any deal and take the time to listen to what kind of ride you want out of your shocks.
  26. Dec 31, 2022 at 9:49 AM
    #656
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
    @Steveeee as @AZxp pointed out is true...they built my set up to how I wanted. My ride is a little firmer than stock, but still extremely comfortable. The stock suspension would billow forward when stopping and it would turn corners like a boat. No longer the case. It drives like a champ allowing for great long distance rides as well as flying down trail/dirt roads.
    Kap1 and ryanwgregg like this.
  27. Dec 31, 2022 at 11:31 AM
    #657
    Steveeee
    Steveeee New Member
    Thats awesome. Thank you both very much. :)
  28. Dec 31, 2022 at 11:38 AM
    #658
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Yeah, I want to know why they state that. Only thing I can think is needing to preload a little more for the weight.
    ryanwgregg likes this.
  29. Dec 31, 2022 at 1:25 PM
    #659
    socaldad
    socaldad New Member
    Stupid me, I decided to cross over the speed bump looking thing at target parking lot instead of reversing. Didn’t think truck was that low. Heard a loud thump, was cringing to see what happened. Got out, seems like the go rhino bottom bracket is slightly bent cause it tapped the speed bump. Still isn’t loose, but I’ll try to loosen screws tomorrow and screw in again.
    Long story, guess I’m definitely gonna look to raise the trunk slightly so it doesn’t happen again.
    Am I safe with keeping UCA stock if I’m only considering 2” rc m1 struts and 1” spacer rear? Thanks
  30. Dec 31, 2022 at 3:18 PM
    #660
    t300
    t300 New Member
    Manitoba
    22tundra
    Yikes what kind of industrial speed bumps you have in socal that you scrape out
