3rd Gen Suspension Lift - MEGA THREAD
Discussion in 'Suspension' started by KroppDuster, Jun 10, 2022.
  1. Sep 1, 2022 at 10:51 AM
    #271
    KroppDuster
    KroppDuster [OP] A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    The easiest way to think about it is like this:
    • Shocks control "bounce" - They don't carry any weight in of themselves
    • Springs carry the weight and thus allow for more lift
    The only way to add lift to OE springs is by preloading (I.E. "squeezing them" more) the factory springs more than they are when they roll off the assembly line. You can only "squeeze" them so much and thus it limits the amount of lift you can out of them. Preloading too much can also reduce travel (up & down).
    Aftermarket springs add ride height because, most of the time, they have a higher spring rate. You can more height and travel from them.
    Hope that helps.
    Dfrink[QUOTED] likes this.
  2. Sep 1, 2022 at 10:52 AM
    #272
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    So the easiest way to answer your question without getting lost in the weeds is that the Eibach Springs that come with the stage 1 kit are longer than OEM springs (and have a different spring rate but that's not critically important for this comparison). They will allow you to capture more lift while giving up less wheel travel. Ex: If you lift 2" on a set of Pro-Truck shocks you'll have less down travel with OEM springs than you would with Eibach springs because you'll have to set the spring perch higher with OEM springs to achieve the same amount of lift.
    Yaboy and Dfrink[QUOTED] like this.
  3. Sep 1, 2022 at 11:05 AM
    #273
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    It all depends on your uses I think
    Eibach will put out something 1-2 levels better than the current OEM offering (minus the Pro’s Fox)…and if they follow what they did on the 2nd gens then we will also get coil-over options and full level and ride height without spacers at a great price.
    So you can mix and match of course but it depends what you want.
  4. Sep 1, 2022 at 11:08 AM
    #274
    memario1214
    Colton
    Missoula, MT
    Mmm... your head's in the right place, but I just want to put a couple of notes here.
    • When installed on a shock a 14" spring (for example) is going to be the same length regardless of how much lift you are asking out of it. Let's say that the weight of the vehicle compresses the spring 1.5" when on the ground. That spring is going to be 12.5" long under the vehicle's weight regardless of whether or not you're asking it to provide zero lift or 2" of lift. That spring is the strongest component in that system so it's going to find its happy place regardless of how you have the shock positioned inside of it. The only way there would be a different value here is if you found the end of the shock itself which would mean you're just compressing a spring on a shock that has zero additional extension to provide.
  5. Sep 1, 2022 at 11:37 AM
    #275
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Awesome feedback, thanks guys! Also, this may explain why the Bilstein 5100's I put on my 19 RAM were set to net 2.5" of lift in the front but I didn't get that? Adding coils would have helped achieve the level I had hoped for?
    When will someone have this product available????
  6. Sep 1, 2022 at 4:41 PM
    #276
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    Adventure Motors KC just took components from the TRD lift and incorporated it with their own lift stuff. You can see all the details on their Instagram story (@adventuremotorskc)
    Dfrink and Yaboy like this.
  7. Sep 1, 2022 at 5:41 PM
    #277
    paulphilly
    paulphilly New Member
    Paul
    Upstate NY
    '24 TRD Pro
    So, is the consensus to install different rear coils instead of air bags to lift 1/2”-1”? Of course, the only spring available now is the LC springs?
    Yaboy likes this.
  8. Sep 1, 2022 at 7:24 PM
    #278
    bigjuice
    WA State
    2024 Terra TRD Pro
    They are a lot of options (and a lot more still in the R&D…test fit stage)
    This video will give you an idea of where things are right now.
    There is more info but it will take some searches and others weighing in when they have the time
    https://youtu.be/avkPK9cg_rs
    paulphilly[QUOTED] likes this.
  9. Sep 2, 2022 at 4:52 PM
    #279
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    I wonder if spacers for the top of the rear shock are necessary when installing a coil spring lift. I know the Wescott preload kit has two sets of small 0.5" spacers for the rear shocks. You can see it describe in this video...
    https://youtu.be/8UJSjoaAGoM?t=139
  10. Sep 2, 2022 at 5:19 PM
    #280
    romanlegion
    Roman
    Katy, TX
    Since you're using a 2.5" Dobinsons coil spring and a 1" Pro Comp spacer on top, did you have to use any spacers for your rear shocks to accommodate or compensate for the 3.5" of additional lift? The shock spacers may not be necessary, but I thought I would ask.
  11. Sep 2, 2022 at 11:54 PM
    #281
    bigjuice
    WA State
    2024 Terra TRD Pro
    I believe not…if you get the right coils (taller coils)
    Most of these spacer lifts are re-using the factory coils so no choice as it’s the only way to get more height.
    …but a true lift with taller coils will give you that extra height without anything else.
  12. Sep 3, 2022 at 4:27 AM
    #282
    Dark
    Dark New Member
    I'm getting the Toyota TRD Lift installed Monday! Going out of town for a bit, but should be a nice thing to come home to.
    iiawah808, LukeS, TheSS712 and 3 others like this.
  13. Sep 3, 2022 at 7:12 AM
    #283
    bigjuice
    WA State
    2024 Terra TRD Pro
    Looking forward to seeing/hearing your thoughts.
    Dark[QUOTED] and Dmon187 like this.
  14. Sep 3, 2022 at 7:38 AM
    #284
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    When did you order this and how long did you have to wait for?
  15. Sep 3, 2022 at 7:44 AM
    #285
    bigjuice
    WA State
    2024 Terra TRD Pro
    …and do you mind let us know the price you paid for the kit and how much they are charging for installation?
    ATXtoyota and Yaboy like this.
  16. Sep 3, 2022 at 2:03 PM
    #286
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    I was quoted $2503.80 for the kit and 9hrs ($1200) install. Still debating on which route to go for suspension.
    bigjuice, Dmon187 and iiawah808 like this.
  17. Sep 3, 2022 at 2:27 PM
    #287
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Make sure to ask for all your original parts back.
    $2500 for the kit isn’t too bad considering all the parts you’ve getting and the warranty. I will strongly consider this when I get my tundra in.
    Armytank and Dark like this.
  18. Sep 3, 2022 at 2:31 PM
    #288
    TheSS712
    TheSS712 New Member
    Shayne
    2022 Army Green Tundra Limited
    @Dark - Can't wait to see your truck with the TRD kit. I want to get it but I have the rear air leveling.
  19. Sep 3, 2022 at 4:47 PM
    #289
    Maharisc
    Maharisc w/Patty
    Karl
    I always request my tear offs, whether it be my truck or my Harley...
    iiawah808[QUOTED] likes this.
  20. Sep 4, 2022 at 2:22 AM
    #290
    Dark
    Dark New Member
    @Dmon187 @bigjuice I prepaid an amount for the kit and new tires with the purchase of my truck when I bought it because it wasn't released yet. That way, it's considered dealer installed. That means no installation cost. If there is any left, they cut me a check.
    Dmon187, bigjuice and iiawah808 like this.
  21. Sep 4, 2022 at 2:23 AM
    #291
    Dark
    Dark New Member
    iiawah808 likes this.
  22. Sep 4, 2022 at 7:34 AM
    #292
    Defector7
    Defector7 New Member
    Eastern ID
    2022 Black Tundra SR5 Crewmax 6.5’ Bed
    Is this for sure unable to go on the rear air leveling trucks. That would suck if true. I was really excited about this lift
  23. Sep 4, 2022 at 7:35 AM
    #293
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    As long as you don’t have avs it will work, you just can’t use the rear suspension parts in the kit- front will all be the same
  24. Sep 4, 2022 at 7:37 AM
    #294
    Defector7
    Eastern ID
    So my guess is dealers won’t install but I can absolutely add the front components myself or from another shop. What would the back feel like or be like and what might have to happen for this to feel like the lift it’s intended to be?
  25. Sep 4, 2022 at 7:38 AM
    #295
    DexterL
    DexterL New Member
    Move your rear air arm up, or buy one of the “lift” versions from someone else.
    I would ask around with dealers, I’m sure there is one that will put the front parts on for you
  26. Sep 4, 2022 at 7:41 AM
    #296
    Defector7
    Eastern ID
    Upon ready the document further it looks like the load leveling might only matter if it’s the TRD sport package.
    TheSS712 likes this.
  27. Sep 4, 2022 at 9:19 AM
    #297
    TheSS712
    TheSS712 New Member
    Shayne
    That’s how I understand the instructions as well. 2WD TRD sport with the air is no go.
  28. Sep 4, 2022 at 10:29 AM
    #298
    Dark
    Dark New Member
    Yeah man, it's for sure. Can't got on TRD Pro either because of the fox springs.
  29. Sep 4, 2022 at 11:05 AM
    #299
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Right hard to believe that the front components won't fit. You lose AVS. Then you can adjust the rear separately. I'm not sure I care about the AVS anyway.
  30. Sep 6, 2022 at 11:55 AM
    #300
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    Do you know if they need any other test mules?
