3rd gen : Stock / Lifted ride height measurement request [hub to fender]
Discussion in 'Suspension' started by BlueBottle, Dec 3, 2017.
  1. May 20, 2018 at 11:06 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    FL 22"
    FR 22"
    RL 24"
    RR 23 3/4"
    All stock suspension
    BlueBottle[OP] likes this.
  2. May 21, 2018 at 10:47 AM
    RMFTundra
    RMFTundra New Member
    2014 Tundra TSS CM
    6”PC Stage2, PC UCA,35x12.50R20AT, Bakflip,Tint,Hypertech, SpidrTrx, Linex Bed & wTech Floor Liners
    Yep Bluebottle is correct. My set up uses Daystar cradles to keep bags aligned under off-road articulation and to permit only the top of bag assembly to be attached to the frame. This one-side only attachment prevents any possibility of a bag tear when full droop is required. Note, off-road articulation is NOT limited when using cradles. 5psi is required for the Firestone bags because the factory bump stop is removed during install. However, I choose the AirLift product which has a bump-stop designed inside the bag. Meaning, I can run the AirLift bags with 0 psi. Said another way: at 0 psi, the ride is factory - can’t even tell the bags are installed. At 10 psi the rake is improved and the highway ride is a little stiffer if not trailer/towing. But here is the best part, if you tow anything from light utility to a boat or even to a camper - the bags make all the difference in Tundra handling. Night and day difference. If I needed a stock pick-up to tow my $hit everyday, I would not have bought a Tundra because trailering is not its handling strength. However, with bags plus all of the other strengths that come with the Tundra, I don’t think there is another 1/2 ton on the market as nice. I don’t know why it took me so long to figure this out and install the bags. Better late than never.
  3. May 21, 2018 at 5:58 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    @BlueBottle I got some numbers for you. Also, the TRD wheels measure 19 5/8" equals 19.625, which makes me 9.8125 to center. That's what all my figures are based off of. These figures are for Bilstein 6112s on top setting, with 1 CB shim on driver side to account for lean. In the rear I have 5160s with CB +2 shackles and TRD rear sway bar. I know the sway bar is irrelevant here.
    LF = 24.4375
    RF = 24.6875
    LR = 25.1875
    RR = 25.4375
    This gives me a 3/4" of rake F to R and with a little less than half a tank of fuel a 1/4" of lean. SmartSelect_20180508-181020_Gallery.jpg
    BlueBottle[OP] and equin like this.
  4. Jun 6, 2018 at 4:52 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    @BlueBottle I'll weigh in for the DC and ADS kiddies
    Vehicle Type - DCSB (6.6 not 8.0)
    Lift/Suspension - ADS 2.5 Coils* Front/2.5 Piggy Rear w/ 1.5" Shackle
    FL : 26.5"
    FR : 26.5"
    RL : 25.0"
    RR : 27.0"
    *Small caveat. I am running 700lb coils instead of standard 650lb coil.
    aaaaaaaaand apparently my driver side rear has something going on that's causing it to sag 2".. yay more projects.
  5. Jun 15, 2018 at 8:17 PM
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    My 2015 Toyota Tundra 4x4 - 1794 has fender flares from the ground to bottom of flares
    Front- 38 1/2”
    Rear - 41”
    My tires are 275/55R 20
    What would my lift be or is it just a leveling kit.
  6. Jun 22, 2018 at 11:28 AM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Sorry for the delay but thanks for all the contributions. I have updated the master list on the OP.
    Your measurements seems high for your suspension. 4-5" of lift off ADS? Are you measuring correctly?
    All our measurements are to the center of hub and NOT the ground.
  7. Jun 22, 2018 at 7:20 PM
    Help New Member
    Ryan
    Tucson, AZ
    @BlueBottle I'll check my tape measure's calibration tomorrow to be certain :rofl:. They come standard with 600lb coils which give 1-3" lift. I'm running 700lb coils.
  8. Jun 27, 2018 at 6:15 PM
    Help New Member
    Ryan
    Tucson, AZ
    @BlueBottle
    Pulled it fully in the garage to measure this time so it was generally level.
    FR: 26"
    FL: 26.5"
    RR: 26.5"
    RL:27"
  9. Apr 12, 2019 at 3:17 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Dang I’m 25.5 up front both sides and rear is 26. So I’m like 3.5” of lift and I’m on stock UCA’s
  10. Apr 12, 2019 at 6:11 AM
    Blkdmax
    Blkdmax New Member
    Tennessee
    2021 Cement CrewMax 4x4
    6112s set on top setting with 1" rear lift
    RF 24.5
    LF 24.75
    RR 25
    LR 25
    I'll be moving shackles to 1.5 soon and I'll update numbers.
  11. Nov 12, 2021 at 2:03 PM
    bjp
    bjp Hello, kitty……
    Ben
    White ‘21 Double-cab Tundra SR5 w/TRD off-road
    GoFast Camper, TRD skid plate, Valhalla cat plates, LT265/70r18 Nokian Rotiivas, buncha shit under the seat, you know how it is
    Adding to an old thread……
    2021 DCSB:
    TRD OR package, stock height, with Nokian LT265/70r18 tires, ARE MX shell, LT265/70r18 spare(steel wheel), TRD RSB, miscellaneous junk in cab and bed, aka normal “empty” load, just under 3/4 in the 38gal tank
    19.5” wheel diameter,
    so a 9.75” radius
    Rear (total height —> center to fender)
    38.5–> 28.75 driver side
    39.0–> 29.25 passenger side
    Front (total height —> center to fender)
    37.25–> 27.5 both sides
  12. Dec 7, 2023 at 8:26 AM
    DBLTRBL
    DBLTRBL New Member
    Bill
    Iowa City
    2016 sr5 Crewmax TRD Off Road
    de-badged, hood decal, Pro Headlights, Paint Match Pro grill and hood. DVD monitors. neoprene seat covers, weathertech floorliners
    YEah this thread is good if more people added to it! Sorry Im 2 year late to the party but
    2016 TRD OFF ROAD 4x4 Eibach Stage 1 set on middle (of 3 choices), plus 1 CB 1/4 shim on driver side. Toytec Shackles on top hole for 1.5" lift
    RF 24.25
    LF 24.75
    RR 25.125
    LR 26
