3rd Gen.NO LIFT w/OVER SIZE tires
Discussion in '2.5 Gen Tundras (2014-2021)' started by Twlrsc, Jan 18, 2016.
  1. Jul 11, 2018 at 8:48 PM
    JakeyTheMost
    JakeyTheMost New Member
    Jake
    2018 Cement Tundra
    285/65R18 on 18x9 +25. Factory suspension. Not a ton bigger than the 275/65R18 but just what I was looking for
    Stock
    Now
  2. Jul 12, 2018 at 12:41 AM
    ONTHEEDGE
    ONTHEEDGE New Member
    2016 Tundra TRD Off Road.
    20” Fast HD Wheels Black TRD Exhaust TRD Pro Grill Bilstein 5100’s Debadged
    Im running 5100’s top height setting with 285-60-20 K02’s and have rubbing On front plastics in reverse and some minor on right turns
  3. Jul 12, 2018 at 1:57 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    True 35’s. Fuel rim with a -1 offset. This was before the 6” lift.
    It was very driveable, so long as you didn’t want to make any right turns, otherwise you were met with a symphony of rubber on plastic machine gun sounds.
    I suppose, with some hefty trimming of the front wheel well covers it would’ve been doable for the long term.
  4. Jul 12, 2018 at 7:31 AM
    tundras00
    tundras00 New Member
    Whoever painted that grille didn't quite match it right.
    zeke7681 likes this.
  5. Jul 24, 2018 at 4:14 AM
    drapex
    drapex Floridian by birth
    RTP, NC
    2018 CM Platinum - Barcelona Red Metallic
    What effect did the 33 inch tires have on your speedometer accuracy and fuel mileage?
  6. Jul 24, 2018 at 4:24 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    I went to 33" tires and the speedometer is now accurate (according to my gps). the fuel mileage went down (1-2 mpg) because I went to 295's.
  7. Sep 5, 2019 at 11:03 AM
    quietflight72
    quietflight72 New Member
    Rob
    Auburndale Fl
    2019 Tundra SR5
    What sizes are those ? It looks nice. I’m looking to do something like that without lifting it. Just tires and wheels. I have a ‘19 SR5.
  8. Jan 10, 2021 at 2:11 PM
    Walleye1875
    Walleye1875 New Member
    16 Limited Crewmax Midnight Black
    Can you tell me what the setup is in this photo?
  9. Jul 22, 2021 at 9:26 PM
    Hawaiiminded
    Hawaiiminded New Member
    Tyler
    2021 Army Green Tundra
    Man those SCS wheels look so good. Those are the exact ones I want, just different color. Also, do you have a leveling kit on this or is the front end factory?
