3rd Gen Dash & Gauge Light Color Swap
Discussion in 'Lighting' started by bauch68, Mar 12, 2020.
  1. Mar 12, 2020 at 7:09 PM
    bauch68
    bauch68 [OP] New Member
    Central Ohio
    2014 Tundra DC TRD Off-Road 4X4 MGM
    Poor man's TRD intake, 6112/5160 1.9", TRD rear sway bar, toytec lift shackles & diff drop, kicker comp rt 10" in custom enclosure
    Whats up everyone.
    Had a few ideas today after thinking about possible lighting changes to my 2014 DC SR5.
    1. I was thinking about tying the cargo lights in with the reverse lights (not sure why I would need that because of the switch).
    2. Changing the gauge needle color to red while leaving the numbers & lettering white
    3. Changing the other buttons and accent lighting throughout the truck. Pretty sure all of the lights are LEDs in something only 6 years old. Im always used to swapping out bulbs on old cars haha.
    Haven't found anything in the lighting section so i figured id ask what you all think.
    Was thinking about adding red footwell lights all around too for some red white and blue!
    Mountun Goat likes this.
  2. Mar 15, 2020 at 8:42 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’d be curious to hear about the gauge lighting upgrade. :popcorn:
  3. Mar 15, 2020 at 8:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There used to be a guy on another Tundra forum that offered this service, but I don't know if he's even there any longer. I've not seen anyone on this board with this information. From what I'm remembering and from having had my cluster apart, these LEDs are incredibly tiny. They're not all the same physical size or part number and getting them would be a task in and of itself as well. These are soldered to the circuit board and in my firsthand experience, swapping these out it akin to trying to solder eyelashes. I found it easier to swap out the entire cluster in the case of my 2nd Gen. YMMV.
    bauch68[OP] and Mountun Goat like this.
  4. Mar 15, 2020 at 12:33 PM
    bauch68
    Central Ohio
    I figured as much. IMHO it's not worth the risk of messing up the gauge cluster. One thing I will check is if the LEDs are colored. If not, then I may try to add some sort of film beneath the areas where I want color change and see how it works. Hope I can get to it soon. I'm in the middle of building a sound system.
