3rd Gen Bumper Swap On My 2010
Discussion in 'General Tundra Discussion' started by 1BadTundra, Feb 24, 2018.
  1. Oct 20, 2021 at 1:42 PM
    #61
    Tundra___myboiBlue
    Tundra___myboiBlue New Member
    2011 Tundra Natuical Blue
    6"RC - 35"X12.50 R20 XD Rockstar
  2. Oct 20, 2021 at 1:42 PM
    #62
    Tundra___myboiBlue
    May I ask we're yall got the shims for the bumper?
  3. Oct 20, 2021 at 1:43 PM
    #63
    Tundra___myboiBlue
    Did u use shims and were did u get them is that bumper rhino lined also?
  4. Oct 20, 2021 at 1:44 PM
    #64
    Tundra___myboiBlue
  5. Oct 20, 2021 at 1:44 PM
    #65
    Tundra___myboiBlue
    We're did yall get the LED BAR?
  6. Mar 19, 2022 at 12:48 PM
    #66
    Seraphinwolf
    Seraphinwolf New Member
    David
    10’ 4.6 Grade TRD Offroad
    Is the support beam for everything the same between 2nd and 2.5 gen’s? Were the plugs to the fog lights still the same between the facelifts? Trying to source a 2.5 bumper right now and trying to figure out how cheaply I can get this done. Just had someone back into my 10’ yesterday and already had a pre-existing rust spot before that.
  7. Jul 10, 2022 at 11:41 AM
    #67
    Seraphinwolf
    David
    So I’ve been sitting here with the “new” bumper waiting to swap out but can’t really take the time unless I can swap out them quick. Not sure if anyone has a handy tip on a QUICK method for undoing the bumper beam extension bracket nuts from the body. I’m in the North East and kinda worried about getting them to break free in the first place.
    Did everyone else find it straight forward to just undo those nuts and once the splash guards are disconnected and fogs unplugged, have the whole thing come off in one go?
  8. Nov 6, 2022 at 6:00 PM
    #68
    Seraphinwolf
    David
    AFF25018-4C28-4FA3-B86A-EDDF09186FE4.jpg Finally had weather and time. Gaps are diving me nuts but I think I can pop the upper cover off, loosen the hardware of the end caps to the cross beam and retighten to wriggle that gap down to gone. If not I’m just gonna make an add on piece after I get flairs and merge the lines up that way.
    I did end up having to fight with the extension bracket nuts but mostly because I decided to semi repurpose a light bar bracket as a spacer to bump out the bumper forward another 1/4” but mounting the bracket behind the extension bracket. Only took me 6 hours but some of that was fiddling with the fog lights(either the adapter harness is no good, or there need a resistor or something to the LED fogs on 19-21’) and clean up time.
  9. Nov 6, 2022 at 6:19 PM
    #69
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Looks good!
    FrenchToasty likes this.
  10. Nov 6, 2022 at 6:19 PM
    #70
    4x4_Angel
    Bree
    Funky Town, Texas
    Ooo.... Not that part though
  11. Nov 6, 2022 at 6:20 PM
    #71
    4x4_Angel
    Bree
    Funky Town, Texas
    I like this a lot
  12. Nov 20, 2022 at 5:26 AM
    #72
    1BadTundra
    1BadTundra [OP] New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    The "Shims" are either stacked washers, I used 1/2" set collars, coach builder actually makes a spacer for it.
  13. Nov 20, 2022 at 5:31 AM
    #73
    1BadTundra
    Clinton
    Too Much to List
    The bumper is Raptor lined. I spray it at my shop, so I had a kit laying around.
  14. Nov 20, 2022 at 5:32 AM
    #74
    1BadTundra
    Clinton
    Too Much to List
    I comes with the bumper
  15. Mar 8, 2023 at 6:09 PM
    #75
    infinkc
    infinkc New Member
    Those that have swapped, do the fender liners behind the bumper still work with the 3rd gen? Didn’t see what was done for that in any of the posts.
  16. Mar 23, 2023 at 5:16 PM
    #76
    1BadTundra
    Clinton
    Too Much to List
    No modification to the fender liners was needed.
    infinkc likes this.
  17. May 19, 2023 at 12:42 PM
    #77
    Mx400ex72
    Mx400ex72 New Member
    sorry, did you say you have a 2014+ bumper for sale and you live in Pa?
    I’m in Quakertown area. Send me a message if you have something for sale
  18. May 19, 2023 at 1:46 PM
    #78
    infinkc
    infinkc New Member
    I tried to put them on, but they hang much lower than the bumper. Did you use the old liners?
  19. Aug 9, 2023 at 7:52 AM
    #79
    rphass17
    rphass17 New Member
    Has anyone tried swapping the rear bumper?
  20. Aug 9, 2023 at 7:54 AM
    #80
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    Rear bumper won't fit stock you would have to cut the bed to match the angles
