3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Oct 11, 2024 at 7:59 AM
    #2611
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Hmmm....Etsy ad says the caps are aluminum. Will take a magnet to them and confirm.
  2. Oct 12, 2024 at 2:51 AM
    #2612
    Lots-O-Dogs
    Lots-O-Dogs New Member
    Mark
  3. Oct 13, 2024 at 9:03 AM
    #2613
    BlackNBlu
    Rich
    MN
    Magnet no sticky.
    These particular caps from Etsy (linked in a previous post) are indeed solid aluminum. No steel thread inserts either.
    Still going to lightly anti-seize them, cuz why not?
    Rockpig likes this.
  4. Oct 17, 2024 at 1:59 PM
    #2614
    maldo012
    maldo012 23 tundra hybrid
    Eric
    Chicago
    23 Tundra Hybrid-Limited
    3inch dobinsons ims struts w/Rough Country 1.5inch spring/M1 shocks in the rear— Icon Uca — Hostile maniac 20inch w/general grabber atx tires — Perry parts front bumps - alpharex luxx headlights— swapped many parts with trd body components— race off-road trd grill etc
    Anyone know what the actual torque should be for upper control arms? For the long bolt? I’m seeing some say 135lbs and some saying 175lbs? I have a limited 23 hybrid with icon tubular uca’s. The icon instructions says to torque to factory specs. But I’m seeing conflicting numbers. Any help would be appreciated
  5. Oct 24, 2024 at 3:19 PM
    #2615
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    steering knuckle nut (to the UCA) is 92 ft lbs (125 Nm), UCA nut torque (for the long bolt) is 136 ft lbs (175 Nm).
    maldo012[QUOTED] likes this.
  6. Nov 26, 2024 at 3:34 PM
    #2616
    brent.ff
    brent.ff New Member
    Anyone know the parts number or a photo of the diagram for the tailgate camera plug connector covers? Dealer is being a dork.
  7. Dec 11, 2024 at 4:50 AM
    #2617
    Barndawg76
    Barndawg76 New Member
    Maryland
    2024 SR5 TRD Sport
    I bought one of these when they had it discounted, and let me say I essentially wasted $60. It fits in the space fine and looks nice and stock, but if you have a bulkier case it won't charge. The biggest issue is your phone will get way too hot from the combination of the usual extra heat generated by wireless charging and the sun coming through the windshield. The phone can get even hotter if your using wireless Android Auto.
    ChiefG likes this.
  8. Dec 11, 2024 at 5:40 AM
    #2618
    Lots-O-Dogs
    Mark
    Thanks- I'll save the money!
  9. Dec 14, 2024 at 12:14 PM
    #2619
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Wonder if it would be possible to add auto up down tail gate to an earlier model
    drewpweinerMD and ChiefG like this.
  10. Dec 14, 2024 at 1:41 PM
    #2620
    ChiefG
    ChiefG Limited 4X4 TRD OR
    Burlington Township, NJ
    2022 Tundra Limited Off Road 4X4
    Just minor stuff. For example, Undercover bed cover, Tufskinz custom door sill protectors, and TRD air filters.
    I’d like to add an auto up to my 2022 Limited TRDOR.
  11. Dec 16, 2024 at 3:45 PM
    #2621
    tundramh
    tundramh New Member
    OHIO
    Anyone have the elevate rack system from realtruck? https://realtruck.com/p/elevate-rac...X7LmNkdBih3A7Pj7_3AAf9a1UkYIEpaEaAmcbEALw_wcB
    I think I am going to get it in a couple months. The roll up cover with the t-slots has been pushed to Jan availablity and I really don't need it until spring. Solves a 13' kayak hauling problem for me when I am traveling with the bed filled with stuff and I really don't want to lug the thing over the roof.
  12. Dec 18, 2024 at 5:31 PM
    #2622
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    UnderCover Flex, mud flaps, Beat Sonic amp, Predator side steps. To come... heritage grille and 20in light bar
    I've got the Elevate rails and have used for hauling paddleboards over the summer.
    I like the T-slot system on the top and bottom of the rails. Simple and easy to assemble and adjust.
    tundramh likes this.
  13. Dec 31, 2024 at 2:14 PM
    #2623
    ninjew
    ninjew New Member
    Hi Guys… Not sure if this is the correct place to ask. I have a 2023 Tundra SR5 with a 5.5’ bed. I was wondering if anyone knows the actual lengths of the Xtrusion Overland pieces for their XTR3 bed rack. I am trying to build my own and sourcing the parts but want to keep it as close to the original as possible. Here’s a link for the one I am trying to recreate: https://xtrusion-overland.com/collections/xtr3-build-your-own-bed-racks I believe that is a user on this forum and I’m subscribed to his yt channel :)
  14. Dec 31, 2024 at 4:09 PM
    #2624
    Shottz
    Shottz New Member
    Carlinkit. Watch netflux or any other streaming app on monitor
    arulataq, DubfromGA and Woodrow bangs like this.
  15. Dec 31, 2024 at 6:59 PM
    #2625
    tom_w2287
    tom_w2287 New Member
    Tom
    2024 Tundra SR5
    Weatherguard toolbox, Ranchhand grille guard
    With the carlinkit, do you need the Toyota WiFi to make it work?
  16. Jan 1, 2025 at 8:07 AM
    #2626
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    Which Carlinkit box did you go with and how was the install and performance?
  17. Jan 1, 2025 at 11:35 AM
    #2627
    matth66
    matth66 New Member
    matt
    Nor cal
    I have the Carlinkit as well t box uhd.
    It works but I have a couple issues with it. 1-when you sort the apps and disconnect the box from the usb it doesn’t remember the sorting.
    2- when you switch from the Tbox to the iPhone CarPlay it disconnects the wifi hotspot on your phone
  18. Jan 4, 2025 at 7:15 PM
    #2628
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    I had a window mounted dashcam but never loved how it looked. I have one of these for my Rav4 and it looks OEM and barely there so I grabbed one for my truck. My guilty pleasure is watching dashcam crash videos on YT btw.
    The Install took like 20 minutes and it uses the mirror/TSS power at the top of the windshield, super easy. To me it looks more OEM than the OEM unit and cheaper
    https://www.amazon.com/dp/B0BRKX4L78
  19. Jan 4, 2025 at 9:58 PM
    #2629
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
  20. Jan 4, 2025 at 11:26 PM
    #2630
    BryMan83
    BryMan83 Slappin da bass mon
    Rio Rancho, NM
    2022 Tundra SR5 TRD OR 4x4 CrewMax
    I've been considering this exact same dashcam. How do you like it so far?
    PapaDave418[QUOTED] likes this.
  21. Jan 5, 2025 at 6:12 AM
    #2631
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    Works great, fires up every time, I forget it’s there. :thumbsup:
    BryMan83[QUOTED] likes this.
  22. Jan 8, 2025 at 9:08 AM
    #2632
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Finally tucked in the bedrug. I had simply dropped it in the bed and I got tired of not having the bed lights or tow hooks exposed. Took a while trimming and taking off/putting back on all the tracks, lights and outlet but it looks so nice and clean now
  23. Jan 8, 2025 at 12:04 PM
    #2633
    Boomer08
    Boomer08 New Member
    2024 white platinum I Force Max
  24. Jan 8, 2025 at 8:32 PM
    #2634
    chrisgibbs707
    Socal
    2022 Tundra SR5 4x4
    Looks amazing! Do you have a tonneau cover, or is that liner ok with rain?
  25. Jan 8, 2025 at 8:48 PM
    #2635
    eddiefromcali
    Eddie
    100% Stock
    I do have a cover but the carpet is supposed to handle the elements just fine although I wouldn't want to put it through that. The foam backing this has is amazing and so easy on your knees and back when you're in there. Used my bed tent on Monday and it was so comfy in there.
    chrisgibbs707[QUOTED] likes this.
  26. Jan 9, 2025 at 5:02 PM
    #2636
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    I got a two drawer Decked unit for my 23 Hybrid Limited. Fits great. It is a generic rectangular main unit with panels that snap along to the sides that are custom designed for the vehicle. It fits great, the drawer is water-proof, and really handy. It is a challenge getting used to a shallow bed but overall I am happy with it. I can lock my tools in the bed and leave them there. No more cluttering up the back seat.
    Like I said, the drawers are water-proof. It has removable panels along the side for storage of anything that doesn't require being kept dry.
    Most of the unit is that really thick, strong, fibrous plastic? I don't know what it is called.
    Once it was installed I realized that the top of it was slicker than greased owl shit so I needed a bed mat. Well, they wanted $499 for their custom mat. I took the bed mat from my 2019, did a little measuring and marking, and cut it to size with my oscillating tool. I did have to bolt it down to the cover since it turned into a sail in the car wash. It would go flying during dry time despite weighing about 50-60#
    I got it at Decked.com. It is a quality product.
  27. Jan 10, 2025 at 11:52 AM
    #2637
    bailey bulldog
    bailey bulldog New Member
  28. Jan 10, 2025 at 12:14 PM
    #2638
    AND
    AND New Member
    Washington, PNW
    It shouldn’t, the hybrid is a totally different truck
  29. Jan 10, 2025 at 1:25 PM
    #2639
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    The brakes system on the hybrid is exactly the same as the gas truck.
    cartage1 likes this.
  30. Jan 10, 2025 at 1:27 PM
    #2640
    Twin2turbo
    Pacific NW
    Yes, they will.
