3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Aug 22, 2024 at 9:09 PM
    #2581
    505lobo202
    505lobo202 New Member
    2024 Lunar Rock Tundra Platinum TRD-Off Road
    I believe that’s because of polarized sunglasses. If you wear non polarized sunglasses you wouldn’t see that rainbow effect when looking through the ceramic tint. I keep an older non-polarized pair of sunglasses in the vehicle now for that reason.
    DubfromGA likes this.
  2. Aug 23, 2024 at 1:22 AM
    #2582
    WickedBassn
    WickedBassn New Member
    Jeff
  3. Sep 3, 2024 at 3:14 PM
    #2583
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    I was wondering if anyone has the TRD Cold Air Intake (PTR03-34223) and TRD Exhaust (PTR03-34221 & PTR03-34222) setup on their truck? I heard that a ECU reflash is also required with these parts and adds a good 40 horses...anyone have any experience?
    Talon7 and Team_Toyota like this.
  4. Sep 6, 2024 at 1:11 PM
    #2584
    sudobash
    sudobash New Member
    If you install the TRD Performance Intake, it will throw a code if you do not flash the calibration.
    32HP and Premium Fuel Required.
    The exhaust can be installed without any calibration needing to be flashed.
    cartage1, Team_Toyota and oddhours like this.
  5. Sep 7, 2024 at 5:22 PM
    #2585
    Team_Toyota
    Team_Toyota New Member
    24 Lunar Rock TRD-OR
    Great info getting those part numbers. That sucks about throwing a code if you put the intake on... So you'll need the full "performance package" from the dealer essentially.
    sudobash[QUOTED] likes this.
  6. Sep 9, 2024 at 5:19 AM
    #2586
    sudobash
    sudobash New Member
    Yes. And it would seem that you will need a late 2024 production date. The Calibrations are very specific to certain ECUs.
  7. Sep 10, 2024 at 5:15 PM
    #2587
    Team_Toyota
    Mines a July 2024 build
  8. Sep 11, 2024 at 7:35 AM
    #2588
    sudobash
    sudobash New Member
    That would be late into the 2024 production cycle when you consider that the 2025s started getting built September 2nd.
  9. Sep 11, 2024 at 8:04 AM
    #2589
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 TTB
    Shooter8571 and sudobash like this.
  10. Sep 17, 2024 at 11:45 AM
    #2590
    Oakman
    Oakman New Member
    Michigan
    looks good. Have you noticed any rattling, loose parts. Is it straight forward install?
    Thanks
    Shooter8571 likes this.
  11. Sep 27, 2024 at 3:14 PM
    #2591
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  12. Sep 27, 2024 at 3:23 PM
    #2592
    Oakman
    Oakman New Member
    Michigan
  13. Sep 27, 2024 at 3:27 PM
    #2593
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Wow. Just wow.
    I would have liked to be in the room when they pitched that one:
    "OK guys, we're going to start with an already structurally compromised grille, cut large portions of it away, and then hang our heavy-ass lights from the remains. Sound good?"
    What could possibly go wrong? :facepalm:
    Blufin, ScottieBones, Kerktam and 6 others like this.
  14. Sep 27, 2024 at 3:32 PM
    #2594
    Shooter8571
    Shooter8571 New Member
    Jack
    2023 Tundra Hybrid iForce Max 1794 trim
    none so far, but would like to
    Twin2turbo likes this.
  15. Sep 27, 2024 at 4:23 PM
    #2595
    eddiefromcali
    Eddie
    100% Stock
    https://www.triple-r-lights.com/toyota-tundra-platinum-2022-grille-kit.html
    For more extreme off-road use, given the size of the grille and risk of vibration, it is recommended to use a Stay Bar Kit to provide additional support and stability for your light installation.
    Colotundie and Shooter8571 like this.
  16. Sep 28, 2024 at 2:41 PM
    #2596
    Prescott87
    Prescott87 New Member
    Jonah
    Brentwood, Ca
    2022 Supersonic Red Limited
    TRD Filters, De-Badged, TRD Pro Grille
  17. Oct 3, 2024 at 7:31 AM
    #2597
    TFTJ
    TFTJ New Member
    This is cool, been eyeing one of these.
  18. Oct 3, 2024 at 7:34 AM
    #2598
    TFTJ
    TFTJ New Member
    Was looking for this specific type of post, probably will pull the trigger on this.
  19. Oct 3, 2024 at 7:39 AM
    #2599
    Shooter8571
    Jack
    I bought the swing case from NAPA online, they had a 10 or 15% coupon if you ordered online. I have one for each side and they’re great, easy to install too.
  20. Oct 7, 2024 at 2:36 PM
    #2600
    BlackNBlu
    Rich
    MN
    valve stem caps.jpg It's the little things....
  21. Oct 7, 2024 at 2:47 PM
    #2601
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    Best mod to my late modded out Tacoma, hands down.
  22. Oct 7, 2024 at 6:34 PM
    #2602
    earlwright239
    earlwright239 New Member
    2022 Army Green Tundra SR5 TRD Sport
    Where did you buy those? Did it come in the red, yellow, orange colors?
  23. Oct 7, 2024 at 6:42 PM
    #2603
    BlackNBlu
    Rich
    MN
    earlwright239[QUOTED] likes this.
  24. Oct 8, 2024 at 7:38 AM
    #2604
    sudobash
    sudobash New Member
    AND, Tundrastruck91, mmasse and 2 others like this.
  25. Oct 8, 2024 at 5:37 PM
    #2605
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Little story about these metal valve stem caps. Had them on my 2020 tundra and while in for an oil change at my local Toyota dealer after 2 hours I ask what’s going on? They bring me back to look at my truck and explain they can’t get my valve stem caps off. The kid took vice grips to my valve stems, crushing them and marking my wheels all to sh:t. I could smell the touch up paint he used to try and cover his tracks. I informed them my dash tells me my tire psi and I just want an oil change. This was the last straw as I’ve had 4 prior issues to this so I demanded 2 new wheels, which they did but they put the old valve stems back in the new wheels. My dealer is an absolute circus and I won’t go back.
    so long story short, you being in MN be careful they don’t seize on you.
    BlackNBlu[QUOTED] likes this.
  26. Oct 8, 2024 at 5:52 PM
    #2606
    BlackNBlu
    Rich
    MN
    Good call, thanks for the tip. I'm thinking a dab of anti-seize on the stem threads should do the trick.
  27. Oct 8, 2024 at 6:01 PM
    #2607
    Northern Toyota
    Tires and bilstein
    yes, that will likely help.
  28. Oct 9, 2024 at 2:16 PM
    #2608
    mfa1981
    mfa1981 New Member
    Marcel
    2024 Nightshade Limited
    Came here because I'm also after this info, I believe you need all 3 + the bracket
    77615-0C020
    77601-0C150
    77602-0C060
    77603-0C060
    I'm not sure if there would be anything else needed, it doesn't look like because RCI says it sends you a bracket and 3 straps, but if you order from some other place you can save at least $100
  29. Oct 10, 2024 at 5:05 PM
    #2609
    Rockpig
    Rockpig You did what?
    08 Limited
    This probably happened because the valve stems are aluminum and the caps steel, the dissimilar metals are not compatible and will enhance the corrosion process. Anti seize should take care of it but your honestly better off with the plastic caps.
    Tundrastruck91 likes this.
  30. Oct 11, 2024 at 6:35 AM
    #2610
    Northern Toyota
    Tires and bilstein
    I have never bought different valve stem caps again. When I got home after they messed up my valve stems/wheels they still didn’t get 2 of the caps off, I took a tiny flat blade screwdriver (one for glasses maybe) and a little hammer and split the caps off in about 2 minutes. I just love incompetence at my service centre.
    Rockpig[QUOTED] likes this.
