3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Sep 21, 2022 at 3:18 PM
    #1771
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    I wouldn’t compare this kit to the Westcott lift or rough country. This is an entire suspension upgrade. As far as this kit I think it’s worth it if you are gonna off road or want to have a better overall drive.
  2. Sep 21, 2022 at 3:36 PM
    #1772
    BaconHelps
    BaconHelps New Member
    2022 Tundra SR5
    CrewMax, 6.5' bed, TRD Off-Road
    Gotcha. I'm just curious because rough country has a 6" lift that replaces the entire suspension for half the price of the trd lift. I know that the trd lift will come with all the Toyota warranties too.
    Also, side question, did they have to calibrate your safety systems or cameras?
    FREEDOMcomesatacost likes this.
  3. Sep 21, 2022 at 3:47 PM
    #1773
    Dmon187
    Dmon187 New Member
    DFW
    I think the warranty itself is worth it. The install price wasn’t what I expected but it is what it is. As far as the safety sensors and features the kit is all compatible with that so I believe it was adjusted. I do not have a front facing camera so I wouldn’t now about that.
  4. Sep 21, 2022 at 5:00 PM
    #1774
    BaconHelps
    2022 Tundra SR5
    Cool, thanks. How do you like driving it?
  5. Sep 24, 2022 at 4:30 AM
    #1775
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    It’s probably important to know that the TRD lift uses taller shocks/springs with upgraded components to achieve most of its lift while the RC lift kit is all spacer pucks that is placed on top of the existing setup.
    So is night and day between the two performance wise in most settings hence the price difference.
    4wd TRD PRO likes this.
  6. Sep 24, 2022 at 5:16 AM
    #1776
    FREEDOMcomesatacost
    FREEDOMcomesatacost Go ahead, pull my finger…
    Just call me Easy
    Louisiana
    2022 SR5 Crewmax supersonic red
    Too much to list…
    Ok I am going to post my own personal experience and choice, but also trying to help others out with questions they may have about lifts. For my own vehicle I currently have a 2022 SR5 crewmax (wanted LR TRD PRO, but after waiting months bought the ONLY new Tundra my dealer got in months with intentions of trading it back in with them once they got the TRD PRO in I wanted, but ended up modding it up so much just going to keep as I love it now) with the Rough Country 6” lift and 37” tires (NITTO ridge grapplers 37/11.5/20 no rubbing). Yes the RC lift is spacer type lift only and I even agree the Toyota factory lift is a much better lift as it’s a true suspension lift with actual better replacement suspension parts and comes with a factory warranty! That is awesome, but for me I wanted a much bigger lift than 3 inches, again personal choice. The factory only is around 3” (haven’t seen one in person but told closer to 2.5”), and that just was not high enough for me. If they had choices for higher lifts from Toyota, 100% I would of choose that route, but RC is the only ones so far that have the taller lift. Ultimately I want a 8” lift with even bigger tires than the 37” I have now, but no one has come out with that yet and I have contacted so many R&D/tech departments (icon,skyjackers,BDS, etc etc) and talked to them personally and all say in development or on the list for upcoming development and all say 2023 at minimum and I obviously have little to no patience so got the RC one for now. I even offered to bring my truck to them to experiment on for the 8” lifts. There are many people that put RC below everyone else (Westcott, etc), but you are hearing from someone that actually has the RC On his truck right now, drives it almost daily and I am being as honest as I can be, it drives very well! Yes it feels a slight different than it did when it was stock (little tighter in turns) but has a SIX INCH lift and 37” TIRES! In the city I have no issues other than people waiving me down to say nice truck or ask me what kit, etc (happens quit often), but the drive is actually smooth, no BS. I don’t do rock climbing or heavy off-roading, but the dirt trails I use again no issues at all. I didn’t do this set up to be an off road overlander type rig, I just like the look of a lifted truck and bigger tires, again MY choice. Some reading may dislike these type trucks and only prefer stock looking, but that’s ok to each his own. I always say if you have the money and want certain things in life then spend it as you can’t take it with you when you leave! Yes you loose a few miles to the gallon on big lifts/tires and yes Any other lift other than the Toyota factory will void your warranty, but ONLY on suspension/tire things not the whole truck. That’s a common misunderstanding. So if your audio system or windows or door locks stop working then those will still be covered under warranty. They only void the warranty if they can show the item you put an aftermarket part on causes the issue. That’s a whole other thread anyway. Also my install shop disconnected the battery and all the sensors (lane change, pre crash, etc) recalibrated themselves and all work perfectly now so much so it locked up on me yesterday as I got too close to a vehicle in front of me that was turning. Got to give ‘em more space! I did go by my dealership after the install and showed and talked to the service manager (know some people there) and he did confirm since aftermarket parts used if any issues on the suspension occurs they have to determine if the aftermarket parts caused it and if so would not be covered, which we all know they gonna do regardless and it’s a decision you have to make as the truck owner. At the same time giving me this bad news, no joke had a line of workers coming check out my truck and taking pics and all saying they love it, but not enough love to warranty any issues suspension wise apparently. Anyway, hope I helped someone looking into lifts and hit me up in this thread or PM if any other questions. Think I covered most and sorry if too long. Before and after pic below. Big difference:
    edit: forgot to mention braking. I have a buddy that has a 3” lift with 35” tires and no big issue, but with 6” & 37’s you need little more time/distance between other cars. Hopefully once I get the 8” inch lift and even bigger tires someone also comes out with a larger brake kit for the 22 Tundras. I have been looking for that too, but no luck yet.
    zayne, vichmr, TrimTab and 4 others like this.
  7. Sep 24, 2022 at 11:08 AM
    #1777
    stump54
    stump54 New Member
    Has anyone found a source for covering the grill emblem? I found this on ETSY but nothing yet for the new Tundra...
    I'd hate to change the entire grill just to black-out the only chrome...
  8. Sep 24, 2022 at 11:28 AM
    #1778
    mike220022
    mike220022 New Member
    stump54[QUOTED] likes this.
  9. Sep 24, 2022 at 11:56 AM
    #1779
    GunnyTundy
    GunnyTundy New Member
    North Dallas, Texas
    2022 Lunar Rock Tundra
    I plastidipped my emblem. It's real easy to pop the emblem out and plastidip it.
  10. Sep 24, 2022 at 12:57 PM
    #1780
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    GunnyTundy[QUOTED] likes this.
  11. Sep 24, 2022 at 1:17 PM
    #1781
    stump54
    stump54 New Member
    That's perfect. Come to think of it, I could use Raptor Liner. Just so happens I have gallons of it waiting on a CJ-7 project...
  12. Sep 24, 2022 at 1:54 PM
    #1782
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    contact adventure motor sports in KC- they have a brake upgrade kit they sell
  13. Sep 24, 2022 at 1:57 PM
    #1783
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Man you know what i did talk to them about a month ago about a 8” lift and Totally neglected to also about if they had a bigger brake kit too. Thanks, calling them back Monday. :hattip::thumbsup:
  14. Sep 24, 2022 at 2:56 PM
    #1784
    GunnyTundy
    North Dallas, Texas
    I've "wasted" enough money on this truck already. I had a couple cans of plastidip at my work station, so I figured I'd save some money by not spending $150 on an entire overlay kit just for the front emblem. All my other emblems on the truck already came black. Now to find some other accessories to "waste" money on.
  15. Sep 24, 2022 at 7:41 PM
    #1785
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Expedition Overland put PowerStop brakes on their 22 Tundra with fully decked out AluCab/Overlanding gear..
  16. Sep 24, 2022 at 7:47 PM
    #1786
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    I had it on my calendar Monday morning for my first call of the day to them, but they are closed Sunday-Tuesday so will be the first call on Wednesday. Thank:thumbsup:
  17. Sep 24, 2022 at 9:10 PM
    #1787
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Sorry disregard the above response. Long day and trying to do too much at one time & got companies mixed up. Thanks for the Expedition Overland reference. Hadn’t heard of them and going to Google them now to contact. :thumbsup:
  18. Sep 24, 2022 at 9:23 PM
    #1788
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Btw, I did check our powerstop brakes in the past when I was searching and Just checked again and on their website nothing for a 2022 Tundra. Maybe they did a custom kit for Expedition Overland? I have sent EO an email asking cause no phone number to call them. Hopefully they respond with some good news :fingerscrossed:
  19. Sep 25, 2022 at 4:42 AM
    #1789
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Did they fix or update their remote case? I remember someone had posted that they had to insert a 3D printed spacer/filler to have the key removal work as expected.
  20. Sep 25, 2022 at 5:53 AM
    #1790
    DexterL
    DexterL New Member
    same ones adventure motor sports has for sale
  21. Sep 25, 2022 at 7:35 AM
    #1791
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    Just received a key fob case last week and it’s fixed. I can pull the key out just fine.
  22. Sep 25, 2022 at 8:27 AM
    #1792
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Yes sir. AJT sent a little grey piece to insert inside for free and works perfectly now. :thumbsup:
    edit: anyone who buys one from now on automatically gets this part so no more issues for anyone.
    jproy12[QUOTED] likes this.
  23. Sep 25, 2022 at 8:31 AM
    #1793
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Yea I’m calling Adventure Motor Wednesday to talk to someone. They are closed Sunday Thru Tuesday. I already sent email to the other company too, no response yet but it’s the weekend. Thanks for everyone’s input. Hopefully I can find a upgraded/larger brake kit. :fingerscrossed:
  24. Sep 25, 2022 at 8:36 AM
    #1794
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Meant to comment on this the other day and got side tracked. Man your truck is a fricking BEAST!! Love seeing stuff like this on here. I swear If I didn’t love the rear window row down so much I would love to add something like this on mine, but I don’t do as much off roading like you, but man I really love the look!!!:101010:
  25. Sep 25, 2022 at 5:15 PM
    #1795
    Dmon187
    Dmon187 New Member
    DFW
  26. Sep 26, 2022 at 8:53 PM
    #1796
    evergreenoffroad
    evergreenoffroad Overland Supply Co. | Land Cruiser Importer
    Garrett
    '22 LTD DCLB TRDOR
    Full Dobinsons IMS Suspension 37" Wildpeak R/T Tires 4WC Flatbed Hawk Prinsu Designs Roof Rack Rig'd UltraSwing CBI Full Armor
    WOO thanks for all the kind words brotha! Yeah, it has been a super fun build process; taking a vision in my mind and putting all the pieces together to make it real. Super super happy with the truck right now and really looking forward to just taking it out more and enjoying it.
    Still lots of work to do on the interior of the alucab to build out cabinets/benches inside for better organization and storage. The build is at the point where I don't have to load/unload much gear every weekend which is ideal since I do typically go camping/exploring every weekend.
    Let me know if you have any questions or if there is anything specifically you want to see more of!
  27. Sep 26, 2022 at 8:56 PM
    #1797
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Any of it. Yea the process never ends. We all want to do more to them. I wish I was handy like you my friend. Keep posting pics as you progress. :thumbsup:
  28. Sep 28, 2022 at 4:24 PM
    #1798
    murtro
    murtro Life is unpredictable. Eat dessert first!
    Alberta
    This is the way. :101010:
  29. Sep 28, 2022 at 7:40 PM
    #1799
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    That looks great! Did you do any prep work on the emblem or just clean it and sprayed away? Is it just held by tape or does it just snaps on and off?
  30. Sep 28, 2022 at 8:06 PM
    #1800
    GunnyTundy
    North Dallas, Texas
    The emblem just snaps off and on. There are tabs at the 10 o'clock, 2 o'clock, and 6 o'clock postions of the emblem. I just put my finger through the gaps in the emblem to slightly push the tabs inward and pull it off. I then cleaned it with isopropyl alcohol and did 4 coats of plastidip. First 2 coats were light. last 2 coats were heavier making sure I got all angles. 10 minutes between coats. I put the emblem back on 8 hours after last coat to ensure that it was dry and had proper adhesion. Let me know if you have any other questions.
    arrampico and vichmr like this.
