3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Aug 23, 2022 at 8:05 AM
    #1681
    ChiefG
    ChiefG Limited 4X4 TRD OR
    Burlington Township, NJ
    2022 Tundra Limited Off Road 4X4
    Just minor stuff. For example, Undercover bed cover, Tufskinz custom door sill protectors, and TRD air filters.
    My understanding is that Toyota has a lift kit up to 4” without having camera/sensor issues. Specifically for the 2022 Tundras.
  2. Aug 24, 2022 at 8:44 AM
    #1682
    Hike5
    Hike5 New Member
    2022 Tundra Limited Crewmax
    Do the Elevate TS rails block the use of the OEM rails mounted on the inside of the bed? I can’t seem to get a clear answer on this.
  3. Aug 24, 2022 at 4:08 PM
    #1683
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    3” on that Toyota OEM lift
    ChiefG[QUOTED] and vichmr like this.
  4. Aug 24, 2022 at 5:50 PM
    #1684
    LukeS
    LukeS New Member
    Luke
    Northeast PA
    Army Green Limited TRD OR
    Would anyone be interested in a full set of unopened OEM carpeted mats? Mine came with them, but purchased all weather mats before leaving the dealership. Forgot I even had them until I put something under the back seat and found them.
  5. Aug 25, 2022 at 9:36 AM
    #1685
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    Got mine delivered today. Only took 3 weeks.
    How long did the install take you?
  6. Aug 25, 2022 at 9:40 AM
    #1686
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Damn. Wish they were shipping the full bumpers that quickly.
    Edit: 1 hour after I post this comment, I get notification from CBI that my full bumper has shipped. Should be here next week. Super stoked. Ordered on 6/15 with an ETA of 8/29.
    Roctane84[QUOTED] likes this.
  7. Aug 25, 2022 at 11:34 AM
    #1687
    Roctane84
    Louisiana
    I opted to pick up at freight facility. Quicker that way if you can do the same. Just make sure your bed is empty. I thought I could take everything off the pallet but it comes in sections that are all bolted to the pallet.
  8. Aug 25, 2022 at 12:01 PM
    #1688
    rpjones68
    rpjones68 New Member
    2022 Blueprint Limited 4x4 TRD Offroad
  9. Aug 25, 2022 at 12:01 PM
    #1689
    KroppDuster
    Bilstein 5100s
    Yeah. I thought about that. Spoke to the local freight terminal, but they said it wouldn't be available for pickup until Monday anyways since their local terminal isn't open to the public on Saturdays or Sundays. I figured I'd just let them bring it to me in that case. I can WFH that day so it's no big deal for me.
    As for the bed...carrying around loads like this is exactly why I opted for the 6.5' bed. hehe.
  10. Aug 25, 2022 at 12:14 PM
    #1690
    KroppDuster
    Bilstein 5100s
    If you're not in a super rush, Amp Research (which makes the Toyota OEM step I believe) sells the entire step for $290.00. Part # AMP75329-01A. Customer service there said they're replenishing stock in mid-September with their retailers.
    https://www.amp-research.com/product-detail/AMP75329-01A/bedstep-flp-dwn-bmpr-stp-22-toyota-tundra
    I think Toyota has it broken into 2 part numbers because the actual step portion is the same between the manual and power versions. However, the bracket is different between the two.
    jmay86, DBamaC and Troyboy84 like this.
  11. Aug 28, 2022 at 4:27 AM
    #1691
    Taikowaza
    Taikowaza New Member
    2558E482-393F-4141-89A9-9310A0D8B6FB.jpg I just installed the Toyota bed step from the parts listed. This video helped me quite a bit, I did have to remove the chassis bracket described in order to fit the step mounting bracket. My step (footplate) components came pre-installed so the install was easier. I’m very happy with the step and its deployment. Previously I had an order in for the aftermarket bedstep, waited a month and no delivery so I cancelled that and went with BAM.
    aogrady22, ChiefG and SmokedMosquito like this.
  12. Aug 28, 2022 at 4:36 AM
    #1692
    Taikowaza
    Also installed the Toyota dashcam. Video here was instrumental in giving me the confidence to do it myself. Install was straightforward and I’m also really happy with this part.
    taysdad likes this.
  13. Aug 28, 2022 at 4:52 AM
    #1693
    Taikowaza
    Installed the TRD skidplate over the Talon Cat Shield. They work and look great together. There is a hook on the TRD skid that must be removed to fit over the Talon. Cut it off with bolt cutters and dremeled flat + smooth
    188Glazier, ChiefG and KClav like this.
  14. Aug 28, 2022 at 5:03 AM
    #1694
    Taikowaza
    Can anyone share the OEM part number, or an aftermarket link to the heritage badge spelling TOYOTA that goes on the passenger side dash “carbon fiber” above the glove box? My Limited TRD Off-road has no Toyota or TRD badging on the passenger side to put decals in, so I’m seeking the raised TRD Pro letters- thanks!
    offshore2005 and ChiefG like this.
  15. Aug 28, 2022 at 6:38 AM
    #1695
    jtundrag
    jtundrag New Member
    ChiefG likes this.
  16. Aug 28, 2022 at 11:04 AM
    #1696
    jtundrag
    jtundrag New Member
    I take it you had to remove the deck rail system to get the Elevate ts rails to fit?
  17. Aug 28, 2022 at 12:48 PM
    #1697
    ChiefG
    Absolutely agree. My Taco had the Husky mats and I thought they were actually better than Weather Tech; however, I’m going to compare both before deciding.
  18. Aug 28, 2022 at 1:03 PM
    #1698
    ChiefG
    The Toyota TRD skid plate is relatively easy to install. Here’s mine. 9279593E-004B-4410-AECA-24B41364A926.jpg
    KClav and Yaboy like this.
  19. Aug 28, 2022 at 1:12 PM
    #1699
    ChiefG
    I have the deployable spoiler on the front
    of my 22 Limited. I’d love to put a good quality decal that says “TOYOTA” or “TUNDRA” on it. If anyone sees one or a source, I’d appreciate a heads up. Thanks.
    FI460 and murtro like this.
  20. Aug 29, 2022 at 3:38 AM
    #1700
    OldMotoMan
    OldMotoMan New Member
    2022 Tundra DC SR5
    Was thinking something similar... But something like "MOVE OVER" or "KEEP RIGHT" printed in reverse so legible when viewed in a rearview mirror.
    Rockgate and ChiefG[QUOTED] like this.
  21. Sep 2, 2022 at 6:26 PM
    #1701
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    GoRhino Dominator D6s today...
  22. Sep 3, 2022 at 7:48 AM
    #1702
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Looks good. They don’t hang down either. Nice work
    Han22 and Medic343[QUOTED] like this.
  23. Sep 3, 2022 at 8:46 AM
    #1703
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    Thanks! If you actually take your time and adjust the mounting hardware appropriately they fit high and tight nicely.
  24. Sep 3, 2022 at 5:07 PM
    #1704
    KingAK55
    KingAK55 New Member
    AK
    2022 Toyota Tundra SR5 TRD Sport Lunar Rock
    I Wanted to add the black exhaust tip. Any discounts out there on that?
    PT932-34221-02
  25. Sep 5, 2022 at 11:06 AM
    #1705
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
  26. Sep 5, 2022 at 11:15 AM
    #1706
    AND
    AND New Member
    Washington, PNW
  27. Sep 5, 2022 at 11:32 AM
    #1707
    jgoliath
    So heretic studios make a 6” light bar that fits that area , but theirs is slimmer so this diode dynamics one most likely won’t fit as cleanly.
    You’d have to come up with some custom mounting and wiring configuration so these definitely won’t “plug and play” fit the stock location.
    AND[QUOTED] likes this.
  28. Sep 5, 2022 at 11:59 AM
    #1708
    taysdad
    taysdad New Member
    2022 Tundra SR
    Awesome video. You’ve inspired me to order one and install it myself!
  29. Sep 5, 2022 at 12:22 PM
    #1709
    TSS Army Green
    TSS Army Green New Member
    Is there any confirmed plug and play amber fog lights that will fit the 2022 Tundra beside Heretic brand?
    Medic343 likes this.
  30. Sep 5, 2022 at 12:34 PM
    #1710
    jgoliath
    Baja has a kit out now which is two 3 ish inch pods per fog light spot.
