3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Mar 18, 2022 at 4:42 PM
    #1021
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    So, the total cost for the step that should have been standard on all models?
    Slicer97 likes this.
  2. Mar 18, 2022 at 5:00 PM
    #1022
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    About $112 for the bracket.. and another $250 for the actual step.. so ~$360 for the oem step.. chances are aftermarket will have some options available in a few months or so.. but i load my bikes on and off constantly and wanted a quick solution.
    dekeman[QUOTED] likes this.
  3. Mar 18, 2022 at 5:33 PM
    #1023
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    wayoflife and dekeman like this.
  4. Mar 18, 2022 at 7:23 PM
    #1024
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
  5. Mar 19, 2022 at 1:31 PM
    #1025
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I usually don't add a lot, here is about as far as it goes for me, window tint, tonneau, and bed slide.
    vichmr, TUNDRA375, rideandfly and 4 others like this.
  6. Mar 19, 2022 at 8:26 PM
    #1026
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Looks sharp ! ...did you have to drill new holes to fit bedslide ? ..or did it use factory bed bolts already there?
  7. Mar 19, 2022 at 8:35 PM
    #1027
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    You need to drill four 1/2 inch holes and then use Riv nuts. I messed up and had to re-do the middle two :frusty:.....so, 6 for me LOL...oops. If you plan on installing one, I learned the hard way that the frame needs to sit about 2 inches or so from the cab end in order to place the Riv nut through the middle of the bed support underneath. This is where I messed up, I drilled the middle two holes then realized the front two holes weren't going to clear the support.
    The Bed Slide is worth every penny! I had a CargoGlide in my last two trucks and decided to try a different brand this go around.
  8. Mar 20, 2022 at 9:14 PM
    #1028
    tropro
    tropro New Member
    Troy
    MN
    2022 Blueprint Platinum
    IMG_20220320_163652.jpg I went with the Truxedo Century CT roll up tonneau cover.IMG_20220320_163750.jpg Aluminum slats with bonded heavy duty woven cloth.
    vichmr, rideandfly, gnc1017 and 4 others like this.
  9. Mar 21, 2022 at 4:28 AM
    #1029
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    Are the factory bed rails considered “with cargo management/deck rail system”?
  10. Mar 21, 2022 at 6:19 AM
    #1030
    tropro
    tropro New Member
    Troy
    MN
    Yes. Super easy install and first time I have done one. Instructions are very good. Realtrucks.com and they will discount, just need to ask. I think I paid $945 before taxes.
    What I really like is it rolls up very easy and doesn't block your rear view.
    Tundrastruck91 likes this.
  11. Mar 22, 2022 at 1:33 PM
    #1031
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    Here is our first prototype on our new storage. My truck build date was pushed to May 3 so looking for one local here in So Cal to test fit.
  12. Mar 22, 2022 at 2:16 PM
    #1032
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    Those look amazing — especially with the lids. Was just thinking: I need lids.
    How would these not rattle though?
    ThePolak likes this.
  13. Mar 22, 2022 at 2:25 PM
    #1033
    ThePolak
    looks great!
  14. Mar 22, 2022 at 2:32 PM
    #1034
    havasubud
    Earl
    Corona, California
    Once we get to production, everything will be a lot tighter. It is just tack welded right now. Plus once they are powder coated, and the locks are adjusted along with adding felt to the underside of the lids, even if they do move a bit, you won't hear it.
    dekeman[QUOTED] and Dmon187 like this.
  15. Mar 22, 2022 at 8:14 PM
    #1035
    gulfcoast850
    gulfcoast850 New Member
    I have the sr it did not come with fog lights. How hard is it to add them? Would also like to add the USB ports for the kids in the back. Possibly bed lights to if possible. Was wondering if the wire harness is ready for these? Has anyone added any of these?
  16. Mar 23, 2022 at 3:14 AM
    #1036
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    Looking forward to these. How long before production? Any idea on pricing?
  17. Mar 23, 2022 at 5:10 AM
    #1037
    Jbeans691981
    Jbeans691981 New Member
    2022 Tundra Sport Lunar Rock
    n/a
    Good lord
  18. Mar 23, 2022 at 8:28 AM
    #1038
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    Anyone use any type of storage bins that go over the wheel wells in the bed? I have a bed slide so the flip out kind isn't an option, and quite overpriced in my opinion.
    jpod likes this.
  19. Mar 23, 2022 at 9:20 AM
    #1039
    ThePolak
    I was looking at those swing cases. They looked neat but are limited to weight of stored items. I like that you can remove them in a snap.
  20. Mar 23, 2022 at 12:13 PM
    #1040
    ja5er
    ja5er New Member
    New York
  21. Mar 24, 2022 at 8:39 AM
    #1041
    Skarnold
    Skarnold New Member
    Karl
    Soon to be a 2022 Tundra SR5 Double Cab
    Looking around yesterday it looks like Go Rhino now has steps for both the crew cab and double cab available on their website.
  22. Mar 24, 2022 at 10:04 AM
    #1042
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Running boards maybe.. but i havent seen a bed step from them. I see universal hitch style bed steps.. but nothing that tucks away for the '22 Tundra.
  23. Mar 24, 2022 at 11:03 AM
    #1043
    lsuwalt
    lsuwalt New Member
    I got real close to ordering one but backed off after reading reviews. I like the looks of it but concerned about shipping damage, paint process, paint match, but most of all, rubbing. Did you experience any paint rub off on your Tacoma?
    Tundrastruck91 and ja5er[QUOTED] like this.
  24. Mar 24, 2022 at 11:32 AM
    #1044
    Maharisc
    Maharisc w/Patty
    Karl
  25. Mar 24, 2022 at 1:16 PM
    #1045
    ja5er
    ja5er New Member
    New York
    With the Tacoma I had the Undercover Lux
    https://undercoverinfo.com/undercover-lux
    i had zero problems from installation, zero water leakage, zero rubbing, etc… it was super easy to take off to haul shit and then put back on. My wife (pregnant at the time) helped me install it to give you an idea of how light and simple it is.
    Specifically to the rubbing issues some may have had….it’s likely they didn’t install it properly. You have to line it up, set the mounts, etc… but taking my time i had a perfect gap around the whole bed.
    *edit* I purchased the Tacoma cover off eBay. The tundra I ordered from summit. Any issues with finish they said they would take care of. Let’s hope for none but Summit’s a pretty big outfit and I assume they would handle whether via replacement or touch up & cash back. If not, credit card charge back for whatever % it’s worth to you. Right now free shipping and 10% off, plus 12 month financing through PayPal credit.
  26. Mar 24, 2022 at 1:53 PM
    #1046
    tropro
    tropro New Member
    Troy
    MN
    gnc1017 likes this.
  27. Mar 24, 2022 at 2:00 PM
    #1047
    lsuwalt
    lsuwalt New Member
    Appreciate the feedback - look forward to seeing pictures of the Tundra cover!
  28. Mar 24, 2022 at 2:47 PM
    #1048
    ThePolak
  29. Mar 24, 2022 at 3:03 PM
    #1049
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    That's still really expensive, considering what it is....at least to me. Nevertheless, I can't use that style because I have a Bed Slide. Thanks for the suggestion though.
    On Facebook and some other pop up adds for truck accessories, I see a pictures of a one piece bin that covers both sides and over the wheel well. It looks like it would be perfect, but I can never find that actual item when I search the associated links. I'll screen shot it next time I see it.
  30. Mar 24, 2022 at 4:46 PM
    #1050
    ThePolak
    They had OEM ones for the Tacoma. Not sure if they’ll make them for the tundra: https://parts.elmhursttoyota.com/oe...e-toyota-tacoma-in-bed-storage-box-pt271350sb
