3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Feb 21, 2022 at 8:49 PM
    #721
    sparky412
    sparky412 New Member
    SW Pennsylvania
    22 SR5 OR CM 6.5 MGM
    It’s a spacer kit with uca’s
    DoMoToyota[QUOTED] likes this.
  2. Feb 21, 2022 at 9:35 PM
    #722
    damnfingers
    damnfingers New Member
    Gene
    So what does a “real” lift kit contain?
  3. Feb 21, 2022 at 10:38 PM
    #723
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
  4. Feb 22, 2022 at 4:29 AM
    #724
    sparky412
    SW Pennsylvania
    Well technically a spacer kit lifts your truck but at a cost. Most will agree if you want improved ride and capability you would want a full suspension upgrade. Also depending on the amount you lift you may need to upgrade other components.
    DoMoToyota likes this.
  5. Feb 22, 2022 at 5:01 AM
    #725
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    I'm looking to order the Westcott lift for my Limited trim (non-TRD) Tundra. Can anyone confirm my suspicion that the non-TRD Limited DOES NOT have the red shocks but rather than standard black shocks? Want to make sure I order the correct lift. Thanks!
    Medic343 likes this.
  6. Feb 22, 2022 at 6:26 AM
    #726
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    Got the Tundy OEM dash cam installed in less than 10 minutes.
    FD54C7F5-4066-4D45-9B59-95B5470F762E.jpg 5F581455-8880-474A-97C7-0D1711B8D5C9.jpg 68EDF9B4-4F3A-4ED0-AAFD-DCCFE90C1E33.jpg
  7. Feb 22, 2022 at 6:34 AM
    #727
    Rbohno
    Rbohno New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
    Most who run those lifts are for mild occasional 4-wheeling and to fit larger tires. I have run them for 20 yrs and my 4 wheeling has always been when I needed it to complete a necessary destination. Driving on the deer lease or property are the biggest reason and then hitting the mountains in the snow a few times a year.
    So most folks are fine with a spacer lift.
  8. Feb 22, 2022 at 6:36 AM
    #728
    Jethog153
    Jethog153 New Member
    2022 White Tundra SR5 TRD Off Road
    Anyone find a good spot for a secondary battery? The engine bay looked packed. Maybe behind the back seat?
  9. Feb 22, 2022 at 7:14 AM
    #729
    jshemmy
    jshemmy New Member
    john
    Milwaukee, WI
    2022 Platinum
    20" TRD rims 295/60/R20 Nit Recon Grappler A/T Window Tint Retrax Ordered Ceramic Coating
    let me know what you think about the dash cam. Never considered one, but this past weekend I did 1000 miles in a wind/snow storm and almost got taken out twice on highway by kids trying to pass me in Honda Accords, very nerve racking!
    ryanwgregg likes this.
  10. Feb 22, 2022 at 7:15 AM
    #730
    Krusher22plat
    Krusher22plat New Member
    22plat
    Good to see but curious if it comes with any other wiring or connectors to hardwire and make connections in headliner or run down to fuse block. I just got my Plat and want to add that along with a Uniden R4. Looking to hide all the wiring.
    Also, doubt it, but does the Toyo cam integrate in any way with the trucks audio visual setup? Thanks.
  11. Feb 22, 2022 at 7:59 AM
    #731
    Krusher22plat
    22plat
    many thanks! I may give that one a shot. I know a number of well regarded cams (I had front an back Streetguard on Tacoma, nice unit) but like this appears fairly simple and straightforward install.
  12. Feb 22, 2022 at 8:16 AM
    #732
    sparky412
    SW Pennsylvania
    Had to look at the install instructions that someone posted to actually see the dash cam that picture kind of focuses on your radar detector
    Krusher22plat and ryanwgregg like this.
  13. Feb 22, 2022 at 9:09 AM
    #733
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Very interested in getting one also.
    I saw another (video) install that was posted on here where the poster said he didn’t get the live view to work (only the recordings).
    I am assuming that an anomaly and not the norm correct?
    - Can someone confirm that the live viewer works also?
    Krusher22plat likes this.
  14. Feb 22, 2022 at 11:05 AM
    #734
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    6721F561-7A3A-44ED-A92A-8AB960D1494E.jpg Taco tunes cat protection plate installed! Had my cat stolen from my F150 so hopefully this will be at least a small deterrent
    TK1979, Henry1jg, EvilSteve and 4 others like this.
  15. Feb 22, 2022 at 11:14 AM
    #735
    DoMoToyota
    DoMoToyota New Member
    Donald
    Monroe, Louisiana
    22 Tundra Limited 4x4 CM Black
    RC 1.75" Leveling Kit Cooper Rugged Trek 275/65r20 Pro Grille Diode Dynamics Grille Lightbar Rave OR Amber Grille Marker Lights GoRhino Dominator DSS Extreme step bars UnderCover Ultraflex bed cover
    Due to my impatience(mostly because my wife is now pregnant and she can already barely get in), I decided to order these -
    https://www.autoanything.com/nerf-bars/go-rhino-rb20-slim-running-boards?VehicleId=9638894
    P.S. they had a Presidents’ Day 21% discount code that worked and still may be active.
    Hope to have em next week and will post pics once I install.
    ToyoTundra89 likes this.
  16. Feb 22, 2022 at 12:21 PM
    #736
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Thanks for the heads up on the 21% discount, i went ahead and pulled the trigger as well. about $100 off is a steal. I'll run these until AMP Research has the PowerStep available for the 22.
    Hope it fits! Will post pictures once installed.
    Bradanglin22 likes this.
  17. Feb 22, 2022 at 12:25 PM
    #737
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    I have the CrewMax as well, did you select extended crew cab or just crew cab? I selected crew cab, hope its right.
  18. Feb 22, 2022 at 12:28 PM
    #738
    WingedHussar
    WingedHussar New Member
    Midwest
    2015 4Runner Limited
    I believe there are 4 cats, does the plate cover all of them?
    Does it need to be removed to do oil changes?
  19. Feb 22, 2022 at 12:35 PM
    #739
    Bradanglin22
    Bradanglin22 New Member
    Brad
    You’re gonna want to contact them and get that changed. I clarified with them prior to placing my order. Crew cab = double cab, extended crew cab = crew max.
    ToyoTundra89[QUOTED] likes this.
  20. Feb 22, 2022 at 12:56 PM
    #740
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Thank you! Reaching out to them now
  21. Feb 22, 2022 at 1:56 PM
    #741
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    so the story just keeps getting stranger...
    Spoke with customer service on the phone and the gentleman couldn't confirm so I then spoke with Jestine B from customer support, and she explained that neither part would not fit the vehicle and that they would only fit prior 2021 2nd gen style models... So I ended up cancelling just in case. Please let me know if the ones you or @DoMoToyota ordered fit. Maybe i just dealt with individuals who didnt know what they were doing.. but I'd hate to receive running boards that don't fit then have to worry about returning them. Please keep me posted on the fit.
  22. Feb 22, 2022 at 5:50 PM
    #742
    Supertech1
    Supertech1 New Member
    Looks like I’ve got an issue…When I ordered on Sunday, the drop down box had a Double Cab or Crewmax option. I selected Crewmax, of course the selector also said these steps would fit 2022.
    Another member actually spoke with their customer service to confirm fit for 2022.
  23. Feb 22, 2022 at 8:23 PM
    #743
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Pretty sure it covers all cats, didn’t count them haha. And no, oil changes are more anterior (under where the TRD skid plate would be). They have good install videos on YouTube that may give you a good look
    WingedHussar[QUOTED] likes this.
  24. Feb 23, 2022 at 5:00 AM
    #744
    Jbeans691981
    Jbeans691981 New Member
    2022 Tundra Sport Lunar Rock
    n/a
  25. Feb 23, 2022 at 7:50 AM
    #745
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Thanks, ended up picking up the oem tube style on Ebay. They look a little more family friendly. I had predator style steps on my last vehicle, so wanted something different. More than what i wanted to pay for a temporary solution, but wife was growing impatient. There is 1 left if anyone is interested.
  26. Feb 23, 2022 at 8:20 AM
    #746
    Scooterman67
    Scooterman67 New Member
    Scott
    2022 SR5 4x4
    I read that Toyota will release a software update around this month to remove the key fob off issue along with other software fixes, I think it mat be delayed some but supposedly will resolve lots of bugs in the programming. I wish they would remove the subscription screen all together unless you actually purchase it, useless unless you want that.
  27. Feb 23, 2022 at 10:22 AM
    #747
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    Just went out to my truck to try getting the .json file but there's not even an option to output to my USB.
    Dmon187 likes this.
  28. Feb 23, 2022 at 10:39 AM
    #748
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    Is there not an option to update from the truck using wifi or something versus plugging in a USB? I thought I saw a video on here a few days ago explaining how to update. I checked for it and there is no update available yet.
    sparky412 likes this.
  29. Feb 23, 2022 at 11:09 AM
    #749
    nmmike
    nmmike New Member
    2022 Tundra CrewMax SR5 TRD
    Dealer installed the TRD Running Boards yesterday. I am generally happy with everything but the price ( $825 plus bolts and tax)
    -these boards are definitely Low Profile, they do not seem to reduce ground clearance much, if any.
    -they mount up high and in close to the truck, but do make it much easier to get in and out of the cab. I don't plan to add a lift kit.
    -I liked these a lot better than the Go Rhinos which is the only aftermarket boards I could find, but again the price difference!!
    -I did not want to wait for more aftermarket choices, we are both about 5'5" and needed boards now. Plus we are going camping next week.
    Bad enough we have to wait for Toyota or Amp Research to have a bed step available.
    Luckily the dealer discounted some in order to make this a little more affordable.RB 1.jpg RB 2.jpg
  30. Feb 23, 2022 at 11:15 AM
    #750
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    I did my oval oem ones the other day and even those feel like its close to the truck. but I was also half hoping sparks personnel screwed up and sent me those instead also
