3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Jan 19, 2022 at 3:58 PM
    #301
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    +1.
    I use my dealership only for parts.
  2. Jan 19, 2022 at 4:00 PM
    #302
    SnowRunnerTundra
    SnowRunnerTundra New Member
    2022 Hyundai Santa Cruz Limited
    I'm not trained mechanic, but in reality, there are only 2 things that need done regularly:
    • oil change
    • tire rotation
    both you can find plenty of tutorial and you save about $100 in labor each time and also you know it's done right.
    Not all dealerships are bad, but EVERY dealership assigns the most novice tech to oil changes and tire rotations especially the prepaid maintenance.
    Common mistakes or neglects are:
    • incorrect oil level
    • oil filler cap not installed
    • over torqued drain plug and filter
    • marred and over torqued lug nuts
    it might surprise you but these mistakes happen a lot, and I just don't want to gamble my luck with them.
    For other things more complicated like a turbo wastegate, I actually trust dealership tech because only master tech gets to work on those issues.
  3. Jan 19, 2022 at 4:18 PM
    #303
    SnowRunnerTundra
  4. Jan 19, 2022 at 4:20 PM
    #304
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    hard to beleive they would go backwards on this but then again.....tow hooks.....
  5. Jan 19, 2022 at 5:27 PM
    #305
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    17 4Runner TRD Pro had to remove the Plate to change the filter. Took a few minutes
  6. Jan 19, 2022 at 5:44 PM
    #306
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Well this sucks…mine is already being shipped
  7. Jan 19, 2022 at 5:50 PM
    #307
    SnowRunnerTundra
    Front my experience with the Tacoma TRD Pro skid plate, which almost weighs about 30 lbs, it's not easy to do 1 person by hand
  8. Jan 19, 2022 at 9:26 PM
    #308
    Hadelson
    Hadelson New Member
    Completed two ways
    1. Lift by hand and attach two anchor points. Definitely the difficult route.
    2. Hockey puck on jack, balance skid plate on top of puck and slowly lift into position
    EvilSteve likes this.
  9. Jan 19, 2022 at 9:45 PM
    #309
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    What is it like 6 bolts?
  10. Jan 19, 2022 at 10:42 PM
    #310
    mountaingroan
    mountaingroan New Member
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Any chance of a group buy with Sparks for the skid plate? Wondering if we could get shipping down a bit more, or maybe free shipping with enough orders....
    malibu dan likes this.
  11. Jan 20, 2022 at 5:49 AM
    #311
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    Any of you guys have experience or ever installed the Westcott pre collar lifts on previous Gen’s? I watched the video and love the look of it. Not sure if I want to pull the trigger on one yet. Curious on how the drive feels and if it is a good product.
  12. Jan 20, 2022 at 6:44 AM
    #312
    wired
    wired New Member
    David
    2022 Tundra Black SR5
    Update on my incorrect step installation yesterday: The dealership was very embarrassed. They got the correct ones picked up last night, are coming to pick up my truck this morning, install the correct ones and return it to me by lunch.
  13. Jan 20, 2022 at 9:16 AM
    #313
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I guess it's a good thing that the Toyota maintenance interval on oil changes is like every 10k miles. But, regardless, removing the skid plate every oil change is still a extra step which creates a minor pain each time.
    I'm still going to pull the trigger on the skid plate post lift & tires.
    Hadelson likes this.
  14. Jan 20, 2022 at 9:16 AM
    #314
    nodak67
    nodak67 New Member
    JR
    go look at the part # on the box.
    if it has c-cab then thats for the double cab
    if it has d-cab then thats for the crew max cab.
    toyota started the cab fitment guide at "A-Cab=single", "B-Cab=ext cab" "C-Cab=double" "D-Cab=crew" if i remember correctly
  15. Jan 20, 2022 at 11:01 AM
    #315
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    Red13, Keeferton and Bradanglin22 like this.
  16. Jan 20, 2022 at 12:13 PM
    #316
    Summit72
    Summit72 New Member
    Summit
    2018 Tacoma TRD OR LB
    Never had any experience with them personally but the way I see it it’s still a spacer lift. I’m sure it rides fine for what it is, I have the rough country level kit (still need a truck to install it on) but if your going for the look and decent drive ability I’m sure you can’t really go wrong by any means. Went with RC simply because it was cheaper and less involved install. Soon I’m sure companies will come out with a actual strut replacement with different spring rates.
    Dmon187[QUOTED] likes this.
  17. Jan 20, 2022 at 1:14 PM
    #317
    KroppDuster
    Bilstein 5100s
    2 Things:
    1) Assuming you got it realigned post RC install, did you do it at an independent shop or the dealer? - Most shops around here don't have alignment specs for the 22's yet.
    2) Did you have loosen the lower control arm or were you able to wedge the coil over assembly back in without doing that? - Just curious because I'm itching to install the RC kit, but if I have to loosen the lower A-arm...I know I'll 100% need an alignment so I'll just wait until the shops here have specs from Hunter.
  18. Jan 20, 2022 at 1:50 PM
    #318
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Is there a way to use the tonneau cover mounts WITH the max mod steel/ alu racks? Since it will take ages (6+ months) to get a topper, I am thinking a tonneau and bed rack option would be clutch for my needs.
  19. Jan 20, 2022 at 2:09 PM
    #319
    KB Voodoo
    Chad
    Yes, all of our Max Modular racks have the option to work with tonneau covers. You would select that option when ordering.
    DexterL[QUOTED] likes this.
  20. Jan 20, 2022 at 2:21 PM
    #320
    Dmon187
    Dmon187 New Member
    DFW
    I think I may hold off for a bit to see what comes out and weigh my options. I want to see what the TRD suspension lift is about abs may go that route. Im not a huge fan of the spacer lifts. Westcott is basically telling us it’s better than just a spacer but it looks the same.
  21. Jan 20, 2022 at 3:13 PM
    #321
    theguz
    theguz New Member
    2022 White Tundra SR5 4x4
    Does anyone know how long the trial lasts for the connected services by Toyota? Like the remote start via the Toyota app and stuff?
  22. Jan 20, 2022 at 3:23 PM
    #322
    theguz
    theguz New Member
    What does the group prefer for mats. The Toyota ones or wait for the weather tech?
  23. Jan 20, 2022 at 3:28 PM
    #323
    theguz
    theguz New Member
    I’m getting the 2in level kit done (front only) next week by Tim Duncan’s off-road shop “Blackjack” here in San Antonio. They say they have done a bunch of them for the dealerships daily so will post pictures once done.
  24. Jan 20, 2022 at 3:32 PM
    #324
    theguz
    theguz New Member
    Do you think a alignment is necessary after just a leveling kit install?
  25. Jan 20, 2022 at 3:34 PM
    #325
    KroppDuster
    Bilstein 5100s
    I'm fairly impressed with the OEM ones. I usually run WeatherTech and have always been impressed with them. Though my current ones, after 9 years of use, have started to wear through a little.
    It's wet & muddy here right now and I couldn't wait. So I bought the OEM ones for the first time ever. Are they as "good" as the WeatherTech mats? No because they don't have the high lip, but other than that...I like them. My 2 cents.
    murtro and rideandfly like this.
  26. Jan 20, 2022 at 3:38 PM
    #326
    KroppDuster
    Bilstein 5100s
    Yes. Especially, if you follow the RC install instructions and loosen the camber bolt on the lower control arm. Even if you mark everything with witness marks and line everything back up during reassembly...it'll still be out of alignment ever so slightly.
    Some folks can probably get by without doing one, but I drive ~550 miles a week. Even a minor degree of misalignment will eat up my tires and show up pretty fast since I drive so much.
  27. Jan 20, 2022 at 3:47 PM
    #327
    theguz
    theguz New Member
  28. Jan 20, 2022 at 3:48 PM
    #328
    theguz
    theguz New Member
    Great point.
  29. Jan 20, 2022 at 3:52 PM
    #329
    KroppDuster
    Bilstein 5100s
    I just got the OEM letter inserts in the mail on Tuesday. They're not just cut vinyl letters. The OEM ones are legit hard rubber /resin / pvc (not exactly sure of the material), raised letters. I was kinda shocked. I expected just thin vinyl letters like the aftermarket ones. I haven't put them on yet. I'll probably do that this weekend when I can clean the tailgate properly to ensure adhesion.
  30. Jan 20, 2022 at 3:53 PM
    #330
    theguz
    theguz New Member
    Thanks! Be sure to post pics!
