3rd Gen 3/1 lift pics anyone?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Surfthetundra, Oct 5, 2015.
  1. Jan 14, 2019 at 10:59 AM
    #91
    Blackbetty
    Blackbetty New Member
    @KELZ84 that is the toytec 3/1. Spacers in the front. 1 inch block in the back. No rake in the front at all. Thanks!
    KELZ84 likes this.
  2. Jan 14, 2019 at 5:34 PM
    #92
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
  3. Jan 15, 2019 at 7:41 AM
    #93
    DiegoC
    DiegoC New car smell
    Diego
    2016 White Tundra Limited
    ReadyLift SST 3/1 Level Lift W/ sum 35's
    3/1 SST leving kit from readylift on 35 Toyo MT’s
    J&ATundra, Dgjman, onetohunt and 2 others like this.
  4. Jan 15, 2019 at 9:10 AM
    #94
    amazingswami
    amazingswami New Member
    Which wheels are those?
  5. Jan 15, 2019 at 9:21 AM
    #95
    DiegoC
    Diego
    They are 18x9 Method NV 305 Bronze with a +25 offset.
    amazingswami[QUOTED] likes this.
  6. Jan 17, 2019 at 7:28 PM
    #96
    Manventurer
    Manventurer New Member
    Josh
    Nashville, TN
    2019 Tundra Limited
    3”/1” lift, 18”x9” replica Pro wheels, 35x12.50r18 Ridge Grapplers, Tint, Chrome Delete.
    3/1 lift w 285/75r18
    100LL, Mattco808, GHOST and 8 others like this.
  7. Jan 18, 2019 at 5:41 AM
    #97
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
  8. Jan 18, 2019 at 5:40 PM
    #98
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Did you have any rubbing? Looks great!
    DiegoC[QUOTED] likes this.
  9. Jan 18, 2019 at 6:27 PM
    #99
    Manventurer
    Josh
    Nashville, TN
    2019 Tundra Limited
    Nitto Ridge Grapplers.
    KELZ84[QUOTED] likes this.
  10. Jan 18, 2019 at 6:33 PM
    #100
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
  11. Jan 18, 2019 at 6:38 PM
    #101
    LTtundra15
    LTtundra15 New Member
    2015 1794 lifted
    Lifted,wheels,tires,light bar, custom grill color
    4” with 35’s don’t do 33’s
    Doesn’t rub with A/T tires M/T might based on outside tread
  12. Jan 19, 2019 at 10:54 AM
    #102
    DiegoC
    Diego
    Yes there was rubbing all plastic. Nothing a heat gun and angle grinder couldn’t fix
    Js18tundra[QUOTED] likes this.
  13. Jan 19, 2019 at 10:54 AM
    #103
    DiegoC
    Diego
    Also thank you !!
  14. Jan 19, 2019 at 12:46 PM
    #104
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Exact route Im going just with 2” rear lift for some rake. Man looks good
  15. Jan 20, 2019 at 5:55 AM
    #105
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    what 4" kit did you go with ?
  16. Jan 20, 2019 at 7:49 AM
    #106
    Alta0
    Alta0 New Member
    tbutler likes this.
  17. Jan 20, 2019 at 9:38 AM
    #107
    LTtundra15
    2015 1794 lifted
    4” rough country
    Dgjman likes this.
  18. Jan 21, 2019 at 7:44 AM
    #108
    DiegoC
    Diego
    what light bar is that??
  19. Jan 21, 2019 at 1:49 PM
    #109
    LTtundra15
    2015 1794 lifted
    Rough country 30” it’s to bright to use at night on main roads would blind people driving coming at you or in front of you.
    Dgjman and DiegoC like this.
  20. Sep 16, 2019 at 7:49 AM
    #110
    TundraTRD5300
    TundraTRD5300 New Member
    2017 Tundra TRD
    2inch Leveling Kit
    Do you haul/tow/off-road with that? If so, how's it handle? Any sag? I got a Revtek 2.5/1.5 and haven't hauled/towed anything yet. But I also have Sumo Springs (replaced bump stops) in the rear and Super Coil Springs between stock coils to hopefully help with the hauling/towing. Thanks!
  21. Sep 17, 2019 at 2:40 PM
    #111
    DES01068
    DES01068 New Member
    2019 cavalry blue limited tundra
    3.5 rough country lift Fuel Trophys ARE Cap
    new member and new to the tundra, ready to lift it how does these kits ride and how bad are the cv angles and uca angles?
  22. Sep 17, 2019 at 3:33 PM
    #112
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Close enough, 3/1.5" with 37's...
    Paxrom, Mattco808, Ryuu and 1 other person like this.
  23. Sep 17, 2019 at 3:38 PM
    #113
    Ibanez6224
    Ibanez6224 New Member
    2019 TRD OR
    How much trimming did you need to do?
  24. Sep 17, 2019 at 7:59 PM
    #114
    TrdLtd26
    TrdLtd26 New Member
    3/1 bilstein 5100’s
    295/70/18 34”
    Mattco808 likes this.
  25. Sep 17, 2019 at 8:05 PM
    #115
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    So what did you add in the back?
  26. Sep 17, 2019 at 8:11 PM
    #116
    TrdLtd26
    TrdLtd26 New Member
    Toytec shackles set at 1”
  27. Sep 18, 2019 at 1:00 PM
    #117
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    You people with your superchargers....:hattip: Some of us half to wait for Bully Dog to complete the tune before we can have it so good :annoyed:. Not sure if I notice the tires or not. I never bothered to drive the truck when it was stock.
  28. Sep 18, 2019 at 1:03 PM
    #118
    GasGuzzler
    2019 Tundra
    Damn, was that pic taken at the dump? The Truck looks great but not sure about all the trash?
  29. Sep 18, 2019 at 5:48 PM
    #119
    TrdLtd26
    TrdLtd26 New Member
    Yea people seem to forget what a trash can is for.
    GasGuzzler[QUOTED] likes this.
  30. Sep 18, 2019 at 5:51 PM
    #120
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    i can tell by the trash, California?
