3rd Brake-Work Light Options
Discussion in 'Lighting' started by fireman_pete, Jan 31, 2022.
  1. Jan 31, 2022 at 3:29 PM
    fireman_pete
    fireman_pete [OP] New Member
    Pete
    2021 SR5 Trail Edition
    I am looking at options for some really bright work lights for the bed of the truck. The cargo lights in the 3rd brake are just not enough (even with super bright bulbs).
    Has anyone done a mod, or seen an option to install a BD type Rock light off of the 3rd brake light, and make it look good/clean?
    I was going to install two lights on the front rail of the bed, but I would really prefer them to be higher up.
    Any options/suggestions?
    Here is a product for a 3rd brake light mount with an antenna and two BD Rock lights. Unfortunately, it is not (currently) available for the Tundra.
    Baja Designs and TTracer like this.
  2. Feb 5, 2022 at 11:44 AM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    I added a flush mount s2 work light. In a angled rago mount to my roof rack
    At the same time I rewired my third brake light to be all three brake light bulbs
  3. Feb 5, 2022 at 11:49 AM
    What the!?
    What the!? New Member
    2017 Pro
  4. Feb 5, 2022 at 12:24 PM
    TTracer
    TTracer New Member
    Daniel
    California
    2014 black tundra LT
    -Long travel -King Shocks all around with valving -paddle shifters -cutting brake with wilwood brakes -dap tune - custom front bumper -switch pros - gps - race radio -custom 3rd brake light - ultra wheel-
  5. Feb 5, 2022 at 12:25 PM
    TTracer
    TTracer New Member
    Daniel
    California
  6. Feb 5, 2022 at 8:58 PM
    fireman_pete
    Pete
    Thanks. I was not aware of this. I will definitely check it out. How easy was it to install? Does it use the existing mounting screws/holes?
    TTracer[QUOTED] likes this.
  7. Feb 5, 2022 at 9:51 PM
    TTracer
    TTracer New Member
    Daniel
    California
    You have to drill 4 holes then with the supplied hardware you put 4 nut inserts in and screw it down hardest part is taking the old light out
  8. Mar 14, 2023 at 7:58 PM
    Rudyrod1794
    Rudyrod1794 New Member
    Rudy
    Orange, CA
    2019 Smoked Mesquite 1794
  9. Mar 14, 2023 at 8:00 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Another vote for the Evil MFG unit. Install is a pain but worth it
    Baja Designs likes this.
  10. Mar 16, 2023 at 10:39 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Hey @fireman_pete, There are a ton of different options on the market for the third brake light. I just wanted to mention for all the options utilizing our S2 lights we offer interchangeable lenses with our Uservice program. What this means for you is that if you do get a clear lens initially and want to change to amber or even a different lens pattern to achieve a different zone we sell replacement lenses that can be switched out. Depending on the 3rd brake light you get may interfere with this option but from a light standpoint, it will be present.
    Best,
    Brandon
  11. May 23, 2023 at 3:30 PM
    AND
    AND New Member
    Washington, PNW
    Any companies making these for the 3rd gen Tundra yet?
