3MXDIVR slow steady OVERLANDER progress....
Discussion in '2.5 Gen Builds (2014-2021)' started by 3mxdivr, Nov 3, 2018.
  1. Nov 19, 2018 at 9:03 PM
    3mxdivr
    3mxdivr [OP] New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    I probably have to hit you up with more questions. But looking at all the pics on the BAMF site and it looks really good, plus can kinda pick and choose what you want as mounting points on the sides. What leafs did you go with for the rear? I have the Kings front and rear with the icon delta UCAs. Was debating whether to go with icon add a leafs or the whole rxt leaf. The truck only has 1200 miles on it.
  2. Nov 19, 2018 at 9:26 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    I can talk trucks all day/night(im on a graveyard shift so my day just started)!!
    Did you get the tubular deltas?? I went with the RXT multirate pack. It's a good pack, with the options. Held up the weight without too much compromise on them. At the first option they run flat fast. With my "normal" weight they went flat within a week.
    GodlessPro likes this.
  3. Nov 20, 2018 at 4:08 AM
    3mxdivr
    NorCal
    Yup went with the tubular deltas. Hope I do not need to cutoff tie rods for alignment. Plus Icon said if i go 3 inches i shouldn’t have too. And since i got the extended travel kings i could go a “lil” higher.
    I was thinking of trying the add a leafs from Icon since my truck’s new and see. Then just replace the whole leaf once it flattens out. But I was also thinking $275 for add a leafs or just go the multi rate for $750 + 15% off BF..... buy once cry once.
    dcsleeper408[QUOTED] likes this.
  4. Nov 20, 2018 at 11:41 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I would say get the whole pack.
    Give @sdhq_offroad a holla or @Wheeler's Off-Road Inc a holler.
  5. Jan 24, 2019 at 6:43 PM
    3mxdivr
    NorCal
    Been busy the past couple months but still progress with the truck.
    Installed the Kings, Icon Delta UCAs, Icon add a leafs, CB Shackles, Wheels, Tires, and Baja Designs fogs and rear lights.
    Just waiting for the switch pros, Baja designs XL80s, Max Modular (kb voodoo) rack, and dual battery setup arriving in the next week!
    Then still debating which slider to go with.
    Never Ending!.....
  6. Jan 26, 2019 at 7:31 PM
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    Awesome build! Hoping I can ask a few questions. What is your wheel and tire setup? What height rack are you going for and why? Is that the OEM TSS cover on the grill or aftermarket? I’m trying to avoid spending 300 on a 3x5 piece of plastic. @3mxdivr
  7. Jan 26, 2019 at 7:59 PM
    3mxdivr
    NorCal
    Sure thing bro....
    Wheels= VTX Viper 18x9
    Tires= Toyo Open Country MTs
    35x12.5x18
    Rack= KB Voodoo Alumax 10” modular rack
    Went this route because my RTT is hoisted up on my garage. And i park the truck in the garage. So i just set the tent on the rack and pull out of the garage.
    Grill garnish= no not oem. Just cut a peice of lexan until i decide what rout to go. Most likely OEM grill garnish.
  8. Apr 2, 2019 at 10:23 AM
    3mxdivr
    NorCal
    Been lagging with posting updates due to never ending truck projects, camping, and work..... so here are more pics of additions to the truck.
    Finishing up dual battery system and switch pros install..... tedious work!
    joonbug and dcsleeper408 like this.
  9. Apr 2, 2019 at 10:26 AM
    3mxdivr
    NorCal
    and added some protection on the trails.....
  10. Apr 7, 2019 at 5:16 PM
    3mxdivr
    NorCal
    After long tedious process..... Switch pros & Red Arc dual battery setup using Genesis off road tray is 95% done!
  11. Jun 8, 2019 at 12:12 PM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    What is the process for getting those rear lights in? Is there a good DIY thread?
    Man I was hoping to put off my switch pro a year but if I get those I’ll need it.
  12. Jun 8, 2019 at 12:55 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Very nice!
  13. Jun 9, 2019 at 12:46 AM
    reno_tundra
    reno_tundra New Member
    2019 White Tundra CM SR5
    Awesome build! Did you do a BMC to fit those tires? Is there any rub? Thanks!
