39's! How to, pictures and questions...
Discussion in '2.5 Gen Tundras (2014-2021)' started by STravis, Dec 5, 2023.
  1. Dec 5, 2023 at 2:23 PM
    STravis
    STravis [OP] SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    I'm creating this thread to document how I'm going to properly make 39" tires fit on my tundra without requiring a drop bracket lift.
    If you want to add to the thread feel free. Please post lift/suspension specs, trimming required and any other mods needed.
    Truck : 2017 TRD Pro with ADS Coilovers, MCM UCA's, superbumps, custom Alcan leaf springs, ADS 3 tube bypasses.
    Lift amount : front 3-3.5", rear 4".
    Trimming : relocated mody mount, front fenders cut 1.5", rear tbd, tubbing tbd.
    Custom bumpers by me @ S.O.B. Fabrication.
    Current photos.
    PXL_20231205_205614748.PORTRAIT.ORIGINAL.jpg PXL_20231205_205631233.PORTRAIT.ORIGINAL.jpg
  2. Dec 5, 2023 at 2:23 PM
    STravis
    Travis
    Ruidoso, NM
    Here is what the truck looked like the first day with the 39's. It was completely street driveable and even went out a few weekends camping with it set up like this. All it had at the time was a very aggressive body mount chop and the pinch weld was cut, "zippered", and hammered back a bit. This setup cleared 37's lock to lock and fully compressed.
    PXL_20230918_233708103.PORTRAIT.jpg PXL_20230921_184542442.PORTRAIT.ORIGINAL.jpg PXL_20231005_233705543~2.jpg PXL_20231005_234801824.PORTRAIT.ORIGINAL~2.jpg PXL_20230921_184649137.jpg PXL_20231014_164154889~2.jpg
  3. Dec 5, 2023 at 2:24 PM
    STravis
    Travis
    Ruidoso, NM
    Next order of business was a body mount relocation. I used the DRT kit for my relocation and it's a well built and thought out kit. I had an older body mount relocation on my old Tacoma and eventually had frame cracking where the mount landed on the frame, but this kit comes with a frame plate that should spread that stress point out and shouldn't have any issues.
    The install for these kits is pretty straightforward and simple, the most time consuming part is getting the old mounts cut off.
    PXL_20231018_212539717.jpg PXL_20231026_214822725.PORTRAIT.jpg PXL_20231027_164937434.PORTRAIT.jpg
    Fobroader, TOYOTARIG, D4x4TRD and 3 others like this.
  4. Dec 5, 2023 at 2:24 PM
    STravis
    Travis
    Ruidoso, NM
    With the body mount out of the way the next step is the front fenders. I made a quick tool similar to what I used when I did my Tacoma. This was inspired by @n0rth way back in the day when he cut up his tacoma. Actually, most of my mod addiction is because of him. The tool is a simple piece of steel with a hole for a bolt and the other end has a hole for a pen or marker. I decided to cut 1.5" out of the fender. Make sure to pull the fender liner out prior to making the fender.
    PXL_20231205_190359395.PORTRAIT.jpg PXL_20231205_190117816.PORTRAIT.jpg PXL_20231205_190530027.PORTRAIT.jpg PXL_20231205_191234988.PORTRAIT.jpg
    After you get the line drawn, check for any obstructions and get to cutting.
    People use a variety of tools for this job, but in my option the only tool to use is a jigsaw with a quality metal blade for the fenders. It cuts very easy without burning the paint and makes the curves easy.
    And boom, just like that they're cut. I used an edge trim from trim lok to finish the cut edge after I touched up the paint.
    I also built a new bumper with 1.5" taken out of the wings to fit the new fender line. It's at powdercoat now and should go back on next week.
    Link to secondary air injection pump intake relocation : https://www.tundras.com/threads/39s-how-to-pictures-and-questions.134519/page-2#post-3419612
  5. Dec 5, 2023 at 2:24 PM
    STravis
    Travis
    Ruidoso, NM
    It's pretty simple to get the rear fenders clearanced. I used the same method as the front fenders, but I only took an inch out of the rears instead of an inch and a half. I chose to do less because I can get away with it and my truck has a little rake to it and this will make it appear visually to be closer to level.
    PXL_20231215_235119326.PORTRAIT.ORIGINAL.jpg PXL_20231215_235126103.PORTRAIT.ORIGINAL.jpg PXL_20231215_235142711.jpg
    I will be building a new rear bumper to match the new fender line as well.
    Also, the bedside lost some stability due to cutting out some supports. I don't think it will cause any issues, but I may come back and build some supports to tie it all back together.
    equin and LarryDangerfield like this.
  6. Dec 5, 2023 at 2:24 PM
    STravis
    Travis
    Ruidoso, NM
    Saved 5
  7. Dec 5, 2023 at 2:24 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    :popcorn::popcorn::popcorn:
    STravis[OP] likes this.
  8. Dec 5, 2023 at 3:06 PM
    STravis
    Travis
    Ruidoso, NM
    Here are a few pictures on my old Tacoma on 37's. Should be about the same process for the tundra.
    IMG_20190301_140900445.jpg IMG_20190301_101717827.jpg IMG_20190228_163609020.jpg IMG_20190301_101833336.jpg IMG_20190313_130625635.jpg IMG_20190824_174148393_HDR.jpg IMG_20190824_174157929_HDR.jpg 18075~2.jpg
  9. Dec 5, 2023 at 3:13 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    First I was worried you were a mall crawler since you mentioned lift which as we know doesn't matter for "properly" clearing. But then this post gave me hope back :D Awesome thread, first time I've actually seen someone truly clear tires on a Tundra (though to be fair I only go on the supercharger threads).
  10. Dec 5, 2023 at 3:43 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Looks good :thumbsup:
    STravis[QUOTED][OP] likes this.
  11. Dec 5, 2023 at 3:52 PM
    STravis
    Travis
    Ruidoso, NM
    You are definitely the man in the boost threads for sure. Hopefully this truck will have some of your parts one day like my shop truck!
    And yeah, lift doesn't do anything for clearance. I changed it to lift/suspension haha.
    This truck is not a rock crawler but I'm building it to let very few things stop me. I want it to go wherever I point it and then camp comfortably when I get there.
  12. Dec 5, 2023 at 3:52 PM
    STravis
    Travis
    Ruidoso, NM
    Thanks! The fender cut looks cool in person with the big tires.
  13. Dec 5, 2023 at 4:05 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Here we go!
    CaptRussia253 and STravis[OP] like this.
  14. Dec 5, 2023 at 4:29 PM
    STravis
    Travis
    Ruidoso, NM
    Glad you posted in here man! Did you do the sdhq relocate for the secondary air pump or just delete the system?
    reywcms[QUOTED] likes this.
  15. Dec 5, 2023 at 4:40 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I made my own secondary relocation setup. Easy to do.
  16. Dec 5, 2023 at 4:41 PM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    Looks great Travis, I'll never forget the look on your face when I took the plasma cutter to the fenders on your old 1st gen....hopefully I can get my junk back together soon and come out and to do fire watch in the cab when you do the tub. I would hate to see a bullhas go down.
  17. Dec 5, 2023 at 4:43 PM
    STravis
    Travis
    Ruidoso, NM
    Haha I would too.
    Still need help with the rear diff?
    n0rth[QUOTED] likes this.
  18. Dec 5, 2023 at 4:55 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    You know in a way it’s unfair that you can build your own bumpers. New one on every few months haha.
  19. Dec 5, 2023 at 4:57 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Looks great! :thumbsup:
    Wish I had the guts to cut my fenders like that, then I’d be able to put on the pro comp fenders I have sitting in my garage lol
  20. Dec 5, 2023 at 5:14 PM
    STravis
    Travis
    Ruidoso, NM
    It really enables me to make drastic changes on a whim haha. I probably wouldn't do the stuff if I couldn't do it myself.
    CaptRussia253[QUOTED] likes this.
  21. Dec 5, 2023 at 5:16 PM
    STravis
    Travis
    Ruidoso, NM
    It's easy. It didn't even take me thirty minutes to tape, mark and cut them. A jigsaw makes it simple.
  22. Dec 5, 2023 at 6:06 PM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    I’ll let you know, hopefully I have the truck back together this weekend.
  23. Dec 5, 2023 at 7:06 PM
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
  24. Dec 6, 2023 at 3:41 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    39s the new 37s?! :rofl:
    STravis[OP], CaptRussia253 and n0rth like this.
  25. Dec 6, 2023 at 5:30 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Your truck is quickly becoming one of my favorites. Quality work
  26. Dec 6, 2023 at 5:59 AM
    CaptRussia253
    Ruslan
    Agreed!
  27. Dec 6, 2023 at 6:06 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Other than the work to physically fit 39s, do you have to beef up other components to handle them? Steering in particular is where my mind goes. What gears do you plan to use?
    sweet truck, btw :thumbsup:
  28. Dec 6, 2023 at 6:16 AM
    STravis
    Travis
    Ruidoso, NM
    I've already got 5.29's. We'll see what becomes the weak point. Maybe tie rods? I will probably do spindle gussets sooner than later, but nothing planned yet.
  29. Dec 6, 2023 at 7:51 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I love how the extra bit cut out of the front fenders make the truck look way "lighter" if that makes sense. Such a sweet rig!
  30. Dec 6, 2023 at 7:54 AM
    STravis
    Travis
    Ruidoso, NM
    I agree, it's only an inch and a half but it changes the look quite a bit.
    BreyTundy[QUOTED] likes this.
