38 gallon fuel tank is a joke 2019 TRD PRO
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Bill Cogan, Nov 5, 2018.
  1. Nov 5, 2018 at 8:49 AM
    Bill Cogan
    Bill Cogan [OP] New Member
    Bill
    2019 Tundra TRD PRO
    So I realize my tundra has one of the worst gas mileages of any truck. But i was ok with it; especially since they have the 38 gallons fuel tank option.
    What a joke.
    The issue is the gauge in the truck is only accurate for the stock 28 gallon tank! Lame.
    Essentially the gauge only accounts for 28 gallons.
    I bought this assuming the 38 gallon tank and the gas gauge worked accurately.
    nope.
    I took it in to the dealership and none of the salesmen or mechanics knew about this. Not cool. They said that it is a 38 gallon tank but that theres an "air gap at top" and "once you put in the fuel pump" your down to around 28 gallons. What a joke. bullshitting me.
    They should disclose this to buyers. Never seen anything like it. I liked the idea of a 38 gallon tank and having a decent mile range.
    But the dam "low fuel" light comes on and I'm lucky to get 375-400 miles per fill up.
    If they provide a 38 gallon tank-- the gauge should be accurate to that many gallons......
    MaxMB likes this.
  2. Nov 5, 2018 at 8:53 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    The smaller tank is 26.9 and the light comes on around 20 gallons. The over cautious gas light is a very common complaint.
    FlyingWolfe, Jsnake89, Ike74 and 5 others like this.
  3. Nov 5, 2018 at 8:55 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
  4. Nov 5, 2018 at 8:56 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Toyotas light comes on early. Really early. In my 2012 i went past the light, past the E and filled up with close to 25 gallons out of the 26 gallon tank.
    You have close to 38 gallons in that tank. You can use it if needed.
  5. Nov 5, 2018 at 8:57 AM
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
    Interesting...
  6. Nov 5, 2018 at 8:58 AM
    Yep....at "zero" miles I have about 6 gallons left in my 26 gal tank. Quite used to it. A built in reserve that will get another 60 to 80 miles depending on my speed. I have never gone below "zero" yet. Plenty of gas stations. The fuel pump also needs to be immersed in fuel.
  7. Nov 5, 2018 at 9:00 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    the most ive ever filled in my 38gal was 33 gallons I believe. of course there is going to be a reserve for the guys that run past "0 miles to empty", but I think for the most part it's pretty true
    FlyingWolfe and Beesta like this.
  8. Nov 5, 2018 at 9:01 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Keep in mind that the 38 gallon tank is about 5' or 6' long. When you go down hill (or vice versa uphill) with an almost empty tank, you will have all the fuel in the front of the tank and nothing in the back. To keep the fuel pump submerged (or at least have access to fuel) it has to keep a minimum amount of fuel in the tank to always keep fuel available to the pump. I have also read that it is to keep the pump cool, but the physics of a long tank is the actual reason why you cannot run it empty. And the bigger (longer) the tank is, the more fuel will be needed, which is why the 38 gal tank has a bigger 'reserve' than the standard 26 gal tank. If you could have a 38 gal tank that is in the shape of an upright tube, this would not be necessary.
  9. Nov 5, 2018 at 9:10 AM
    Marty McFly
    Morty McBoonJug
    What a shame. You should probably look into buying a Ford. Much better than Toyota.
  10. Nov 5, 2018 at 9:21 AM
    dud13
    dud13 níl aon tinteán mar do thinteán féin
    2018 MGM 1794 4WD 5.7 (noFFV)
    See Info Page DeChroming... in progress.
    Forgot to add: :rofl:
    59nascar, Tundyfundy, Kerktam and 7 others like this.
  11. Nov 5, 2018 at 9:34 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Sounds like a class action lawsuit waiting to happen.
  12. Nov 5, 2018 at 9:35 AM
    Rakso
    Oskar
    Uffffffffffffff :boink:
    14burrito likes this.
  13. Nov 5, 2018 at 9:38 AM
    15whtrd
    15whtrd Mr. Blonde
    Stupid physics. How dare it!
  14. Nov 5, 2018 at 9:39 AM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    I guess I'm the only one that doesnt mind having a extra 5-6 gallons of fuel instead of the low fuel light popping up and having to rush to the nearest gas station
  15. Nov 5, 2018 at 9:40 AM
    15whtrd
    15whtrd Mr. Blonde
    This could be cured with one of those fuel mat pick up devices that hot rodders used.
    Blueknights75 and Marty McFly like this.
  16. Nov 5, 2018 at 9:45 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I have the smaller tank and I get about 220 to the tank...I think your making out on the bigger tank.
    Beesta, Ike74, UNTMatt and 7 others like this.
  17. Nov 5, 2018 at 9:45 AM
    Blueknights75
    Ron
    Clayton, NC
    First off, welcome Bill! You are obviously very passionate about this issue. Some other members have voiced their concerns regarding this issue.
    I would have to disagree with you in regards to the worst vehicle mileage as I average 19mpg (I do drive like a grandma though). My previous truck got 13.5 average mpg. So a lot of it is dependent upon how you drive as well.
    Good Luck with your truck and show us some pics of that beauty!
    Dupey, Beesta, woodcan and 6 others like this.
  18. Nov 5, 2018 at 9:47 AM
    Marty McFly
    Morty McBoonJug
    Great idea bud. Leeeggggooo
  19. Nov 5, 2018 at 9:48 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Now I know what Beast Mode is I'm getting about 12-14 mpg...thanks guys! :annoyed:
    Not getting in the throttle I get 425 or so on a tank, fill up at about 1/4 tank, I'll take that.
  20. Nov 5, 2018 at 9:49 AM
    Run your truck out of gas. Have 15 gallons of fuel in Jerry cans in the bed. I bet you put another 22.5 gallons in when stopping at the next fuel station.
    All the auto manufactures do this "reserve" thing. This might be a surprise to you, but there are many people each year that actually run out of fuel. You see them all the time walking down the road with the little red gas can. Now if you were offering free roadside assistance for 2 years, wouldn't you make damn sure the average idiot doesn't run out of fuel three times per year?
    Luckster, next_z, Kerktam and 25 others like this.
  21. Nov 5, 2018 at 9:54 AM
    Newm
    Newm New Member
    KC
  22. Nov 5, 2018 at 9:59 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Had the same issue with my Jeep. It had a 22.5 gallon tank and I could never put more than 19 gallons in it even when it was on E and the warning told me I had zero miles left.
  23. Nov 5, 2018 at 10:03 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  24. Nov 5, 2018 at 10:10 AM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    This - exactly!
  25. Nov 5, 2018 at 10:22 AM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    I'm new to this site but I'm already sick of people crying about how horrible the Tundra is because of little meaningless issues! Get a life already! They're just making themselves look like self absorbed cry babies! Boy that felt good. I'm done.
    59nascar, Ginsterkev, next_z and 30 others like this.
  26. Nov 5, 2018 at 10:30 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    You filling right when light comes on? I can get 33 gal if I drive on E for awhile. You have a 6 gal reserve. Enjoy the truck.
    59nascar, Beesta, sdde4n and 3 others like this.
  27. Nov 5, 2018 at 10:34 AM
    Boosted4runner
    WA
    I have a 26 gallon tank - and have figured out how to use it :D
  28. Nov 5, 2018 at 10:42 AM
    War Machine
    War Machine SSEM # 5 3MW
    I thought you didn’t need gas where you’re going?
  29. Nov 5, 2018 at 10:50 AM
    Marty McFly
    Morty McBoonJug
    I need plutonium :anonymous:
    Beesta, Tundyfundy, Ostrich and 4 others like this.
  30. Nov 5, 2018 at 10:56 AM
    War Machine
    Check with @thelibyans.
