38 Gal tank experiences....
Discussion in '2.5 Gen Tundras (2014-2021)' started by KeithM, Mar 19, 2018.
  1. Dec 4, 2019 at 1:01 PM
    #181
    AdventureAddict
    AdventureAddict New Member
    Josh
    19 Cement Limited TRD off road
    I have never filled up more than 30 gallons, but I dont usually run it all the way to the end. Although I think its silly its advertised as 38 and only really around 30-32, realistically for me that is big enough
  2. Dec 4, 2019 at 1:08 PM
    #182
    AdventureAddict
    Josh
    Haha Yup! My truck was 560 range when full when I first got it and now 6 months later its about 525
  3. Dec 4, 2019 at 2:05 PM
    #183
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    Before my 1st lube oil/filter change, i.e., 5K, my truck range was 500. Afterwards, after every re-fuel to full tank, range is 490...wonder why? May be because of not so good driving habits?
  4. Dec 4, 2019 at 2:08 PM
    #184
    Jpneely
    Jpneely New Member
    White SR5 5.7
    Does the computer take into account winter fuel vs summer fuel? I know mine dropped from 560 to 540 miles pretty suddenly too. That's all I can think of
  5. Dec 4, 2019 at 2:13 PM
    #185
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    @Jpneely: No idea about computer assumptions. Temps here during days is around low 40s to upper 60s. Yesterday, I travelled almost 400mi and about 80% highway; fuel eco is 15.88mpg (manual compute).
  6. Dec 4, 2019 at 2:21 PM
    #186
    Jpneely
    Jpneely New Member
    White SR5 5.7
    That's about the same temps here too. I know my milage had always dropped in the winter a bit ( even though we rarely ever see a "winter") due to fuel mix changes. I just assumed this fancy smart truck was taking that into account haha
  7. Dec 14, 2019 at 8:02 AM
    #187
    cropduster7
    cropduster7 New Member
    For those of you complaining about not being able to use 38 gallons, there’s a simple explanation. Close the drain and put 1 gallon of water in your bathtub. You can tell it spreads out a lot. Now imagine that pickup tube somewhere in the middle and you will see it will take a few more gallons before anything can be sucked up a tube without a lot of air especially considering sloshing around.
    GODZILLA and g35man like this.
  8. Dec 16, 2019 at 8:42 AM
    #188
    HellBent
    HellBent Breaker of Things
    Brayden
    2017 SR5 TSS 5.7
    * Didn't read all 7 pages
    Was aware of the large "reserve" on these big tanks when I bought my '17 - from having read it on this forum when researching the purchase.
    Ran mine dry a month or 2 ago (accidentally, I miscalculated my miles on the tank after forgetting to trip my ODO after the last fill-up) - thought I had PLENTY in the tank to make it to the next town where gas is +/- 20 cents less per gallon. Had been driving a couple days with the light on just out of curiousity.
    Was able to coast into the pump and put in over 37 gallons (Dang near 38). I'm a bit more cognizant of my tank level now, but I do know that I've got a solid 100 miles left in the tank when the light goes on....
    65SNAKE, ClaytonW, Wallygator and 6 others like this.
  9. Dec 16, 2019 at 9:37 AM
    #189
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    I love this "feature". My old 01 had a 26 gallon tank, maybe put 20-21 gallons in at the most when the light came on. It's something I never minded, and I continue to appreciate it with my new 38 gallon tank. :notsure:
    Wallygator and Cpl_Punishment like this.
  10. Dec 19, 2019 at 11:26 PM
    #190
    sumgai
    sumgai New Member
    19 trd sport
    new to forum, tundra's since 2012. then a 2015, my newest 2019: OMG, I can read the instruments in daylight! parking assist, LDA, rcta! died and gone to heaven. (most important mod: driver side grip handle added) but. 38 gal tank and what appears to be the old 26 gallon fuel gauge. come on toyota, can't we all just do digital gas gauges for accurate measurement? but, the actual gas mileage is falling off the cliff. downgraded from 8 ft to 6.5 ft DC 4wd this time. not flex-fuel. First few tanks 17+ mpg! heaven in a truck. then put a cap on, more aero dynamic my aunt nannies fanny: 16 mpg. now winter, 9k on odo, my first leg 497 miles the instant fuel said 14.7 mpg. what has happened: Winter blend fuel?
    anyhow, will do low fuel light running at least until the end of the 3/36, unless toyota issues a technical service bulletin saying "don't do that!" Hate thought of carrying 48lbs of unusable fuel. Cold outside, hope it helps cool the pump. it was frost overnight on the Tundra in Hardeeville. and I need the range. i got $2.249 gallon gas in hollywood, fl. From there until Hardeeville SC, gas crooks on every i95 off-ramp. Yesterday I was running fumes till hardeeville. 48 miles into the low fuel warning. but i had over a dollar off/gal coupon at shell and had a shell station for $2.179 outside Florence. So I put 12 gals in ( est range 160 miles) in hardeeville $2.199/gal. low fuel came on again outside Florence. SC. 55 miles on low fuel light. Complete fill up at shell outside Florence. 35.11 gal. so, 11 mpg for 5 gals into the 8 gal reserve? total 88 miles range on the reserve 8 gals? that's a disappointment. 14.1 mpg (actual gals to miles) from Hollywood FL-Florence SC. cruise set at: "maintaining traffic flow officer" appx speed: limit plus 10-12%.
    I used to run two 20 gal saddle tanks on Silverados, one tank sputters, hit the switch to the other tank and hope the switch isn't broken. Why they stop that? oh, i remember, exploding saddle tanks on t-bone collisions. Got a thousand dollar coupon for a new chevy as a Class Action Settlement. But look who's driving what now!
    65SNAKE likes this.
  11. Dec 24, 2019 at 9:27 AM
    #191
    LGTruckWesternSlope
    LGTruckWesternSlope New Member
    2019 Super White Tundra Limited Double Cab TRD Off-Road 4x4
    2019 Double Cab purchased in August....tracking mileage. Happy so far......see attached pdf Mileage History.
  12. Dec 24, 2019 at 1:51 PM
    #192
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's pretty good. Must be mostly highway?
  13. Dec 24, 2019 at 2:08 PM
    #193
    FlipMonkey21
    FlipMonkey21 New Member
    Mark
    SoCal Glendale
    2019 Toyota Tundra 4X4 Sport
    2019 Toyota Tundra Crewman TRD Sport Kings 2.5 Front & Rear suspension Camburg UCA Method Wheels MR312 18X9 +18 Offset 5x150 matte black w/toyo open country RT 35x12.5R18 tires Toyo Open Country RT 35X12.50 R18LT 123Q 10 P.R TRD Front Sway Bar (Removed) TRD Rear Sway Bar ( Removed) Carven Cat-Back Kit (torque 65lbs to 70lbs of torque) Windows tint Bakflip MX4 Bed Cover TRD CAI NSV air compressor AJT Design chrome delete NSV Light Bar Diode Dynamics 42" light bar Diode Dynamics SS3 Max Pod CBI Full Skid Plate CBI Lower Control Arm Shield Sibi Built regear Revolution 5.29 Harrop rear lockers Rigd mega swing Wheel lock Deaver springs U-748 King 3x16 650 Coil springs
    Got a 38 gallon tank filled up the tank full got about 409miles on the meter/gauge drive it to 0 miles remaining filled it up again full tapping it 3x and only showed 33 34 gallons filled
    Does that mean I have 4 or 5 gallons to go before it's really empty?
    Funny when I first drove the truck out of the dealer my meter/gauge show like 500+ miles remaining don't ever see that number again
  14. Dec 24, 2019 at 6:37 PM
    #194
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    Why would you think the last 8 or so gallons is “unusable”? Just because the light is on doesn’t mean you don’t get to use the gas.
    I don’t worry about the fuel pump, if we’re empty it will stop running.
    Cpl_Punishment and Nm6300'asl like this.
  15. Dec 24, 2019 at 6:46 PM
    #195
    18" TRD Off Road Wheels
    Just ignore the troll. Go look at the Tesla Cybertruck thread. He states he originally came to the forum to get a TRD Pro but has decided that the Tundra isn't worth it and all of us are idiots for not putting money down on a Tesla.
  16. Jan 10, 2020 at 4:02 PM
    #196
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    If you went 20 miles an hour for ever you might even get more than the 500 mile range???:)
    Cpl_Punishment likes this.
  17. Feb 12, 2020 at 7:04 AM
    #197
    SR520
    SR520 Lay it tight
    Robert
    Evergreen
    2020 SR5
    Leveled by Toytec: Boss Aluma 2.5 adj coilovers/ UCA
    Ran mine to " 0 miles remaining" on the display yesterday; pumped 33 gallons...
    Reserve = 5 gal to try to coast in, no?
    :monocle:
  18. Feb 12, 2020 at 3:12 PM
    #198
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    same here..... was thinking the truck was not programmed for the larger tank..... bought mine new 2016 TRD pro. but always makes me wonder when I have 20 miles to empty and only put in 28-30 gallons in??:monocle:
  19. Feb 12, 2020 at 3:17 PM
    #199
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    if you getting that MPG. your lucky !!!!!!!!!!!
    13MPG here. city/highway. im not complaining,,,, its a truck... but you lucky.
  20. Feb 12, 2020 at 5:26 PM
    #200
    Kerktam
    Kerktam Lexus truck wanted
    middle of nowhere, up north
    2023 limited TRD OR, 2024 silverado 5.3
    35 tires, 2 inch level kit
    I'm getting average 12mpg in winter here in Alaska with mine 5.7 2010 CM . 14mpg in summer
  21. Feb 13, 2020 at 2:35 PM
    #201
    BobaChris
    BobaChris New Member
    2017 Cement Grey Tundra TRD Pro
    I did this a couple months ago on accident. Filled my tank with just under 37 gallons at the pump. Unfortunately I'm in Southern California so it was over $3 a gallon and well above $100 to fill up.
  22. Feb 13, 2020 at 3:00 PM
    #202
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    It's an unregistered reserve that accounts for towing. If you're towing and only getting 7 to 8 MPG, 8 gallons isn't going to get you very far.
  23. Feb 14, 2020 at 5:03 AM
    #203
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    that makes sense, I just ASSumed, that since you can view REALTIME MPG.... that the distance to empty would adjust........
  24. Feb 14, 2020 at 6:44 AM
    #204
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Between 56 and 64 miles :anonymous:
  25. Feb 17, 2020 at 3:35 PM
    #205
    eddie98
    eddie98 New Member
    Atlanta, GA
    2018 MGM CM
    N-Fab Podium Steps, Line-X, Bed Lights
    I have gone aobut 25 miles after getting the 0 miles left and only put ~33 gals, sometimes I'm able to squeeze 35 but that's about it.
    When I got it new the computer said 470 left and now 2 years later when I fill up it never says more than 440 left. I reset my trip meter and I can consistently can get 500 miles to a tank (not counting going past 0 left).
  26. Feb 24, 2020 at 8:09 PM
    #206
    Tundra_Dawg
    Tundra_Dawg Boss Moss
    Arizona
    2017 MGM Platinum
    PPE headers, TRD exhaust, ICON 3" lift, Raceline wheels, Powertrax Tonneau cover; 2019 TRD Pro headlights and fogs; TRD pro grille; Victory 4x4 sliders.
    I reviewed my fillup records for the past 2 years, and I have put 33.7 to 33.9 gallons in at the pump on 5 occasions. Usually I'm around 31-32 gallons. I tend to get as close to empty as I can to take advantage of my fuel discount at Frys. I'm cool with having an extra 4 gallons in there when I fill up, since that's really only about 45 miles before fumes.
  27. Feb 27, 2020 at 5:45 AM
    #207
    EG1
    EG1 New Member
    Mass
    19 White 1794 CM
    I just bought 2019 1794 crewmax which I love but otw home from the dealer my gas light came on and with about 30 miles to go it said refuel so I thinking I wasn't going to make it. Got home fine, through 4 gallons in from a jug and drove to the gas station where I filled up with 26 gallons. Confused I hopped online and quickly found a thread similar to this one. Now that I know its not an issue, but my gas gauge is stuck all the way past full so I need to schedule an appointment at the dealer.
  28. May 7, 2020 at 12:35 PM
    #208
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    Gah...why can't a get an SR Tundra with the 3 passenger split-folding bench, LEDs and a 38 gallon tank?!! LOL
  29. May 7, 2020 at 2:11 PM
    #209
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If you could get your hands on a 38 gallon tank, I wonder how hard it would be to swap it in.
    pnw.tundra[QUOTED] likes this.
  30. May 12, 2020 at 3:53 AM
    #210
    ClaytonW
    ClaytonW New Member
    2022 Tundra 1794
    O.K., it looks pretty normal. I had about 10 Toyota/Lexus cars and SUVs and each of them had about 5 gallons left when the computer displayed 0 remaining miles. This is not a bug, it's a feature :) It was the same for my 2008 Sequoia and it's the same for my 2016 LX 570. I did not test it on my Tundra yet but I believe that there will be no difference.
