38 Gal tank experiences....
Discussion in '2.5 Gen Tundras (2014-2021)' started by KeithM, Mar 19, 2018.
  1. Nov 7, 2023 at 5:59 AM
    #781
    PermaFrostTRD
    Northern NY
    More than likely.
    Run it to empty. If you're filling up 20 gallons, you've got the 26'er. If you're filling up 28-32 gallons, you've got the big bloke.
    *edit*
    You can peak under the bed too. Big fella runs just about 4-5' long.
  2. Nov 7, 2023 at 6:04 AM
    #782
    JohnWhicker
    JohnWhicker New Member
    Thanks and we shall see after your proposed experiment :)
    PermaFrostTRD likes this.
  3. Nov 7, 2023 at 6:16 AM
    #783
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Easy to determine from under the truck. If it has 3 straps, it's the 38 gallon, 2 straps is the 26.
    Johnmatrix, KOTOC79, Mike59 and 4 others like this.
  4. Nov 9, 2023 at 2:56 PM
    #784
    JohnWhicker
    Can't see the tank under. There is a long cover and you can't see crap under that :(
  5. Nov 9, 2023 at 3:08 PM
    #785
    armyoffoo
    armyoffoo Member
    Cypress, TX
    If you look next to the drive shaft you should see the straps, the middle strap is on the same crossmember as the carrier bearing, and if you have the 38 gallon it has an extra crossmember looping under the drive shaft, just behind the exhaust crossover.
    Here you can see the 3 straps on mine:
    Here is a better shot at the front strap with dedicated crossmember looping under the drive shaft:
  6. Nov 30, 2023 at 2:02 PM
    #786
    dan_osms.io
    dan_osms.io Milana Vayntrub...
    NorVA
    2020 Tundra Ltd w/ TRD, 2003 Honda S2000 (NASA)
    Retrax XR, Yakima Overhaul HD w/ 78" Yak Crossbar, NatureNest RTT, WolfBox G850, Halolock Phone Kit, ICS DashMount
  7. Nov 30, 2023 at 2:40 PM
    #787
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
  8. Dec 3, 2023 at 7:30 PM
    #788
    Ran er past empty after a last minute urgent work request. Able to squeeze more almost 33 gallons in.
    Rstreight and Mike59 like this.
  9. Dec 4, 2023 at 8:21 PM
    #789
    dan_osms.io
    NorVA
    Mike59 likes this.
  10. Dec 5, 2023 at 12:24 AM
    #790
    Mike59
    Mike59 Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    Seems like a lot of work for just an 8 gallon gain.
  11. Dec 5, 2023 at 4:29 AM
    #791
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    https://www.tundras.com/threads/46-gal-transfer-flow.25519/ I just simply searched this and found this thread. Like Mike said, that's an expensive upgrade for only 8 gallons. Now if you have the small tank, then yes I could see it being worth while to do the upgrade. YMMV
    Mike59 and Cpl_Punishment like this.
  12. Dec 5, 2023 at 6:55 AM
    #792
    dan_osms.io
    NorVA
    That was initially my thought as well. I was calculating the weight difference and it's negligible. But it also opened the thought of, once installed the PID for the tank size would need to be adjusted. So it was curiosity biting at me to understand if anyone had seen larger tanks than the 46 upgrade, I see diesel tanks but that is for diesel applications.
  13. Dec 5, 2023 at 7:08 AM
    #793
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    If you have a center console, you have the 38 gallon tank. If you have 6 seats and a column shifter, you have the 26 gallon tank.
    TacomaTRD4x402 and Mike59 like this.
  14. Dec 6, 2023 at 5:53 AM
    #794
    dan_osms.io
    NorVA
    Did some searching on tundras.com forum in other generations there is no post Long Range or Transferflow mod to have DTE be correct. Just posting here in case someone else was searching for the same.
  15. Dec 8, 2023 at 7:15 AM
    #795
    JohnWhicker
    Actually mine is the 38. Just loaded the Toyota app in my phone, put in the VIN and got all the specs available, every option or upgrade that is included.
    dan_osms.io and Mike59 like this.
  16. Dec 8, 2023 at 2:50 PM
    #796
    GravityGear
    Aurora, CO
    DTE will never be correct with the new tank. I don't believe anyone has found a way to modify the tank size for the dash calculation. If you have a 38, I would not do it. It's a ton of work and a decent amount of money. From full, 2 clicks on the pump, I'll get about 730miles.
    dan_osms.io likes this.
  17. Dec 15, 2023 at 8:04 PM
    #797
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    God I love seeing this each time I fill up :bananadance:20231215_200312.jpg
    Phrog Driver and Mike59 like this.
  18. Dec 16, 2023 at 7:24 PM
    #798
    mpd13078
    mpd13078 New Member
    Alabama
    2017 Platinum Crewmax 4WD 5.7L
    Stock
    My 38 gallon tank, (fyi, fill up with top tier 87 grade), summer time shows 419 and winter time 414.
  19. Dec 16, 2023 at 7:32 PM
    #799
    TacomaTRD4x402
    Southern California
    :monocle: whaaat whyy
  20. Dec 17, 2023 at 1:55 PM
    #800
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Mine is almost always 406 or 409 miles.
    Minarets likes this.
  21. Dec 21, 2023 at 1:23 PM
    #801
    mpd13078
    mpd13078 New Member
    Alabama
    Stock
    Filled up today, top tier @ $2.63 / 87 grade. Pics before and after.IMG_5557.jpg IMG_5559.jpg IMG_5560.jpg
    Mike59 and TacomaTRD4x402 like this.
  22. Dec 21, 2023 at 1:31 PM
    #802
    TacomaTRD4x402
    Southern California
    Wow. $2.63!! Only $64 for 3/4 tank. Geez! I can only wish. But still, what's with the only 414miles and I'm showing close to 600miles on mine when I fill up. That's a dramatic difference.
  23. Dec 21, 2023 at 6:41 PM
    #803
    I just paid $72 for a full tank. $2.59 / gallon
  24. Dec 21, 2023 at 6:47 PM
    #804
    TacomaTRD4x402
    Southern California
    So jealous. 87 at the Chevron down the street is $4.90 right now. 91 is at $5.30 :annoyed: That's what my Taco takes
    Mike59 likes this.
  25. Dec 22, 2023 at 4:35 AM
    #805
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Why is your taco taking 91? OV tune?
    Ohio has been around the high $2's lately. It's nice. Even saw Diesel at $3.69 off the highway at a truck stop last night.
  26. Dec 22, 2023 at 5:13 AM
    #806
    TacomaTRD4x402
    Southern California
    It's supercharged
    Mike59 and ATV25 like this.
  27. Dec 22, 2023 at 5:17 AM
    #807
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I guess I could have read that in your signature. Makes sense now lol
  28. Dec 28, 2023 at 6:45 AM
    #808
    Florida AF
    Logan
    North Florida
    Same, but with regular fuel. I run a higher octane once a month or so.
    Mike59 likes this.
  29. Feb 19, 2024 at 6:18 AM
    #809
    Rstreight
    Rstreight New Member
    Ron
    South Texas
    2021 MGM Platinum 2WD
    Interesting about the low fuel light and the actual amount of fuel left in the tank, On my 21 I have taken it as low as needing 34 gals to refill, never had a problem? I just figure when the light comes on I have 75 to 100 miles left till I'm walking.
    When I first got my truck I was paranoid about getting low, but the 28 gallon refills just didn't seem right so I pushed it a few times and know when the light comes on I know I have at least 50 miles before really needing a fill. Usually around 32 gals.
  30. Mar 1, 2024 at 7:19 AM
    #810
    Henfield
    Henfield New Member
    That's the only bitch I have with any of the Tahoe/Sequoia/Expeditions. Their tanks are too small in comparison to the 36 (Ford) and 38 gallon Tundra. Whenever I embark on a long drive to a new place I plan my fuel and rest stops ahead of time. Solo I go 500 miles comfortably between refueling-pretty much lunch time so it makes sense. Towing, I plan my stops every 280-330miles. If its a multi day trip, I always end the day by refueling so I can in the morning, get in, start up and go.
